Month: March 2025
CNC Machine Operation
Category : New Stuff
CNC Machine Operation: A Comprehensive Guide
CNC (Computer Numerical Control) machine operation is a crucial skill in modern manufacturing.
It allows for precise and automated production of complex components.
Whether you are new to CNC machining or looking to refine your skills, understanding the fundamentals of CNC machine operation is essential.
Onsite Training Enquiry
Classroom courses
Ring David: 07834 858 407
What is CNC Machine Operation?
CNC machine operation involves controlling CNC equipment to cut, drill, mill, and shape materials, mainly  metals.
Also plastics, and many other materials can be machined.
The process is guided by computer-generated instructions, commonly referred to as G-code and M-code
These codes direct the machine’s movements and actions with exteme accuracy.
Key Components of CNC Machine Operation
  1. Understanding G-Code and M-Code
    • The G-codes controls the movements and functions of the machine (e.g., positioning and cutting).
    • The M-codes handle auxiliary on off functions like coolant control and tool changes.
  2. Machine Setup
    • Loading setting and securing the workpiece to be made.
    • Installing and measuring the cutting tools.
    • Setting machines datum coordinates.
  3. Tool path Programming
    • Sometimes using CAD/CAM software to design and generate tool paths.
    • Optimising cutting speeds and feed rates for efficiency.
  4. Operating the CNC Machine
    • Running simulations with graphics to verify the program before execution.
    • Program test and prove out.
    • Executing machining operations while monitoring tool performance.
    • Adjusting offsets as needed for optimal results.
    • Monitoring tool life and wear.
CNC Machine Courses
Learn CNC Programming & Machining
CNC Machine Courses, are you looking to enhance your skills in CNC machining?
These CNC machine courses are designed for both beginners and experienced machinists. Students who want to master CNC programming, setting and operating techniques.
CNC Machine Courses
With hands-on training using real CNC machines, the courses provide the knowledge and practical experience needed to succeed in the industry.
CNC Turning Course
Why Take a CNC Machine Course?
CNC (Computer Numerical Control) machining is a crucial skill in industries like aerospace, automotive, and medical manufacturing. By learning CNC programming and machine operation, you can:
•Boost your career opportunities in precision engineering.
•Improve your machining skills for better efficiency and accuracy.
•Stay competitive in an evolving manufacturing industry.
What You Will Learn in Our CNC Machine Courses
Our courses are designed to be practical and industry-relevant, covering:
✅ CNC Programming: Learn G-code and M-code to control CNC machines.
✅ CNC Milling & Turning: Hands-on operating real CNC machines.
✅ Advanced Mill-Turn Techniques: Learn multi-axis machining for complex parts.
✅ CAM Software Training: Learn to use Edgecam software for CNC programming.
✅ Precision Measurement: We offer CMM (Coordinate Measuring Machines) training too.
Course Details
Duration: 2 or 3 day course
Skill Level: Beginner to advanced
Price: Two days £600 plus VAT  Three days £900 plus VAT
Fanuc Parameters 3101 Clear Buffer
Category : Fanuc Parameters
Fanuc Parameters, does it really annoy you when you swap screens on your Fanuc control and you loose whatever you just typed in?
Well it’s OK, no more sleepless nights. It doesn’t have to be that way thanks to Parameter 3101
Bits n Bobs
Messing With Fanuc Parameters Can Be Fatal!!!!!
To change a Fanuc Parameter you need to go to the setting screen in MDI. Now put a 1 in the parameter write box.
Now We Can Get This Party Started
This is how Parameter 3101 looks in the Fanuc Manual
Fanuc Parameters
It’s Fanuc Parameters 3101 bit 1
When this is a zero. If you change screens your code is lost.
Fanuc Parameter
Now here’s one I prepared before the show
Vegan Homemade Portabello Mushroom Black Bean Burger with Fries
This is how it works when you change the Fanuc Parameters 3101 to 1
Fanuc Parameter
The Dreaded Options Fanuc Parameters
I once bought a new car and naively thought it would be just like the one I saw advertised on the telly.
On some cars everything is a fuckin option. Well unfortunately it can be a bit like that with CNC controls.
It’s not all doom and gloom, a lot of the things you can’t get the control to do are just settings and parameters.
Keep reading my articles and you’ll find out what they are.
All this boring shit really does have a point to it.
If you have a lot of similar controls in your company it’s a good idea to try n set them all up the same way.
Don’t get me started on Haas.
OK You Started It
In my opinion by far the greatest thing about a Haas control is the program restart.
Guess what: most people have it turned off. I would liken it to switching off your central heating in the winter and making a fire with some sticks in the middle of the room.
You can restart anywhere in the program and the machine magically gets its digital shit together.
It gets the right tool, sorts out all the M codes, just about everything. Try it today it’s amazing.
Setting 36 Turns it On
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
If you aint got a camera then you must have a piece of paper.
Offset Keylock Fanuc Parameter 3291
Offset Keylock Fanuc Parameter, before you change this you will need to go to the setting screen in MDI.
From here you can allow yourself to alter parameters.
Today we are going to change the parameter that stops operators from altering wear offsets.
Apprentices should be inquisitive it’s normal. We want them to experiment and learn by making mistakes.
Mmmm sounds great but and there is a big but. By a big but I don’t mean a big arse I mean but with one t.
I once trained an apprentice on a Haas VF1. He picked it all up really fast. When I revisited he was really excited to show me how  he’d learned to alter parameters all over the place.
It was real scary stuff he thought it was fuckin space invaders or some computer game.
Game Over
Game over on a CNC machine means you just buried a tool in a part and caused £5000 worth of damaged or somebody just died for real.
The key switch is now needed.
Parameter 3291 will stop operators from changing the tool wear offsets. It requires use of a physical key to unlock them.
So you just pull the key out and depending how the machine is setup It’s like you just made him wear boxing gloves.
So in Parameter 3291 you can set bit 0# (WPT) to a 0 and you will need to use the key to edit offsets.
By the way it wouldn’t have stopped my rogue apprentice I think he’s the MD now.
Bits n Bobs
3101 Clear Screen
That’s it away you go, Offset Keylock Fanuc Parameter
Retain Geometry Fanuc Parameter 5003
Retain Geometry Fanuc Parameter 5003, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops your tool offset from being dropped when you press reset.
Parameter 5003 will stop that annoying thing where you activate a tool offset and then press reset and it clears.
If you have a Mazak machine you will know that if you index to tool 6 the offset will be instantly activated. This means if you are on a CNC Lathe you can just move the tool to a 50mm diameter and turn away. Providing the tool has been measured the size will be correct.
You are probably used to the tool not being active if you use a Fanuc control but help is at hand.
With this parameter 5003 set to 1
You input T0101 in MDI and that activates tool number one’s offset. Your position display is now correct (allowing for tool geometry).
If you now look at the ABSOLUTE position display and press reset it will not change. If it changes then the machine is more than likely dropping the tool geometry.
#6  (LVK) Set to 1 not cleared on reset
#7 (TGC) Set to 1 not cleared on reset
Bits n Bobs
3101 Clear Screen
