Month: October 2025
CNC Turning M Codes List For Beginners
CNC Turning M Codes
CNC turning M Codes
Download CNC Turning M Code List
This is my list of CNC Turning M Codes and you will notice there aren’t many.
That’s because you don’t actually need many.
M Codes are used to turn things on and off on a CNC Lathe. Sometimes known as miscellaneous functions.
A typical M Code would be M03 which would start your spindle forwards.
M04 would be reverse and guess what?
M05 is stop the spindle.
There, you learned three already.
You don’t need the extra zero so I advise you leave it out, program M3 M4 M5.
It really doesn’t matter but….. You could be wasting memory space or wearing out the tips of your fingers.
Here’s what I think about leading zeros.
M codes are the Snow Leopards of CNC Machining
Snow Leopards are Solitary Animals
Snow Leopards only ever get together to mate, they don’t even have a Christmas party or get pissed on a stag night.
With M codes they hate being on the same line of code. If they are then they will fight to the death.
Tigers Playing
Please note no animals were hurt in the making of this post.
There are exceptions to this rule, M Codes that is, but please don’t overload yourself with this at the moment.
Just trust me.
The first one in the block usually wins but I can’t  guarantee it. So you could get some crazy shit happening.
M8 G0 X50. Z2. G97 S1500 M3;
You wouldn’t even get an alarm on most controls and it may just obey the first M Code it sees and ignore the last one.
The other thing to note with M Codes is that it makes no difference where they are in a block of code.
So if you put your M Code at the front of a block of code.
M3 G97 S1500;
Or the end.
G97 S1500 M3;
The spindle will start according to the logic of the machine not where the M Code is in the block of code.
The Boring CNC Turning M Codes
That’s my list of M Codes the rest are really boring doing stuff like changing gear ranges and stuff.
Sorry I’m being flippant again.
CNC Turning M Codes Where Are The Rest?
Sorry you can’t have them. The reason for this is that they are different depending on what machine they are on.
CNC Turning M Codes
Hand Em Over
For example this beast is a Mazak Megaturn
CNC Turning M Codes
Mazak Megaturn
It Has a Gearbox.
To change gear you program M41 M42 and M43 for the different gears
M40 is neutral. Now on machines with gearboxes they do normally use these same M Codes.
However they can be different.
M10….. mmmm well that’s normally a clamp.
I think you get the picture. It is up to the machine tool builder.
It is best to get a specific set of M Codes from your machine manual.
The manual by the way is that book that nobody ever reads, it’s usually at the bottom of a bent up old filing cabinet.
Please Don’t Read It
I’ll read it for you then charge you a shit load of money for training.
Click here for CNC Training
Some M codes That “Might” be Useful
Open Chuck                         (Might be M11)
Close Chuck                         (Could be M10)
Parts Catcher Up               (Mmmmm)
Parts Catcher Down         (No idea)
Well Commented Programs
M11 (OPEN CHUCK)
M10 (OPEN CHUCK)
etc etc
I once had a boss once who actually learnt sines and cosines of angles.
Cosines of Angles
Holy shit I mean it’s fuckin impressive and I must add in the 1970’s  it was actually worth doing because we didn’t even have calculators. We just had bits of paper, pencils and Ford Capris.
The Market Online Classic Car Auctions
Mine was just like this but mine was a P reg three litre, vinyl roof handled like a cow on a march. Very fast at the time. Dream car, loved it.
Hope you enjoyed reading my article on CNC Turning M Codes.
Edgecam Part Modeler is once part of the Edgecam suite of programmes. You can create solid models very easily with Edgecam Part Modeler from simple line drawings.
You can move straight into Edgecam from Edgecam Part Modeler and start machining your component.
The brilliant thing is that through associativity you can alter the model and Edgecam will immediately know that you altered it in Part Modeler.
It will then allow you to automatically update the Edgecam programme to suite. Anyway watch my video on associativity
The video below is about how you can build assemblies. This could be something like a fixture with all its bolts and clamps.
This could be one complete assembly and you could move it around and do all sorts of things to it as a single unit.
You can also have sub-assemblies which are assemblies inside assemblies.
The great thing is that if, for example, you make a clamp, a bolt and a nut as a single assembly, when you get into Edgecam and you need to move them over a bit you can easily move them in one go as a single unit.
All you would have to worry about is filling in the hole you left behind and creating a new one in the new position.
It’s really easy to drag and drop bits or full assemblies around. That means you can take a part and move it into a different assembly very easily.
Leading Zeros Programme Numbers
Next time you call up a programme on your Fanuc or Haas control. Instead of typing O0001
Just type O1
I know it’s daft but just add up all the time you wasted (Three presses of your Zero key no wonder it’s worn out)
Training Courses
Fanuc Haas Training
More Heidenhain
Drawing Datum
On  a Fanuc control it’s a G code usually G54 although as standard you have six of these.
G54 G55 G56 G57 G58 G59
Zero Return
X 0.000
Y 0.000
Z 0.000
What about Z you say?
Mazak Work Offsets
CNC Training Mazak
Toshiba BMC 800 Work Offsets
Is Six Enough?
Right Let’s Wrap This Up
So now if we program
Because G54 is Modal.
Digital Readout
Toshiba Tosnuc CNC Training
G57 H901
G0 X0 Y0
So Where’s This All Going?
Now then think about this.
