30 Plus Five Star Reviews
See all The Courses
CNC Setter Operator Training (Milling) what is this course?
This new course CNC Setter Operator Training is suitable for beginners who want to learn how to set and operate a CNC Milling Machine.
It covers all the basic principles of setting and operating a Fanuc G Code type system. It is also suitable for Haas controls and other G code type systems.
Duration: 2 or 3 days
Date: See course dates
Times: Start 9.30am Finish 4.00pm
£720 including VAT for two days
£1080 including VAT for three days
Book a Place Now
Live Training Simulators
Some students like to sit down and study but if you are hands on and like to see what you are learning then this course is for you.
Unfortunately you won’t have any pottery to take home to your partner.
You will learn right from first turning the machine on to turning the machine off.
Each part of the course is carefully explained with loads of visual exercises and real examples.
Virtual Reality
When you train at the CNC Training Centre You get your own virtual machine to practice on.
Using the different modes of the CNC Machine.
- Manual
- Jog
- Edit
- MDI
- Auto
- Zero Return
Book a Place Now
Each mode of the machine demonstrated with a chance to try for yourself.
Setting work offsets G54 to G59
This can be a difficult concept for a beginner. Not to worry help is at hand. It’s easily explained on your virtual machine where you can see just how it all works.
We will set up some sample parts and add the work offsets. Honestly it’s easy once you see it in action.
Then if you want to see what happens if you change something. Go ahead try it. The virtual machine may crash but we don’t charge you for the damage.
Book a Place Now
Setting Tool Length offsets.
It’s easy when you know how.
Setting offsets manually and using automatic methods.
Full machine demonstration of how the tool length offsets work. You will get a chance to test your own skills hopefully without breaking too many tools.
Book a Place Now
Prove out and test a new program.
We will create CNC Programs in the classroom and then you get to test them out. You will learn how to safely test and prove out a CNC Program.
How to use MDI to load tools and start up the spindle.
MDI is included in CNC Setter Operator Training. Entering short lines of code to make the machine behave itself.
Learn to use The Manual modes of a CNC machine.
As a CNC Setter Operator you will learn to jog the machine around and using the hand-wheel.
And loads more, book your place today we can’t wait to see you.
