Unlock Programs Fanuc Parameter 3202
Category : Fanuc
Unlock Programs Fanuc Parameter, first of all you’ll need to go to the setting screen and change the parameter write box to a 1.
Programs 9000 to 9999 are used for things like probing, tool-change and all sorts of other important things.
So beware back em up ASAP.
These programs along with 8000 to 8999 can be locked so no one can mess with them.
3202 if NE9 is 1 then programs 9000 to 9999 can’t be deleted or edited.
3202 if NE8 is 1 then programs 8000 to 8999 can’t be deleted or edited.
 Unlock Programs Fanuc ParameterOnce you’ve finished don’t forget to lock the 9000 programs back up and turn off that parameter write switch.
Unlock Programs Fanuc Parameter 3201
So you might want to use this yourself if you have a sub program in your machine that you use quite often and you don’t want anyone messing with it.
Don’t forget when this parameter is set to stop you editing the programs  you can’t read them in and out either. That means you can’t back them up until you unlock them.
1300 Stops over travel alarm
3101 Clear Screen
3203 Clear MDI Screen
11 Comments
Bassem Hanna
January 4, 2021 at 12:14 pm
Hi dear
I have CNC Machine Center control Fanuq io and I have problem is cnc lock this lock be any month how to unlock or delete the file lock
Pandi Mugunthan S
December 20, 2021 at 3:49 pm
Hello sir,
I have some problem with fanuc series Oi-tf. I can’t insert new program. Below message repeated show on screen “write protect”. I’ll check parameter write switch enabled, and also check 3210 password protect is empty. How can solve this problem
    December 20, 2021 at 4:20 pm
    What about your edit key. Check that the edit key on the control panel is not locked
PANDI MUGUNTHAN
May 14, 2022 at 3:31 pm
How to block program insertion in fanuc series Oi-tf
    May 19, 2022 at 7:09 pm
    Not sure what you mean email me and i will try n help
James
January 11, 2023 at 3:28 am
hello
i have problem in insert and delete the programm.
when i try to insert or delete or edit, ” Write Protect” comes out and
i checked the key on the panel. its locked. it doesnt move to unlock.
    January 11, 2023 at 3:08 pm
    It is the key that is doing it. You need to replace it
Mahesh Ranaware
August 7, 2023 at 7:29 am
A specific program no Ex. O3025 is available in list. But message “program not available” comes when searching in BG EDIT mode
    August 24, 2023 at 2:08 pm
    Not sure on that one
Lawrence
January 23, 2024 at 1:10 pm
hi i am getting an error when i try to run a program SR5010 end of record. Please assist
    March 5, 2024 at 5:19 pm
    You probably have no EOB (;) at the end of the program
