Doosan Access Tool Table Random Tool
Category : New Stuff Useful Stuff
Doosan Access Tool Table. Now you probably already know that when you have a random tool changer it’s hard to know which tool is which. You look round the side at your tool drum and the numbers make no sense.
Random Tool Changer That Sounds Dodgy
No it’s not dodgy it just confuses the shit out of any one who is not used to this type of machine. I means that the tool number you are using bears no relation to the tool numbers in your tool drum.
Confused? Well you should be by now.
The machine picks up a tool and swaps it with the tool in the spindle. It then puts that tool back where it go the last one from.
Why you may be asking. Well it obviously makes the tool change faster because the drum does not need to rotate. You can preload your tools by just adding a T number anywhere before your tool change. That means you next tool is ready. All the machine needs to do is swap em. Job done.
Now for me I can’t even remember if the wife told me to get a pint of milk or a pizza on my way home from work. Therefore keeping track of these tools is absolutely impossible.
Good News Doosan Access Tool Table
You don’t need to. Our clever little machine remembers it all even when it’s turned off.
Seek And Ye Shall Find
All you need to do is ask for a tool and the machine will get you the correct one. Just don’t look at the drum, promise me.
Looking at the drum is like being on a 100ft cliff and looking down. Just scares the fuck out of you.
Trust the machine it knows best.
For more CNC Training check us out
The Catch
But then one day you want an M6 tap and you see one in the tool drum.
How do you get it?
It’s number 20 in the tool drum and only the machine knows what that is.
Ok so we need it to tell us.
So to acces the tool table on a Doosan machine we first press this button.
You will then see this screen.
Press TOOL DATA
So here we have it P is the pot number (the position in the drum) and T is your tool number.
So if you wanted the tool that is in pot number 3 in the tool drum you would type M6 T20.
Here is how to do it if you don’t have a Doosan Machine.
Got a Haas? They have an even easier solution Read this
