Month: May 2022
Surface Finish CNC Turning
Category : Beginners
CNC Turning Surface Finish
Ever wondered what feed rate is best to give you a particular CNC Turning surface finish? Or do you just guess?
Well look no further. From now on you’ll be able to work out what feed-rate will give you the surface finish you require when CNC Turning.
Oh and there’s a formula where you can work out what surface finish you’re going to achieve without a fortune teller.
We are going to use um Ra.
The um stands for microns.
The Ra stands for roughness average.
Here is a full explanation if you really want to know.
CNC Turning
You can buy a flat block like the one above which you can use as a comparison to see what surface finish you’re getting.
The section above is for CNC Turning surface finishes.
So you can already see that 12.5 is like a plowed field and .4 is like a babies arse (as my father used to say) .
So if you’re fixing a fence post then 12.5 might be OK.
Surface Finish The Dreaded Formula
surface finish
First of all what feed rate would you need to obtain a certain CNC Turning surface finish.
CNC Turning
Now what if you’re already machining the part. That means you know the feed rate. What surface finish will you get?
CNC Turning
So………….
Our tip radius is .8mm
CNC Turning
We want to achieve a 3.2 um Ra  CNC Turning surface finish
CNC Turning
So here’s the formula.
CNC Turning
Let’s do this bit first.
https://www.youtube.com/watch?v=vWQgBtlUUMM&ab_channel=MotoMadness
8 x .8 x 3.2 = 20.48
Now let’s divide it by 1000
20.48 / 1000 = .02048
Now lets square root the answer.
Square root of .02048 = .143
So the feed-rate you need is F.143
CNC Turning
OK… You Came Back. You Ready to Carry On?
Anyway let’s see how you do it backwards.
surface finish
So imagine you had been turning these imaginary bits with a .8mm radius insert at a feed-rate of .143 (F.143)
First of all square the feed rate .143 x .143 = .020449
CNC Turning
Now do the bottom bit 8 x .8 = 6.4
surface finish
Now divide the top by the bottom.
surface finish
.020449 / 6.4 = 0.00319515625
Then simply multiply this by 1000
0.00319515625 x 1000 =3.19515625 (3.2)
That’s 3.2 to you
surface finish
A surface finish comparator
It worked backwards!!! Phew what a relief.
Surface Finish, Now Let’s Think About This
So to get a 3.2 finish with a .8 tip radius you would need a feed rate of .14
Now let’s do the same calculation with a .4 radius tip.
surface finish
Calculate surface finish
So did you work it out?
Here’s one I prepared earlier.
The answer is .101
And if you can be bothered to work it out with a 1.2 radius tip.
The answer is .175
.4    =  .101
.8    =  .143
1.2  =  .175
Interesting
So as the tip radius gets bigger you get to increase the feed rate!
Oh yea we do CNC Training too not to mention Classroom Training.
G82 Drilling Program Example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
This is because of the G98.
Haas G82 example
G83 Peck Drilling Program
Category : Beginners Fanuc
G83 Peck Drilling Program Example
G83 Peck Drilling Program, G83 is a deep hole peck drilling canned cycle.
Cycle G83 drills holes breaks up the chips as it goes. It fully retracts from the hole after each peck.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
The G83 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)
The Q2. tells the machine to drill the hole in 2mm steps. After each step it retracts to the surface of the part.
This allows all the chips or powder to come out of the hole after each cut. It also allows the drill to cool.
G83 Drilling Program Example
More G83 stuff from Haas
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G73 Peck Drilling Program Example
The G73 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)
G73 Drilling Example
Haas G73 example
CNC Tooling Spot Drill Centre Drill
Category : Tooling Useful Stuff
CNC Tooling
Spot Drill Centre Drill Spot The Difference
Now if you already know then:
GET SOME WORK DONE
You don’t need to waste your time reading all this bollocks.
CNC Tooling
Spot The Difference
Now Let’s Talk About Centre Drills
They come in various sizes designated by a BS number.
BS1 to BS6
BS6 being big.
Anyway BS1 is 1/8″ diameter and BS6 weighs in at a massive 5/8″and a government health warning.
CNC Tooling
There is only one reason why you would use a centre drill and that is if you require clearance for a centre.
CNC Tooling
If you have a long part and you wish to support it with a tailstock then you need clearance for the point of the centre.
If you used a spot drill the point would touch before the sides.
CNC Tooling
If the part is going to be ground then it will most likely be held between two centres.
CNC Tooling
CNC Tooling
Now the big problem with centre drills is that in order to clear the point of your centre they have to have that little point (pilot) on the end.
And these little bastard break off. Oh and if your turret on your lathe is not aligned properly, you got no chance.
A BS1 centre drill has a pilot that’s just .64mm in diameter!!!!!
As soon as it makes contact you’ll see it wandering aimlessly around like a drunk teenager in Birmingham on a Saturday night.
Carry on now and it will snap off and if your having a shit day it will lodge itself in the part. You’ll need a neutron bomb to get it out.
So let’s move on and stop talking about these annoying little beasts.
Rule Number 1 only use them if you have to.
Rule Number 2 only use them if you really have to.
Rule Number 3 only use them if you really really have to.
CNC Tooling Spot Drills
Now these again come in various sizes a much bigger range from 2mm to 20mm and you get a 120 degree point or a 90 degree point.
B & Q are great for all kinds of DIY products (free add). But whatever you do don’t use the drills for serious engineering.
CNC Tooling
Shelves, building kitchen units, making the misses a Jewelry Box. They are fantastic, but not if you want to be a serious grown up engineer and play with the big boys.
So lets bin all the shitty cheap HSS drills and buy some decent stuff. Oh by the way don’t blame me if your boss says “dream on”
Why Am I Saying This
Well because modern drills are amazing.
They hold accurate size.
Don’t need a spot drill.
Really super fast.
Last longer.
Oh did I mention they are bloody expensive.
Centre Drill
Now with HSS drills you can buy thousands of em for a fiver and still have change to buy Robbie Williams concert tickets.
Authors Note
Please don’t read any of my articles if you like Robbie Williams, it means your a twat. Now Robin Williams, that’s totally different. Don’t you just love “Mrs Doubtfire” my favourite film.
Drills Drills More About Drills
But good quality modern drills are expensive. The good news is they easily pay for themselves. You need to treat them carefully because if they are carbide then they can chip and smash easily. You know in that James Bond movie where he is disarming a nuclear bomb? Well treat them like that and you’ll be just fine.
CNC Tooling
Anyway that’s not what this article is about.
CNC Tooling Centre Drill
A centre drill has a 60 degree point which is not good to start a drill. With a spot drill you can get a 120 degree point which is roughly the same as your drill point so it gives the drill a great start.
The drill won’t wander but if you heed my advice and use a super duper new drill then it will drill perfectly without any spot drill.
Spot Drill Last
I would always  use good quality CNC Tooling.
Use a good quality modern drill and then use a 90 degree point spot drill after to chamfer your holes.
This means you can rapid the spot drill right into the hole and then feed in just a tiny amount to create the chamfer.
Spot Drills The Good Bit
You can deburr with a spot drill. Just program it to go around your shape and put a nice clean chamfer around you part.
CNC Tooling Conclusion Spot Drill Centre Drill
Always use good quality CNC Tooling
Use a centre drill only if you have to.
Make sure your turret is aligned on a CNC Lathe.
Centre drills are for centre locations on long or ground parts.
Centre drills are for grinding between centres
Spot drill can be same angle as drill.
Spot drill after drilling.
Use spot drills to deburr parts.
