Fanuc CNC Parameter 14852, Fixed Form Character Length
Fanuc CNC controls include hundreds of parameters that quietly shape how the control behaves. One that often goes unnoticed—but can make a real difference to usability and program readability—is Fanuc CNC Parameter 14852, Bit 4.
This article explains what parameter 14852 bit 4 does, when you might want to change it, and what to watch out for before making any adjustments.
Shibaura Training
What Is Fanuc Parameter 14852 Bit 4?
Parameter 14852, Bit 4 controls the number of characters that can be displayed or entered in each fixed form field on supported Fanuc CNC controls.
When this bit is enabled, the control allows more characters per fixed form, effectively expanding the usable text length within those fields.
In practical terms, this means:
  • Longer text entries are possible
  • Descriptions and identifiers are less likely to be truncated
  • Fixed-form screens become more informative and easier to interpret
The exact behaviour can vary slightly depending on the Fanuc control series and software version, but the purpose of Bit 4 remains the same: increase character capacity per fixed form.
What Are Fixed Forms on a Fanuc Control?
Fixed forms are structured input screens used to quickly create program.
Typical forms:
  • Start of program
  • Call a tool
  • Call a cycle
  • End a program
I means the programmer does not need to memorise loads of G and M codes. The structures is created.
For more details on Fanuc macro variables and fixed forms, check our Fanuc Parameters that cover advanced control functions.
Why Increase the Number of Characters per Fixed Form?
Enabling Parameter 14852 Bit 4 can be particularly useful in the following situations:
1. Improved Program and Process Clarity
Longer character limits allow more information to be added in one keystroke.
2. Better Operator Understanding
Operators can see more meaningful descriptions without abbreviations, reducing the risk of misunderstandings on the shop floor.
Rads and Chamfers Fanuc Parameters 8134 3453
Category : Fanuc Parameters
Bits n Bobs
Rads and Chamfers Fanuc Parameters. Today we are going to change the parameters that make ,R and ,C work this means you can program point to point and just stuff in some rads and chamfers as an afterthought.
Here’s an article on it if you want to use it
Fanuc have two ways of putting on chamfers and rads and that’s where the confusion lies.
Just do as you’re told (oh and read this article)
So in Parameter 3453 you can set bit #0 (CRD) to a 1 this allows what Fanuc call “Direct Drawing Inputs” to work.
Also in Parameter 8134 set bit #2 (CCR) to a o
Now don’t let the description put you off this turns on the crappy one that uses R and R- and K and K-. This only works on 90 degree corners and unless you won Mastermind I wouldn’t even try to understand how it works.
Trust me it’s shit
Anyway Rads and Chamfers Fanuc Parameters 8134 3453 all sorted!
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
If you aint got a camera then you must have a piece of paper.
XYZ KRV 2000 Milling Machine
The XYZ KRV 2000 also branded as King Rich is what is commonly known as a turret mill it is an incredibly versatile machine. This machine can get into all the nooks a crannies that other machines can only dream of. It has an Acurite Mill Vision digital readout.
PLEASE READ THE SAFETY RULES AT THE END OF THIS ARTICLE
Access all areas, it’s a bit like the gynaecologist who repainted his hall through the letterbox.
My machine had the Acurite DRO this is the Acurite Mill Vision and for it’s age it still packs a punch as you will see later in the article.
It takes me back many, many years, in fact 50 years. I actually worked on a what was known as a Beaver Mill. Mine was a Beaver Pal very similar to the KRV 2000, still a few Beavers out there.
Now, not without it’s sexual connotations it was an unfortunate name but I was proud of my Beaver, it was brand new.
At the company I worked for Sharnco Tools, you were rewarded with your own brand new Beaver once you became fully skilled and qualified as a toolmaker. You also got all new collets chucks and tooling.
Wow luxury. (Don’t let anyone tell you the 70’s were shit.)
Turret Mill
On-Site Bridgeport BRJ Turret Mill Training
Develop your team’s practical machining skills with professional on-site Bridgeport BRJ turret mill training, delivered at your own workplace.
Rather than sending employees to an external training centre, the instructor comes to your premises and provides practical training using your own machinery. This helps learners become familiar with the exact turret mill, tooling and workshop environment they will use in their day-to-day work.
Bridgeport BRJ get one here
Practical Training at Your Premises
The Bridgeport BRJ turret mill training is designed for beginners, apprentices, maintenance engineers, workshop technicians and operators who need to improve or refresh their manual machining skills.
Training at your site reduces employee travel and time away from the workplace. It also allows the course content to be tailored around your equipment, working practices and typical machining tasks.
Where suitable, training can be delivered on a Bridgeport BRJ or a similar Bridgeport-style manual mill.
What the Training Covers
The course can be adapted to suit the experience of the learners and the requirements of your business. Typical subjects include:
  • Operation of digital read out (DRO) where applicable
  • Essential safety procedures and pre-use checks
  • Correct machine setup
  • Workholding and vice alignment
  • Selection and fitting of cutting tools, collets and chucks
  • Setting suitable spindle speeds and feeds and calculating them
  • Establishing a datum and setting work coordinates
  • Accurate measurement and dimensional checking
  • Face milling, slot milling
  • Drilling, countersinking, tapping and reaming
  • Safe tool changing
  • Machine shutdown
  • Routine care and workshop housekeeping
The emphasis is on safe, methodical operation and the practical skills required to produce accurate work on a manual mill.
Loading Tools on a Doosan DNM
There are several ways of Loading Tools on a Doosan DNM. The first is the most simple. Don’t forget this is random tool changer so it’s no good looking in the tool drum. Read this article first if you don’t understand how a random tool changer works.
Just call out the tool you want for example T6 M6 and then load your tool. Your tool has now become T6.
M45 To The Rescue
The other way of Loading Tools on a Doosan DNM is to use M45
Loading Tools on a Doosan DNM Access Tool Table
So to acces the tool table on a Doosan DNM press this button.
Doosan Tool Drum
This screen is displayed.
Press TOOL DATA button
This is your tool table that tells you where everything is in the Doosan Tool Drum.
This tells me that T20 (Too20) is in pocket 3 (P003).
Love It Or Leave It
From this screen you can decide what tools you want to keep and what tools you want to replace.
It’s a good idea to keep an actual list of what tools are in your machine.
If I wanted to use pocket three then call it in MDI tool 20 (M6 T20).
Doosan Tool Drum
Now you can load your tool, if the pocket is empty, or exchange it with this tool.
This button will release the tool if you are in a manual mode.
The tool can be heavy or stick in the spindle so be prepared for it to drop. It may be heavy so you could put a piece of wood under it to support i
From now on your tool will be tool 20 (T20).
Please don’t call it anything else because it will just ignore you.
