Onsite Doosan CNC Training UK – Hands-On Courses
Onsite Doosan CNC Training UK – Expert Hands-On Courses at Your Facility
In the competitive UK manufacturing sector, your Doosan CNC machines are key assets for delivering precision turning, milling, and multi-axis work. But to get the absolute best performance from models like the Puma series lathes, Lynx compact turning centres, or DNM vertical machining centres, your operators and programmers need targeted, practical skills.
32 Five Star Reviews
That’s where CNC Training Centre excels: we provide onsite Doosan CNC training right on your shop floor – no travel, no lost production time, just real results tailored to your exact machines and workflows.
Why Onsite Doosan CNC Training Delivers Superior Value
Doosan machines (now known as DN Solutions) have earned a stellar reputation in the UK for their durability, high-speed capabilities, FANUC controls, and versatility across industries like aerospace, automotive, medical devices, and precision engineering.
Yet the biggest untapped gains often lie in operator expertise.
  • Zero production disruption – Training happens where your team already works, using your specific Doosan lathes, mills, or multi-tasking centres.
  • Hands-on with your reality – Practice on your actual fixtures, tooling, programs, and materials – far more effective than offsite or generic simulators.
  • Fully customised sessions – From foundational operator safety and setup to advanced Doosan programming training onsite, live tooling, Y-axis, sub-spindle ops, probing, and cycle time reductions.
  • Quick, measurable ROI – Teams apply new skills immediately, slashing scrap rates, shortening setups, minimising errors, and increasing output.
Investing in premium Doosan machine training onsite empowers your workforce to fully exploit the reliability and innovation built into every Puma, Lynx, or DNM model – helping you stay ahead in a skills-short UK market.
What Our Onsite Doosan CNC Training Includes
Every course is built around your Doosan lineup and production goals. Core topics typically cover:
  • Safe operation, daily checks, and preventive maintenance
  • Rapid, accurate setup and workholding strategies
  • G-code mastery plus conversational and Manual Guide i programming techniques
  • Toolpath optimisation for turning and milling efficiency
  • Advanced capabilities: live tooling integration, multi-axis machining, in-cycle probing
  • Common troubleshooting on Puma CNC training onsite, Lynx Doosan training, DNM machining centre training, and similar models
Delivered by seasoned instructor with extensive Doosan experience, our sessions provide industry-proven insights you can trust.
Ready to Maximise Your Doosan Investment?
Don’t let under-skilled operators hold back your high-performance Doosan CNC machines. With Doosan CNC training from CNC Training Centre, you’ll see faster setups, better part quality, reduced downtime, and a more capable team – all without anyone leaving your premises.
Your Doosan machines are built for greatness. Let’s ensure your team is too.
Expert onsite Doosan CNC training – practical, effective, delivered where it matters most.
How to Use FANUC Manual Guide i Engraving Doosan Lynx
FANUC Manual Guide i Engraving on a Doosan Lynx 300M
FANUC Manual Guide i engraving is one of those things that often looks more complicated than it really is.
Now I admit to having a few “issues” with Manual Guide i  but when it comes to engraving I have to admit it’s quire simple.
Not well explained, sorry I’m doing it again. Anyway once you get how it works and what it wants to know it’s easy
If you have a CNC lathe with a C axis and driven tooling, you can do much more than turn diameters and face components. You can mill flats, drill cross holes and engrave text directly onto the component.
Loads and loads of shit. So much fun without taking down your pants.
On the Doosan Lynx 300M, you can engrave on the front face of a component or wrap the engraving around its outside diameter. It can be straight across the front face or rotated around it.
This type of C-axis engraving is ideal for adding:
  • Part numbers
  • Batch numbers
  • Serial numbers
  • Company names
  • Material specifications
  • Inspection references
  • Simple identification marks
  • And the most common which is rude comments to make your mates laugh
Manual Guide i makes the process quite straightforward. You can create the engraving conversationally rather than calculating and programming every individual movement yourself.
FANUC describes Manual Guide i as a conversational programming system for turning, milling and combined machining applications. You can read more about its capabilities on the official FANUC Manual Guide i website.
Loading Tools on a Doosan DNM
There are several ways of Loading Tools on a Doosan DNM. The first is the most simple. Don’t forget this is random tool changer so it’s no good looking in the tool drum. Read this article first if you don’t understand how a random tool changer works.
Just call out the tool you want for example T6 M6 and then load your tool. Your tool has now become T6.
M45 To The Rescue
The other way of Loading Tools on a Doosan DNM is to use M45
Loading Tools on a Doosan DNM Access Tool Table
So to acces the tool table on a Doosan DNM press this button.
Doosan Tool Drum
This screen is displayed.
Press TOOL DATA button
This is your tool table that tells you where everything is in the Doosan Tool Drum.
This tells me that T20 (Too20) is in pocket 3 (P003).
Love It Or Leave It
From this screen you can decide what tools you want to keep and what tools you want to replace.
It’s a good idea to keep an actual list of what tools are in your machine.
If I wanted to use pocket three then call it in MDI tool 20 (M6 T20).
Doosan Tool Drum
Now you can load your tool, if the pocket is empty, or exchange it with this tool.
This button will release the tool if you are in a manual mode.
The tool can be heavy or stick in the spindle so be prepared for it to drop. It may be heavy so you could put a piece of wood under it to support i
From now on your tool will be tool 20 (T20).
Please don’t call it anything else because it will just ignore you.
Doosan Access Tool Table Random Tool
Doosan Access Tool Table. Now you probably already know that when you have a random tool changer it’s hard to know which tool is which. You look round the side at your tool drum and the numbers make no sense.
Random Tool Changer That Sounds Dodgy
No it’s not dodgy it just confuses the shit out of any one who is not used to this type of machine. I means that the tool number you are using bears no relation to the tool numbers in your tool drum.
Confused? Well you should be by now.
The machine picks up a tool and swaps it with the tool in the spindle. It then puts that tool back where it go the last one from.
Why you may be asking. Well it obviously makes the tool change faster because the drum does not need to rotate. You can preload your tools by just adding a T number anywhere before your tool change. That means you next tool is ready. All the machine needs to do is swap em. Job done.
Now for me I can’t even remember if the wife told me to get a pint of milk or a pizza on my way home from work. Therefore keeping track of these tools is absolutely impossible.
Good News Doosan Access Tool Table
You don’t need to. Our clever little machine remembers it all even when it’s turned off.
Seek And Ye Shall Find
All you need to do is ask for a tool and the machine will get you the correct one. Just don’t look at the drum, promise me.
Looking at the drum is like being on a 100ft cliff and looking down. Just scares the fuck out of you.
Trust the machine it knows best.
For more CNC Training check us out
The Catch
But then one day you want an M6 tap and you see one in the tool drum.
How do you get it?
It’s number 20 in the tool drum and only the machine knows what that is.
Ok so we need it to tell us.
So to acces the tool table on a Doosan machine we first press this button.
You will then see this screen.
Random Tool
Press TOOL DATA
So here we have it P is the pot number (the position in the drum) and T is your tool number.
So if you wanted the tool that is in pot number 3 in the tool drum you would type M6 T20.
Here is how to do it if you don’t have a Doosan Machine.
Got a Haas? They have an even easier solution Read this
