And by the way never use the letter O it’s number zero
GO2 GO3 looks almost exactly the same as G02 G03. But your control will blow it’s mind and get real mad with you.
It will also do some really weird shit like trying to start a new program. Anyway just don’t do it.
If you want to know how to do this on your Heidenhain control you need to read this article.
Oh and please don’t call it interpolation as it annoys the shit out of me.
  • Linear interpolation is movement in a straight line.
  • Circular interpolation in moving in a circle.
  • Interpolation is movement.
  • CNC Training Centre Reviews
Which one of you bastards said interpolation?
Then your CNC controller magically creates your circle. You can programme any arc like this with one exception.
Do you know what it is?
Ok I will tell you later, it’s OK to not know. (Just means you are little thick).
Lets go back to school.
G02 G03
Let’s see what the control has to do to work out where the centre of the circle is.
It knows its current position and in your G3 line you tell it the end point and the radius you want.
G02 G03
G02 G03
Get yourself a pair of compasses and try it. It’s great fun.
G02 G03
That’s how the maths works.
Fuckin hell I give up.
g02 g03 lathe
G2 G3 No Pot of Gold
Your control will give you an alarm “End Point Not Found” which makes sense because it can’t find one. It’s like the pot of gold at the end of the rainbow.
G02 G03
Oh Before you Go More on G02 G03
You can do it but you would have to break it into two halves. I’m not going to explain anymore because this method is for wimps and peole who can’t be arsed to read my articles.
You know who you are, ordering Chicken Korma in an Indian Restaurant.
Well…… what follows is a full, blow your bollocks off, shit your pants the next day, vindaloo.
Did he say almost?
Well yes almost. You could programme forever and never bother about using I and J with G02 G03. So just go off and watch some porn for awhile and I will explain to the real programmers when you can use it.
In the old days I and J was the only way to programme an arc. You would tell the control where the centre of the circle is and the endpoint. This is cumbersome and a bit tricky. That’s why I’m not telling you about it.
Anyway one really good simple way to use I and J is for a full circle. Oh and it’s bloody easy. That is once I’ve explained it to you.
Click here for more info on full circle
When I was a boy hundreds of years ago I had a toy called a Spiro Graph.
Spirograph those were the days
It consisted of a series of plastic gears. You stuck your pen in a hole in the gear and rotated it around another gear. With a bit of practice you could make some really nice pictures. Kept us happy for hours. The crime rate dropped dramatically in my area when these things came out.
In Comes I and J
G02 G03
So some clever bloke thought fucks this I’ll invent I and J.
If we use I and J there are four options as above.
  • G3 I-20.
  • G3 I20.
  • G3 J20.
  • G3 J-20.
And that’s it.
G02 G03
So these are the four options
G02 G03
So there you have a fantastic way to programme a full circle without having to break it down into two halves or be clever like a newsreader or some twat off mastermind.
Why do you only need the I and not X and Y Dave?
For fucks sake don’t call me Dave my name is David.
I had this really nice guy phone me from Africa the other day. He explained to me that he needed to get his inheritance of 10 million pounds out of England and if I helped him he would give me £20,000. All I had to do was give him all my bank and credit card details. Oh and a small one off payment of £1000.
Of course I agreed, what a bargain. Just as I was about to do this the cheeky bastard called me Dave.
I immediately told him to fuck off. I just hate being called Dave.
I gave him my 96 year old mothers phone number because I thought at least she can benefit from it all. Her name is Mary so he couldn’t shorten that. She only has £1200 in savings so it would be doing her a massive favour.
Explanation
You don’t need to re-state the X  and Y because you are already at the endpoint
Siemens Sinumerik
Fanuc G82
Call David: 07834 858 407
G Code Groups What Use Are They?
G Code Groups, every G code is in a group and I remember looking at G codes for years thinking why on earth do they do that?
I thought it was just to satisfy the geeks, it gave them more bullshit to talk about and confuse the shit out of me.
Anyway now I’m all grown up, I know exactly why G Codes are in groups.
The good news is today I am going to tell you why and….. I am going to give you a practical example.
(Be sure to read on for a free cheese on toast recipe)
Here is a list of G codes and the groups that they are in
G Code
G Code List with Groups
Hass G Code Groups do vary a little.
Now I know this is boring but please try to keep focused it gets exciting soon honestly.
If you are loosing the will to live already then off you go, this video is amazing.
I know it’s only two of us now but I will carry on. I wrote this article a bit back about macro for the over 18’s.
Fanuc G83
More Heidenhain
Drawing Datum
On  a Fanuc control it’s a G code usually G54 although as standard you have six of these.
G54 G55 G56 G57 G58 G59
Zero Return
X 0.000
Y 0.000
Z 0.000
What about Z you say?
Mazak Work Offsets
CNC Training Mazak
Toshiba BMC 800 Work Offsets
Is Six Enough?
Right Let’s Wrap This Up
So now if we program
Because G54 is Modal.
Digital Readout
Toshiba Tosnuc CNC Training
G57 H901
G0 X0 Y0
So Where’s This All Going?
Now then think about this.
Don’t Just Plonk It Anywhere
Now when you program.
G0 G55 X0 Y0
By The Way
There’s More
Matsuura Training 500v
Lets Save Some Time
Mazak Training
Doesn’t matter either.
Work Offset G54 G55 G56
And…
Heidenhain
Bridgeport Interact 412
Heidenhain Training
This would call out offset 1.
Just zero the display.
How easy is that?
Heidenhain Training
Heidenhain Training
Heidenhain Training
So there you go from Heidenhain on a Bridgeport Machine to Matsuura MX520 with a Matsuura G-Tech 31i control. There are loads of different machines but the principle is always the same.
Call David 07834 858 407
