Month: July 2026
CNC Help Beginners Operation Modes
CNC Help, this article is about the different modes of operation on a CNC Machine
CNC Help
Depending on what mode you are in
  • Zero Return
  • Jog
  • Handwheel
  • MDI
  • Memory/Auto/Full Run
  • Drip Feed/Tape
  • Edit
This determines what you can do on the machine.
CNC Help
Learn all this and more
Zero Return
So when we turn on the machine we would need to zero return the machine. What is Zero Return you ask?
Well when you switch on the machine it’s a bit like when you wake up the next day after drinking a whole bottle of whisky.
First thing you think is where am I? Then the memories flood back of how you were dancing naked on the bar.
A CNC machine is much the same (except they don’t piss in a complete strangers cupboard). So you need to let the machine know where it is.
We move the machine back to it’s zero position and on the way it triggers a dog which is like passing over a button. This tells the machine where it is.
You’ll notice it slows down as it passes over this dog. That gives it time to sort itself out.
No dogs were harmed to create this post
Not a real dog you turkey that would be cruel I mean a switch.
You only need do this when you first turn on the machine. After that the machine always knows where it is.
Jog
Jog what’s Jog? Well in this mode you will have an X Y and Z buttons.
CNC Help
You will also have a feed control potentiometer.
(A twisty knob to you)
It’s like when you turn the music up.
CNC Help
This determines how fast your axis will move when you press X Y or Z in the plus or minus direction.
This very often has a rapid button that you can hold in to make the moves really fast if you really want to shit yourself.
So you can use this to move your axis around. You could even use it to drill a hole or face mill a part.
CNC Help Hand wheel
CNC Help
When you use the hand wheel you would normally be required to select an axis and an increment as below.
CNC Help
If you selected the X axis and an increment of 0.1 then each click of the hand wheel will move the X axis 0.1mm.
The hand wheel always reminds me of the robbers cracking the safe in the old movies.
Again you can use the handwheel much like jog to get the machine in the position you want and maybe drill a hole or something.
Haas handwheels have a really course setting like 1mm a click so beware!! But it’s great for quickly getting around the machines.
Also beware of over-run, because some Haas Toolroom Machines will carry on after you finished turning the hand wheel!!! Holy shit batman.
Just remember that these articles are designed as general guidelines as machines will vary.
If you use the analogy of driving a car then it’s like borrowing your mates car. It will definitely have lights and indicators. You just got to find where the switches and buttons are.
Got this off ebay only 5000 quid
Incremental Jog
Just thought I’d add this in. Some machines have an incremental jog and I suppose it’s a bit of a combination between handwheel and jog.
You select an increment and each time you press the axis button (XYZ) the machine feeds that amount.
Very useful for clocking in bores and stuff like that. Personally I like the idea and if I worked on a machine with this I’d be using it.
Read the manual and get the most out of your machine.
Safety
It’s important to remember that handwheel and jog can usually be used with the door of the machine open. They may seem gentle and there’s not much noise going on.
Please note you are using the full power of the machine and if your hand is in the way the handwheel will not stop.
MDI
Remember that these modes may have slightly different names but all CNC machines will have them.
Like on some Siemens controls MDI is called MDA (don’t google that one!!!)
Manual Data Input (I suppose it’s kind of self explanatory).
It’s just a way of writing little short bits of CNC code and it’s normally automatically deleted after use.
You could use this for things like doing a tool change or starting the spindle.
Almost anything that you would put in a program can be done in MDI.
It is usually used once and thrown away, not really environmentally friendly single use program.
CNC Help
Most controls have a way of converting this MDI program into a permanent one to keep in memory. Fanuc uses program O0000 for MDI and it’s a bit like a clipboard. You can change this program O0000 to a real program number like O0001.
There is also a parameter you can change that makes the program stick around after you used it.
Some operators only use MDI for tool changes so you might want to keep the code  there for whenever you need it.
Moan Moan Moan
On a Fanuc control you have to put an EOB (end of block or semicolon) at the end of the line of code to make it work. Otherwise you get an alarm. Drives me bonkers.
Digital punishment
This mode can have different names but it’s the mode where you get to run your programme.
After selecting the programme you want to use select this mode.
When you press cycle start the programme will run.
CNC Help
You can run your programme in single block
And that red button at the side there is feed hold, it will halt the programme movement but it won’t usually stop the spindle from rotating.
Drip Feed/Tape
This mode is usually for running direct from a Memory Card or PC and it varies from machine to machine. Some will run direct from a floppy disc.
It is for those massive programs too big for the machine memory. Some really old machines will even run a paper tape.
Drip feed is a bit like lying under a beer tap and slowly getting pissed.
Anyway you don’t need to worry your pretty little head about that one at the moment.
Picture of a floppy disc for our younger viewers.
Let’s get on to the interesting shit.
CNC Help Edit
Edit well it’s kinda when you edit….
Yes it’s when you alter the program. In the edit mode you can look at any of your programs stored in your machine and Edit them.
There are massive differences in what you can do depending on your CNC control.  Don’t get me started on this one cos I think CNC Machines have been in the stone age on this one for years. Now I’m not going to mention names but even simple things like copying programs can be an absolute piece of shit.
So if your used to the power of editing on a PC get ready to go back in time. Most new machines are pretty good on this now but it’s taken a long time and I still find it really convoluted and counter intuitive. (I don’t know what either of those words mean).
CNC Help
Here is a short video on how to copy and paste on a Fanuc 18i it’s very similar on most oldish Fanuc controls. (Excuse the long intro on the video but I am trying to flog records as well here).
Oh and if you want to copy a program on an 18i Fanuc view this one.
