Month: December 2024
Fanuc Useful Variables
Category : Macro News
Call David: 07834 858 407  (On or off-site Training)
If you use macro programming quite a lot these Fanuc Useful Variables will definitely speed things up for you.
#0 Null Mmmm
#0 this is null, use this to make something have no value, that’s not zero by the way.
You can use this to see if your macro user has not entered a value for some letter you have used.
This means you can then apply a default value if there is none stated.
#1 to #33 are classed as local variables. These values are not retained depending on settings.
These variables will be assigned to corresponding letters in your macro call line.
For example using letter A will represent #1 in the body of your macro.
We have loads more articles on macro if you are interested.
System Variables
These are amazing you can interrogate the sytem, ask it questions like.
What tool is in the spindle?
What time is it?
What speed are you running at?
Almost anything, well you know not anything as in, will I go bald or what horse should I bet in the Grand National?
Fanuc Useful Variables Work Offsets
Or these
Setting a Macro As an Alias Using M Code
Setting a Macro As an Alias Using G Code
Fanuc Useful System Variables Modal Information
Don’t Be alarmed
#3000 is a system variable it puts the machine into an alarm state. You can assign a value of 0-200 and a message in brackets such as.
(THE TOOL IS BROKEN YOU TWAT)
#3000=100 (SORRY FOR SWEARING AT YOU)
Single block
#3003=1 will disable single block
#3003=0 will enable single block.
Thanks for reading my article, if you need to look for more information there’s loads more on this website or go here for Fanuc manuals.
It’s a bit spammy but you can get the manuals you need.
Decimal Point Fanuc Parameter 3401
Decimal Point Fanuc Parameter, to change this parameters you need to go to the setting screen in MDI. Now put a 1 in the parameter write box.
Today we are going to change the parameter that allows us to program with or without a decimal point.
If you set parameter 3401 BIT 0 (DPI) to a 1 then you can input numbers like a calculator.
X5000 will be taken as 5000mm
If you set parameter 3401 BIT 0 (DPI) to a 0 then your numbers will be taken as microns..
X5000 will be taken as X5  (in other words 5000 microns you would need to program X5000. to get 5000mm
X5000000 would also work
Decimal Point Fanuc Parameter Why?
It doesn’t really matter how you set this it’s entirely up to you. What I would recommend is that you make all your CNC machines behave in the same way.
Teach everyone to always input a decimal point and then if it’s needed then you got it.
Parameters You may Want to Change
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
This guy has more CNC Manuals than you can shake a stick at.
G Code Alias Fanuc Parameter 6050
G Code Alias Fanuc Parameter, to change this parameters you need to go to the setting screen in MDI.
Today children we are going to change the parameter that allows us to alias a G code to a 9000 series program.
So for example if you were to put 384 in parameter 6050 then if you program G384 you would be directed to program 9010. (See the list below the program)
09010 (G384 Macro)
M9 (Turn off Coolant)
M5 (Stop Spindle)
G40 (Cancel Cutter Compensation)
G80 (Cancel Canned Cycle)
G90 (Absolute)
G0 G53 X0 (Return X To Tool change Position)
G53 Z0 (Return Z To Tool Change Position)
(Any Old Shit You Want to Do)
So when you program G384 in MDI or from a program it jumps into program 9010 and does all that lot.
Parameter 6050 is the G code for program 9010
Parameter 6051 is the G code for program 9011
Parameter 6052 is the G code for program 9012
Parameter 6053 is the G code for program 9013
Parameter 6054 is the G code for program 9014
Parameter 6055 is the G code for program 9015
Parameter 6056 is the G code for program 9016
Parameter 6057 is the G code for program 9017
Parameter 6058 is the G code for program 9018
Parameter 6059 is the G code for program 9019
There is just no end to the stuff you can do with this.
I’m not telling you anymore cos I need the work and probably couldn’t handle the competition. This bloke seems to know more than me about all this macro shit so go and visit him.
Don’t come crying back to me cos I wont have you on my site again.
The Bonus
Because you didn’t go I’ll tell you more….
You can alias programs to M codes and G codes.
Whats the difference?
When you alias a G code you get to pass parameters to it.
It’s like when you call a canned cycle for example when you call G81
G81 R1. Z-10. F100.
This would tell the machine to drill a hole 10mm deep. Well that Z figure of -10 is a parameter being passed to the cycle.
So when you program a special G code that jumps into a 9000 series program you can send information with letters.
With an M code sadly you can’t
Some More Interesting Parameters
3101 Clear Screen
Parameters I Like to Change
If you have worked on many Fanuc controls like I have you will know that there are massive differences in the way they operate. No it’s not because they were not all created equal. It’s just the dreaded parameters.
Now I can’t stress enough how important it is not to mess with the parameters of a machine. So don’t.
Please Proceed If You Are Stupid
Maybe your not stupid maybe you actually want to wreck your CNC Machine so you chose to carry on.
Once I have set these parameters the machine almost performs how I want it to.
These are not machine options that you pay for or anything like that. They are just choices as to how you want the control to work.
Point of No Return
First of all you’ll need to go to the setting screen and change the parameter write box to a 1.
You will need to be in MDI to do this and all the subsequent alterations.
Please note that these parameters wont necessarily be the same on all machines so please check your parameter manual.
This stops that annoying alarm when you reach the end of travel on the various axis.
When proving out I like to use the feed rate override control to stop rapid moves as well as feed moves.
3202 Unlock Program 9000 to 9999 and 8000 to 8999 to Edit
I often need to acces the 9000 series program and this allow me to do it.
This parameter will clear the MDI screen each time it is used.
This parameter will determine if you need to add a decimal point to your X Y Z numbers.
I love local sub routines, this parameter means M98 Q500 will jump to internal program N500
3301 Allows you to make screen shots
I use screen shots all the while they are really useful for keeping a record of the different screens especially parameters so do yourself a favour and use this one
More interesting parameters.
3101 Clear Screen
Allow Screen Shot Fanuc Parameter 3301
Unlock Programs Fanuc Parameter, first of all you’ll need to go to the setting screen and change the parameter write box to a 1.
If you want to make screen shots on your Fanuc control this parameter may need altering.
Just press and hold the shift key to make a picture of the screen on your data card or usb.
Should look like this to make it work.
