Month: October 2026
Doosan Lynx 2100 LSY
This week had loads of fun on Doosan Lynx 2100 LSY. Seems to be a very well thought out machine oh and they don’t skimp on the extras.
Not the simplest of machines to operate but once you get over it’s little quirks let’s face it we all have them.
I mean I keep scratching my bollocks but as long as it is not in public or in front of the wife I usually get away with it.
This machine has one turret and two spindles both spindles have a rotary C axis. The Doosan Lynx 2100 LSY has a Y axis the clues in the title.
Most impressive of all is the 24 station turret which means you can be more tooled up than Arnold Schwarzenegger on his birthday.
Loads of driven tools.
There are half stations so you can get special holders that cover two stations.
The other option is to space the tools out like a twelve station turret.
I mean these tools are like elephants in a fuckin lift meaning you don’t have much clearance.
You need to look out for the tool below if you do decide to cram more tools in. If you know what it’s like to run out of tool stations then you won’t mind compromising a bit.
Congratulations Mr and Mrs Doosan on the Doosan Lynx 2100 LSY, it might be a compromise but it works well.
Fanuc Speed Amnesia
Why can’t a Fanuc control remember the speed.
Age old problem, you try to start the spindle in manual and it sits there fuckin laughing at you. So you have to go into MDI and start the spindle or just give it a speed before you can manually start any of the two spindles.
Speed amnesia so bloody annoying, come on girls give us a break. Logically if you have to start the spindle in MDI is there really any point of a manual spindle on off button. Mmmmm.
Icons I hate Icons
I can never remember what all the buttons are on these machines. What chance has your new apprentice who’s only experience of working a machine was in Costas
Anyway I have a labelling machine so I stuck em everywhere. Does it really cost that much money to have different buttons on a machine for an English speaking country than say a French one?
I could sell Doosan my labelling machine, maybe that’s the solution.
Using U and W on a CNC Lathe
On a CNC machining centre incremental and absolute are modal. That means when one is active it stays active until you programme the other.
Now on a CNC Lathe it’s different. You just change your axis to U or W. You can remember this by its position in the alphabet UVW correspond to XYZ .
What this means is that you have U instead of X and W instead of Z. Oh and if you have a Y axis you can use V.
This can make programming easier if the drawing is dimensioned incrementally.
Click for Classroom Training
This is a nice convenient 10mm. If it was 10.312 then you would have to do the arithmetic in order to use absolute.
You can even mix incremental and absolute in the same block. Look at this example.
This is it with W
Got to be honest I don’t use incremental that much in turning but I reckon this is a really good use for it.
If you have a slight taper in the part and you want to programme it out. This makes a really simple way.
Onsite Machine Training (Fanuc Haas Heidenhain Mazak)
It is also much less prone to error. You can put it back to zero for the next time if you want.
Changing the X value can be dodgy.
So there you have it Using U and W on a CNC Lathe
Just one other thing.
DON’T FORGET
The U figure is a diameter not a radius.
So in the example above the diameter is increasing by .02 (U.02)
Mazak Training
G94 Facing Cycle CNC Turning
G94 Facing Cycle CNC Turning. Facing on a CNC Lathe is no big deal. You just call out the tool, start the spindle, rapid to the part n face the job.
But then what do you do when you get to the end of the batch of work and find you have got some parts with extra metal on the lengths.
Now you need to add a lot of extra code. This takes a while and it’s easy to make a mistake.
So enter our Knight in Shining Armour
G94
This is how it looks for the first cut
So if you got into the habit of using G94 Facing Cycle CNC Turning.
Oh just one other thing
It remembers.
Interested in classroom CNC training courses?
co*****@***************re.com
Category : Beginners
CNC beginners guide (using Single Block)
CNC beginners guide
This article CNC beginners guide, is about Single Block and how it is used.
When you write a CNC programme it will consist of blocks of programme.
What is meant by a block?
Well it’s everything until the control sees a semicolon ;
If your not sure what a semi colon is it’s when you have had an operation to remove half your large intestine.
The semicolon is called an end of block or EOB
CNC beginners guide
Try not to confuse this with a line of code.
Depending on how your screen is set out a block could be more than one line. The control reads everything until it sees the semicolon or EOB (End of block).
In most cases and on most controls it does not matter what order the code is in. The main reason to follow a set pattern for your code is to make it easy to read.
Try to always put things in the same order.
In one block of code you can have loads of stuff.
You could write:
G0 X50. Y50. S1500 M3;
But if you wanted you could put the S1500 M3 on a different line.
When doing this, think about why you might want to do it. For example you may want to get the tool ready to use before switching on the spindle or the coolant. This saves the excitement of the spindle whizzing round when proving the programme.
Oh yes and you could get fuckin soaked.
