Day: October 12, 2026
G94 Facing Cycle CNC Turning
G94 Facing Cycle CNC Turning. Facing on a CNC Lathe is no big deal. You just call out the tool, start the spindle, rapid to the part n face the job.
But then what do you do when you get to the end of the batch of work and find you have got some parts with extra metal on the lengths.
Now you need to add a lot of extra code. This takes a while and it’s easy to make a mistake.
So enter our Knight in Shining Armour
G94
This is how it looks for the first cut
So if you got into the habit of usingĀ G94 Facing Cycle CNC Turning.
Oh just one other thing
It remembers.
Interested in classroom CNC training courses?
co*****@***************re.com
Using U and W on a CNC Lathe
On a CNC machining centre incremental and absolute are modal. That means when one is active it stays active until you programme the other.
Now on a CNC Lathe it’s different. You just change your axis to U or W. You can remember this by its position in the alphabet UVW correspond to XYZ .
What this means is that you have U instead of X and W instead of Z. Oh and if you have a Y axis you can use V.
This can make programming easier if the drawing is dimensioned incrementally.
Click for Classroom Training
This is a nice convenient 10mm. If it was 10.312 then you would have to do the arithmetic in order to use absolute.
You can even mix incremental and absolute in the same block. Look at this example.
This is it with W
Got to be honest I don’t use incremental that much in turning but I reckon this is a really good use for it.
If you have a slight taper in the part and you want to programme it out. This makes a really simple way.
Onsite Machine Training (Fanuc Haas Heidenhain Mazak)
It is also much less prone to error. You can put it back to zero for the next time if you want.
Changing the X value can be dodgy.
So there you have itĀ Using U and W on a CNC Lathe
Just one other thing.
DON’T FORGET
The U figure is a diameter not a radius.
So in the example above the diameter is increasing by .02 (U.02)
Mazak Training
