Fanuc CNC Parameter 14852, Fixed Form Character Length
Fanuc CNC controls include hundreds of parameters that quietly shape how the control behaves. One that often goes unnoticed—but can make a real difference to usability and program readability—is Fanuc CNC Parameter 14852, Bit 4.
This article explains what parameter 14852 bit 4 does, when you might want to change it, and what to watch out for before making any adjustments.
Shibaura Training
What Is Fanuc Parameter 14852 Bit 4?
Parameter 14852, Bit 4 controls the number of characters that can be displayed or entered in each fixed form field on supported Fanuc CNC controls.
When this bit is enabled, the control allows more characters per fixed form, effectively expanding the usable text length within those fields.
In practical terms, this means:
  • Longer text entries are possible
  • Descriptions and identifiers are less likely to be truncated
  • Fixed-form screens become more informative and easier to interpret
The exact behaviour can vary slightly depending on the Fanuc control series and software version, but the purpose of Bit 4 remains the same: increase character capacity per fixed form.
What Are Fixed Forms on a Fanuc Control?
Fixed forms are structured input screens used to quickly create program.
Typical forms:
  • Start of program
  • Call a tool
  • Call a cycle
  • End a program
I means the programmer does not need to memorise loads of G and M codes. The structures is created.
For more details on Fanuc macro variables and fixed forms, check our Fanuc Parameters that cover advanced control functions.
Why Increase the Number of Characters per Fixed Form?
Enabling Parameter 14852 Bit 4 can be particularly useful in the following situations:
1. Improved Program and Process Clarity
Longer character limits allow more information to be added in one keystroke.
2. Better Operator Understanding
Operators can see more meaningful descriptions without abbreviations, reducing the risk of misunderstandings on the shop floor.
Parameter 3109 Display W and G
People who know me know just how boring I am. Today I’m going to confirm this by getting very excited about this parameter.
Parameter 3109 bit 1 (#1) DWT will make the display of wear offsets loose that confusing W and G.
Stay here I’ll explain more.
Parameter 3109, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops the offset page displaying G and W.
Bit 1 (#1) DWT make this a 1 to stop this being displayed.
So when you change this parameter you won’t see a W beside the offset number in the wear screen. You also won’t see the G beside the tool number in the geometry screen.
I know for a fact when training people that this really confuses them. Especially the the G on the geometry screen.
This is it before with the W
Parameter 3109
This is it with the parameter change good old fashioned numbers.
Parameter 3109
As in the book
Parameter 3109
Bits n Bobs
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
Do yourself a favour take a picture of the screen before you change a parameter. If you ain’t got a camera then you must have a piece of paper.
Fanuc Parameter Write Switch
Call David: 07834 858 407
Some more interesting parameters
Taking a Screen Shot Fanuc Control
To take a Screen Shot Fanuc, you will need to have either a data card installed or a USB
Screen Shot Fanuc
MDI
In MDI I/O channel needs to be set (4) data card or (17) memory stick
Screen Shot Fanuc
Stick the Card in (or the stick)
Press and hold the shift key for about 10 seconds. You will see the clock stop. That’s how you know it worked. Time will stand still at this point and all the people around you will appear static.
Try not to panic, the world didn’t end. Your control just needs to ponder a while and think about what you just did.
Stop The Clock
Once it’s done your clock wil start again (phew).
Screen Shot Fanuc
Then press CARDScreen Shot Fanuc
Screen will show what is on the data card
Screen Shot Fanuc
The BMP files are your screen shots. You can then view them on your laptop or PC.
Now I know you are saying “what is the fuckin is the use of that”
Well It’s just so that I can show off my knowledge.
Parameter
If this does  not work then you may need to alter parameter 3301 bit zero and bit 7 need to be 1
Should look like this to make it work.
Screen Shot Fanuc
A good use is when you are changing parameters. There’s nothing worse than changing a parameter and trashing a £100,000 machine. Help is at hand, luckily you did a screen shot before you changed the parameter and you can view it and change it back.
With this parameter it wont work because you need to switch it on!!!
Good luck with the massive dent in the guarding and the bent tool. No screen shot will fix that.
Screen capture Fanuc, thanks for reading.
Overtravel Axis Fanuc Parameter 1300
Over-travel alarm, make this a thing of the past with this parameter
You first need to go to the setting screen in MDI.and put a 1 in the parameter write box.
Today we are going to change the parameter that stops the machine generating an alarm when it gets to the end of travel.
End Of Travel Alarm  Fanuc Parameter
Now I need to start by apologising to all the lovely people at Fanuc. All the years I have moaned and moaned about the fact that when you get to the end of the machine stroke on a Fanuc control you get a stupid alarm.
Actually I have been totally wrong and I offer my sincere apologies to all who have been hurt by my nasty comments about this.
If you set parameter 1300 BIT 1 (NAL) to a 1 then you do not get an alarm when you travel to the end of the machine stroke.
Bits n Bobs
Other Parameters You may Want to Change
3202 Unlock Program 9000 to 9999 and 8000 to 8999 to Edit
This guy has more CNC Manuals than you can shake a stick at.
Or take a screen shot.
