Cutting Feed-Rate 0% Fanuc Parameter 1401
Category : Fanuc Fanuc Parameters
Unlock Programs Fanuc Parameter, first of all you’ll need to go to the setting screen and change the parameter write box to a 1.
Cutting Feed-Rate 0% No Movement
When you set you feed-rate override to 0% the machine will not move. Some operators like to use this when proving out a program
All you need to do is make Bit 4 of parameter 1401 into a 1 and the machine will not move even in rapid.
Bits n Bobs
