Fanuc Parameter Write Switch
Category : Fanuc
Some more interesting parameters
1 Comment
Pascal Siegwart
October 2, 2020 at 9:52 amHi David, my Name is Pascal and i live in Germany. So.. i have a big Problem with an Fanuc 32iB.
How can i fix the issue “PS5541 Basic Software illegal”.
The old Control Unit doesnt work anymore ,so i copied everything on a new control unit with the same options an reinstalled in the machine.
Is there a Parameter a have to set??