Most of this applies when you first test your programme. This is when we use single block.
The Switch
To run a programme in Single Block we have to throw a switch.
CNC beginners guide
This can be a normal Single Block switch or a button or a soft key. Read the article below to learn how to prove out your CNC programme in Single block.
Read this if you don’t know how to prove out a CNC programme.
Once single block is enable the machine will do exactly what it says on the tin.
It will run that block and wait for its next command like a good doggy.
The beauty of this is you only need to think about one block.
Now I don’t want to appear sexist at this point but I recon if my wife were a CNC Operator she wouldn’t need single block. Not only can she do two things at once, which I can’t, but my wife also has an uncanny knack of knowing what’s going to happen next too.
For those with no extrasensory powers just switch on the fuckin single block.
If you turn single block off the machine will still stop at the end of it’s current block and wait for another press of the CYCLE START button to carry on.
Also when you first turn single block on it will stop at the end of the block it is executing.
CNC beginners guide
Those of you who read my articles will know that I love these old Matsuura machines (they make me feel young again).
You know when you’re getting old when you keep asking complete strangers “how old do you think I am”
I did it in Barwell the other day. The woman in the Coop said “piss off you silly old bastard”
What No Telly Screen
Anyway these machines have a one line display so you have to step through to read each line. You can only see little bits of code.
I once input a whole programme into one of these controls not realising I had no end of blocks .
(From now on I ‘m not saying fuck in my articles, I will refer to it as the F word like these posh people on the telly)
On this occasion I said the F word after taking about an hour trying to realise why the programme wouldn’t work.
The whole program was in one block!!!
Don’t mix your G Codes
(here is a nice way to make a John Collins if your bored with this CNC Shit)
You can even make this with non alcoholic Gin. Yes it’s true (non alcoholic gin) my wife bought a bottle the other day. Now I happily went along with this scenario till I found out it was fourteen quid a fuckin bottle.
Absolutely no way, no hang over, no phone call from your mate saying you shit in his cat tray. No no none of that, honestly I give up.
Let’s continue with this CNC beginners guide to CNC programming.
In one block of CNC code you can only have G codes that belong to the same group. I’ll tell you about this in another article when I can be bothered to do it. Anyway it’s easy, they can’t argue with one another. You can’t put G1 and G0 on the same line for example because they are in the same group.
You can’t say feed and rapid in the same line. That would be stupid.
Obviously you can’t repeat things like having two speeds in the same block.
G0 S1200 X50. Y50. S2000;
I don’t think anyone who reads my articles is that stupid….. Except for that bloke in Bolton, but I think he took up plumbing in the end.
Heidenhain
If you have a Heidenhain control the single block works the same. You select Full Run or Single Block
CNC beginners guide
You don’t hear me criticise Heidenhain very often cos I love em. Brace yourselves cos I’m about to.
Those bloody icons.
They all look the same. Every time I come back to working on Heidenhain I can never remember which is which.
I sometimes suggest making little sticky labels to go underneath to identify them.
This one will do wonders for your relationship with the guy on nights.
Before You Go A Few Question about Single Block
  1. What about a tool change?
  2. What about a canned cycle?
  3. What is the meaning of life?
Ok the last one is easy. Question 3 ….. the meaning of life is 42
Right, Now the Difficult Ones.
Your tool change M06 is probably aliased to a macro. This means that a programme is running in the background that you can’t see. Single block may well be inhibited. This means one press of the CYCLE START button will do the tool change. Sometimes however single block works. In this case it will take loads of presses to get through the tool change. Just be patient.
This is the sort of thing that’s running in the background.
CNC beginners guide
I won’t go too much into this, after all it is a CNC beginners guide.
Canned cycles depend on parameter settings. It will normally be one press to rapid to the tool down. Then one press to drill the hole. It may or may not need another press to bring the drill out of the hole.
The exception is G84 Tapping Cycle. You definitely wouldn’t want single block to work on this. Imagine the tap gets to the bottom of the hole and sits there waiting for a push of the button.
Sometimes feedhold is inhibited too in a canned cycle.
Hope you enjoyed this CNC beginners guide
Edgecam training
Category : Fanuc Turn
What to do Next?
Correct
IncorrectG76 threading start point
Don’t say I didn’t warn you.
G0 X21. Z3.
G97 S1200 M3
G76 P010060 Q20 R.02
This thread has a core diameter of 16.96 (X16.93) the thread depth is 1.535 (P1535).
Wrong as Below
G0 X19.95 Z3.
Well now’s the time.
G0 X21. Z3.
G97 S1200 M3
2.5 x 1200 = 3000
Strange Behaviour
Maybe you had a pitch error.
G0 X21. Z3.
G97 S2400 M3
2.5 x 2400 = 6000
Eat more fish.
You know that old book that you use to prop  the door open.