Don’t Just Plonk It Anywhere
Now when you program.
G0 G55 X0 Y0
By The Way
There’s More
Matsuura Training 500v
Lets Save Some Time
Mazak Training
Doesn’t matter either.
Work Offset G54 G55 G56
And…
Heidenhain
Bridgeport Interact 412
Heidenhain Training
This would call out offset 1.
Just zero the display.
How easy is that?
Heidenhain Training
Heidenhain Training
Heidenhain Training
So there you go from Heidenhain on a Bridgeport Machine to Matsuura MX520 with a Matsuura G-Tech 31i control. There are loads of different machines but the principle is always the same.
Call David 07834 858 407
Jump Around Using M99 Plus Block Skip
M99 Plus Block Skip, M99 on a Fanuc, Haas or Mazatrol ISO control can be used to jump sections of code.
Learn to use this in conjunction with the block skip command to switch it off and on.
Now I know you are all thinking “Dave you’re wrong it’s the end of a sub-program”. (Please in the name of holy shit do not call me Dave.)
Well you are right and you are wrong.
Yes it means continue and is used at the end of a sub program.
But it also has another nifty use.
Imagine you want to skip a complete section of program in the case below it’s the Spot Drill.
Let’s See Some Crap Ways Of Doing This
(If you want to do this on a Toshiba Tosnuc 888 or similar control go to the end of the article)
In this example it’s a spot drill we want to miss out.
M99 Plus Block Skip
Standard Code
You could delete it and make two programmes (sounds like hard work and loads of errors). Not to metion wear on your finger tips. Truth is it’s just a shit way to do it.
M99 CNC Code
Block Skip
The programme above  contains BLOCK SKIPS sometimes called BLOCK DELETES.
When you switch on your BLOCK DELETE/BLOCK SKIP switch, each time a forward slash (/) is seen that block will not be processed and the control will move on to the next block.
M99 Plus Block Skip
On most Fanuc controls it’s B.D.T not to be confused with CBT (Cock and balls torture) please do not google this in company time.
It works ok but it is very time consuming. If you want to skip a big section of code you will have to write in loads of block skips.
Call me a lazy bastard but I definitely couldn’t be arsed with that.
Some controls even have two three and four block skips so you can switch on any combination of these switches, mmmm complicated. Good luck with that one.
Do You Have Adequate Life Insurance?
M99 CNC Code (Now let’s use it)
The next example is the easiest way.
You probably normally see an M99 at the end of a sub programme.
In the case below it tells the control to jump to N100 (M99 P100).
The P part is the N number you want to jump to.
M99 P600 (Jump to N600)
M99 P6666 (Jumps to N6666)
M99 Plus Block Skip
If you put the BLOCK SKIP/BLOCK DELETE on it will not jump the spot drill.
You would have a choice. If you temporarily want to skip a section of code.
Be careful what N Numbers you choose so as not to mix them up.
Maybe you broke all the taps and you don’t have anymore so you want to skip the tapping. In this case I’d just jump with M99 and then take it out before saving the program.
However, see the next Example.
For this last example you might have to think a bit. Call me finicky but I like the BLOCK SKIP/BLOCK DELETE as a default to be off.
Most machines now don’t have a mechanical switch for BLOCK DELETE/BLOCK SKIP so when you turn on the machine block skip will always be off.
That means the default would be to jump the code.
My way of looking at it, is that you would want the default to be running the whole program as normal.
So We Are Agreed
The default should really be the way the programme was originally done.
In the example below if the block skip is off, which it will be when you start up your machine.
The first thing it will do is jump over the bit that tells it to jump the code.
Meaning it runs as normal not jumping any tools.
The Clever Shit (M99 Plus Block Skip)
M99 Plus Block Skip
What’s This?
Now I know this is a bit confusing and maybe I didn’t explain it too well. Trust me it works.
What’s the matter with you lot just take some time to fuckin read it.
Sorry I’m losing my temper a bit here, the dog’s just pissed on the TV remote again. Just read through it a few times and the penny will drop.
CNC Training Centre Classroom Training
Where the teacher is never angry.
DO NOT PASS GO DO NOT COLLECT £200
Yes you can do this with GOTO
This is my pet Cockroach his name is Boris
GOTO 100
Same as M99 P100
To do this you must have the Macro Option if you don’t then this is where M99 comes in handy.
Best way to see if you have macro is to try using it in MDI.
In MDI Type in #1=6 if you have macro it will work if you don’t you’ll get an alarm and your machine will self destruct in 15 minutes.
Jumping Sections of Code on a Toshiba Tosnuc 888 or Similar
This is how you do it on a Toshiba (the blue bit).
Don’t forget it’s GO (that’s G and letter O) not G0 which is G and number zero (Rapid Command).
Don’t get your letter O’s and your number zeros mixed up.
/M99 P50                                   /[GO,50]               (JUMP TO N50)
M99 P100                                    [GO,100]            (JUMP TO N100)
N50                                              N50                      (ARRIVE HERE
THE CODE
THE CODE
THE CODE
ETC
ETC
ETC
ETC
N100                                            N100                      (ARRIVE HERE)
Without Fancy Shit  (Just jump some code)
THE CODE
THE CODE
THE CODE
ETC
ETC
ETC
ETC
If you have macro you can do a similar thing on Mazak, Haas or Fanuc.
Call 07834 858 407
