Overtravel Axis Fanuc Parameter 1300
Category : Fanuc Parameters
Over-travel alarm, make this a thing of the past with this parameter
You first need to go to the setting screen in MDI.and put a 1 in the parameter write box.
Today we are going to change the parameter that stops the machine generating an alarm when it gets to the end of travel.
End Of Travel Alarm Fanuc Parameter
Now I need to start by apologising to all the lovely people at Fanuc. All the years I have moaned and moaned about the fact that when you get to the end of the machine stroke on a Fanuc control you get a stupid alarm.
Actually I have been totally wrong and I offer my sincere apologies to all who have been hurt by my nasty comments about this.
If you set parameter 1300 BIT 1 (NAL) to a 1 then you do not get an alarm when you travel to the end of the machine stroke.
Bits n Bobs
Other Parameters You may Want to Change
3202 Unlock Program 9000 to 9999 and 8000 to 8999 to Edit
This guy has more CNC Manuals than you can shake a stick at.
