Day: July 23, 2026
DMG Mori CTX
Category : New Stuff Siemens
DMG Mori CMX 800 V Review: The iPhone of CNC Machines
This is my honest DMG Mori CMX 800 V review, written after getting back behind the control and remembering all the little rituals this machine expects you to know.
This machine is gorgeous.
The first time I saw one was at the NEC quite a few years ago. I remember looking at it and thinking:
“This thing is beautiful.”
To me, it brought CNC machines properly into the 21st century.
This is definitely the iPhone of the CNC machine world.
Even the handwheel is sexy. Yes, I know.
I’ve reached the age where I’m describing a CNC handwheel as sexy. Things could be worse.
When You Know, You Know
Something that annoys me about modern CNC machines is the rigorous protocol you sometimes have to follow to do the simplest bloody thing.
This machine definitely has a few of those little rituals.
I think I now understand the expression:
“When you know, you know.”
Because until you know, you haven’t got a fucking clue.
I was genuinely excited about working with this beast.
That excitement lasted right up until I couldn’t get the handwheel to work.
Fortunately, I always allow plenty of time to get back into using a machine I haven’t seen for a while.
Partly because machines have their own quirks.
Partly because controls change.
And partly because my memory now works like an old Windows computer with twelve toolbars installed.
Fanuc CNC Parameter 14852, Fixed Form Character Length
Fanuc CNC controls include hundreds of parameters that quietly shape how the control behaves. One that often goes unnoticed—but can make a real difference to usability and program readability—is Fanuc CNC Parameter 14852, Bit 4.
This article explains what parameter 14852 bit 4 does, when you might want to change it, and what to watch out for before making any adjustments.
Shibaura Training
What Is Fanuc Parameter 14852 Bit 4?
Parameter 14852, Bit 4 controls the number of characters that can be displayed or entered in each fixed form field on supported Fanuc CNC controls.
When this bit is enabled, the control allows more characters per fixed form, effectively expanding the usable text length within those fields.
In practical terms, this means:
  • Longer text entries are possible
  • Descriptions and identifiers are less likely to be truncated
  • Fixed-form screens become more informative and easier to interpret
The exact behaviour can vary slightly depending on the Fanuc control series and software version, but the purpose of Bit 4 remains the same: increase character capacity per fixed form.
What Are Fixed Forms on a Fanuc Control?
Fixed forms are structured input screens used to quickly create program.
Typical forms:
  • Start of program
  • Call a tool
  • Call a cycle
  • End a program
I means the programmer does not need to memorise loads of G and M codes. The structures is created.
For more details on Fanuc macro variables and fixed forms, check our Fanuc Parameters that cover advanced control functions.
Why Increase the Number of Characters per Fixed Form?
Enabling Parameter 14852 Bit 4 can be particularly useful in the following situations:
1. Improved Program and Process Clarity
Longer character limits allow more information to be added in one keystroke.
2. Better Operator Understanding
Operators can see more meaningful descriptions without abbreviations, reducing the risk of misunderstandings on the shop floor.
Rads and Chamfers Fanuc Parameters 8134 3453
Category : Fanuc Parameters
Bits n Bobs
Rads and Chamfers Fanuc Parameters. Today we are going to change the parameters that make ,R and ,C work this means you can program point to point and just stuff in some rads and chamfers as an afterthought.
Here’s an article on it if you want to use it
Fanuc have two ways of putting on chamfers and rads and that’s where the confusion lies.
Just do as you’re told (oh and read this article)
So in Parameter 3453 you can set bit #0 (CRD) to a 1 this allows what Fanuc call “Direct Drawing Inputs” to work.
Also in Parameter 8134 set bit #2 (CCR) to a o
Now don’t let the description put you off this turns on the crappy one that uses R and R- and K and K-. This only works on 90 degree corners and unless you won Mastermind I wouldn’t even try to understand how it works.
Trust me it’s shit
Anyway Rads and Chamfers Fanuc Parameters 8134 3453 all sorted!
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
If you aint got a camera then you must have a piece of paper.
XYZ KRV 2000 Milling Machine
The XYZ KRV 2000 also branded as King Rich is what is commonly known as a turret mill it is an incredibly versatile machine. This machine can get into all the nooks a crannies that other machines can only dream of. It has an Acurite Mill Vision digital readout.
PLEASE READ THE SAFETY RULES AT THE END OF THIS ARTICLE
Access all areas, it’s a bit like the gynaecologist who repainted his hall through the letterbox.
My machine had the Acurite DRO this is the Acurite Mill Vision and for it’s age it still packs a punch as you will see later in the article.
It takes me back many, many years, in fact 50 years. I actually worked on a what was known as a Beaver Mill. Mine was a Beaver Pal very similar to the KRV 2000, still a few Beavers out there.
Now, not without it’s sexual connotations it was an unfortunate name but I was proud of my Beaver, it was brand new.
At the company I worked for Sharnco Tools, you were rewarded with your own brand new Beaver once you became fully skilled and qualified as a toolmaker. You also got all new collets chucks and tooling.
Wow luxury. (Don’t let anyone tell you the 70’s were shit.)
Turret Mill