Editing in its simplest form is INSERT ALTER and DELETE.
CNC Help
These are self explanatory but I have put a nice little gif above just to hold your attention.
Most modern controls will have FIND and REPLACE. It is well worth learning to use this because it guarantees that you don’t miss any figures in your programme.
Like if you had X57.65 in your program six times if you use FIND/REPLACE to change em all to X57.66.
You are sure to catch them all and you can be sure they are all accurate. Even if you altered em to the wrong figure at least they will all be the same.
Click here if your interested in training with us.
Or just get in touch.
DMG Mori CTX
Category : New Stuff Siemens
DMG Mori CMX 800 V Review: The iPhone of CNC Machines
This is my honest DMG Mori CMX 800 V review, written after getting back behind the control and remembering all the little rituals this machine expects you to know.
This machine is gorgeous.
The first time I saw one was at the NEC quite a few years ago. I remember looking at it and thinking:
“This thing is beautiful.”
To me, it brought CNC machines properly into the 21st century.
This is definitely the iPhone of the CNC machine world.
Even the handwheel is sexy. Yes, I know.
I’ve reached the age where I’m describing a CNC handwheel as sexy. Things could be worse.
When You Know, You Know
Something that annoys me about modern CNC machines is the rigorous protocol you sometimes have to follow to do the simplest bloody thing.
This machine definitely has a few of those little rituals.
I think I now understand the expression:
“When you know, you know.”
Because until you know, you haven’t got a fucking clue.
I was genuinely excited about working with this beast.
That excitement lasted right up until I couldn’t get the handwheel to work.
Fortunately, I always allow plenty of time to get back into using a machine I haven’t seen for a while.
Partly because machines have their own quirks.
Partly because controls change.
And partly because my memory now works like an old Windows computer with twelve toolbars installed.
Fanuc CNC Parameter 14852, Fixed Form Character Length
Fanuc CNC controls include hundreds of parameters that quietly shape how the control behaves. One that often goes unnoticed—but can make a real difference to usability and program readability—is Fanuc CNC Parameter 14852, Bit 4.
This article explains what parameter 14852 bit 4 does, when you might want to change it, and what to watch out for before making any adjustments.
Shibaura Training
What Is Fanuc Parameter 14852 Bit 4?
Parameter 14852, Bit 4 controls the number of characters that can be displayed or entered in each fixed form field on supported Fanuc CNC controls.
When this bit is enabled, the control allows more characters per fixed form, effectively expanding the usable text length within those fields.
In practical terms, this means:
  • Longer text entries are possible
  • Descriptions and identifiers are less likely to be truncated
  • Fixed-form screens become more informative and easier to interpret
The exact behaviour can vary slightly depending on the Fanuc control series and software version, but the purpose of Bit 4 remains the same: increase character capacity per fixed form.
What Are Fixed Forms on a Fanuc Control?
Fixed forms are structured input screens used to quickly create program.
Typical forms:
  • Start of program
  • Call a tool
  • Call a cycle
  • End a program
I means the programmer does not need to memorise loads of G and M codes. The structures is created.
For more details on Fanuc macro variables and fixed forms, check our Fanuc Parameters that cover advanced control functions.
Why Increase the Number of Characters per Fixed Form?
Enabling Parameter 14852 Bit 4 can be particularly useful in the following situations:
1. Improved Program and Process Clarity
Longer character limits allow more information to be added in one keystroke.
2. Better Operator Understanding
Operators can see more meaningful descriptions without abbreviations, reducing the risk of misunderstandings on the shop floor.
Rads and Chamfers Fanuc Parameters 8134 3453
Category : Fanuc Parameters
Bits n Bobs
Rads and Chamfers Fanuc Parameters. Today we are going to change the parameters that make ,R and ,C work this means you can program point to point and just stuff in some rads and chamfers as an afterthought.
Here’s an article on it if you want to use it
Fanuc have two ways of putting on chamfers and rads and that’s where the confusion lies.
Just do as you’re told (oh and read this article)
So in Parameter 3453 you can set bit #0 (CRD) to a 1 this allows what Fanuc call “Direct Drawing Inputs” to work.
Also in Parameter 8134 set bit #2 (CCR) to a o
Now don’t let the description put you off this turns on the crappy one that uses R and R- and K and K-. This only works on 90 degree corners and unless you won Mastermind I wouldn’t even try to understand how it works.
Trust me it’s shit
Anyway Rads and Chamfers Fanuc Parameters 8134 3453 all sorted!
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
If you aint got a camera then you must have a piece of paper.
XYZ KRV 2000 Milling Machine
The XYZ KRV 2000 also branded as King Rich is what is commonly known as a turret mill it is an incredibly versatile machine. This machine can get into all the nooks a crannies that other machines can only dream of. It has an Acurite Mill Vision digital readout.
PLEASE READ THE SAFETY RULES AT THE END OF THIS ARTICLE
Access all areas, it’s a bit like the gynaecologist who repainted his hall through the letterbox.
My machine had the Acurite DRO this is the Acurite Mill Vision and for it’s age it still packs a punch as you will see later in the article.
It takes me back many, many years, in fact 50 years. I actually worked on a what was known as a Beaver Mill. Mine was a Beaver Pal very similar to the KRV 2000, still a few Beavers out there.
Now, not without it’s sexual connotations it was an unfortunate name but I was proud of my Beaver, it was brand new.
At the company I worked for Sharnco Tools, you were rewarded with your own brand new Beaver once you became fully skilled and qualified as a toolmaker. You also got all new collets chucks and tooling.
Wow luxury. (Don’t let anyone tell you the 70’s were shit.)
Turret Mill
