Using U and W on a CNC Lathe
On a CNC machining centre incremental and absolute are modal. That means when one is active it stays active until you programme the other.
Now on a CNC Lathe it’s different. You just change your axis to U or W. You can remember this by its position in the alphabet UVW correspond to XYZ .
What this means is that you have U instead of X and W instead of Z. Oh and if you have a Y axis you can use V.
This can make programming easier if the drawing is dimensioned incrementally.
Click for Classroom Training
This is a nice convenient 10mm. If it was 10.312 then you would have to do the arithmetic in order to use absolute.
You can even mix incremental and absolute in the same block. Look at this example.
This is it with W
Got to be honest I don’t use incremental that much in turning but I reckon this is a really good use for it.
If you have a slight taper in the part and you want to programme it out. This makes a really simple way.
Onsite Machine Training (Fanuc Haas Heidenhain Mazak)
It is also much less prone to error. You can put it back to zero for the next time if you want.
Changing the X value can be dodgy.
So there you have it Using U and W on a CNC Lathe
Just one other thing.
DON’T FORGET
The U figure is a diameter not a radius.
So in the example above the diameter is increasing by .02 (U.02)
Mazak Training
G94 Facing Cycle CNC Turning
G94 Facing Cycle CNC Turning. Facing on a CNC Lathe is no big deal. You just call out the tool, start the spindle, rapid to the part n face the job.
But then what do you do when you get to the end of the batch of work and find you have got some parts with extra metal on the lengths.
Now you need to add a lot of extra code. This takes a while and it’s easy to make a mistake.
So enter our Knight in Shining Armour
G94
This is how it looks for the first cut
So if you got into the habit of using G94 Facing Cycle CNC Turning.
Oh just one other thing
It remembers.
Interested in classroom CNC training courses?
co*****@***************re.com
Category : Beginners
CNC beginners guide (using Single Block)
CNC beginners guide
This article CNC beginners guide, is about Single Block and how it is used.
When you write a CNC programme it will consist of blocks of programme.
What is meant by a block?
Well it’s everything until the control sees a semicolon ;
If your not sure what a semi colon is it’s when you have had an operation to remove half your large intestine.
The semicolon is called an end of block or EOB
CNC beginners guide
Try not to confuse this with a line of code.
Depending on how your screen is set out a block could be more than one line. The control reads everything until it sees the semicolon or EOB (End of block).
In most cases and on most controls it does not matter what order the code is in. The main reason to follow a set pattern for your code is to make it easy to read.
Try to always put things in the same order.
In one block of code you can have loads of stuff.
You could write:
G0 X50. Y50. S1500 M3;
But if you wanted you could put the S1500 M3 on a different line.
When doing this, think about why you might want to do it. For example you may want to get the tool ready to use before switching on the spindle or the coolant. This saves the excitement of the spindle whizzing round when proving the programme.
Oh yes and you could get fuckin soaked.
Most of this applies when you first test your programme. This is when we use single block.
The Switch
To run a programme in Single Block we have to throw a switch.
CNC beginners guide
This can be a normal Single Block switch or a button or a soft key. Read the article below to learn how to prove out your CNC programme in Single block.
Read this if you don’t know how to prove out a CNC programme.
Once single block is enable the machine will do exactly what it says on the tin.
It will run that block and wait for its next command like a good doggy.
The beauty of this is you only need to think about one block.
Now I don’t want to appear sexist at this point but I recon if my wife were a CNC Operator she wouldn’t need single block. Not only can she do two things at once, which I can’t, but my wife also has an uncanny knack of knowing what’s going to happen next too.
For those with no extrasensory powers just switch on the fuckin single block.
If you turn single block off the machine will still stop at the end of it’s current block and wait for another press of the CYCLE START button to carry on.
Also when you first turn single block on it will stop at the end of the block it is executing.
CNC beginners guide
Those of you who read my articles will know that I love these old Matsuura machines (they make me feel young again).
You know when you’re getting old when you keep asking complete strangers “how old do you think I am”
I did it in Barwell the other day. The woman in the Coop said “piss off you silly old bastard”
What No Telly Screen
Anyway these machines have a one line display so you have to step through to read each line. You can only see little bits of code.
I once input a whole programme into one of these controls not realising I had no end of blocks .
(From now on I ‘m not saying fuck in my articles, I will refer to it as the F word like these posh people on the telly)
On this occasion I said the F word after taking about an hour trying to realise why the programme wouldn’t work.
The whole program was in one block!!!
Don’t mix your G Codes
(here is a nice way to make a John Collins if your bored with this CNC Shit)
You can even make this with non alcoholic Gin. Yes it’s true (non alcoholic gin) my wife bought a bottle the other day. Now I happily went along with this scenario till I found out it was fourteen quid a fuckin bottle.
Absolutely no way, no hang over, no phone call from your mate saying you shit in his cat tray. No no none of that, honestly I give up.
Let’s continue with this CNC beginners guide to CNC programming.
In one block of CNC code you can only have G codes that belong to the same group. I’ll tell you about this in another article when I can be bothered to do it. Anyway it’s easy, they can’t argue with one another. You can’t put G1 and G0 on the same line for example because they are in the same group.
You can’t say feed and rapid in the same line. That would be stupid.
Obviously you can’t repeat things like having two speeds in the same block.
G0 S1200 X50. Y50. S2000;
I don’t think anyone who reads my articles is that stupid….. Except for that bloke in Bolton, but I think he took up plumbing in the end.
Heidenhain
If you have a Heidenhain control the single block works the same. You select Full Run or Single Block
CNC beginners guide
You don’t hear me criticise Heidenhain very often cos I love em. Brace yourselves cos I’m about to.
Those bloody icons.
They all look the same. Every time I come back to working on Heidenhain I can never remember which is which.
I sometimes suggest making little sticky labels to go underneath to identify them.
This one will do wonders for your relationship with the guy on nights.
Before You Go A Few Question about Single Block
  1. What about a tool change?
  2. What about a canned cycle?
  3. What is the meaning of life?
Ok the last one is easy. Question 3 ….. the meaning of life is 42
Right, Now the Difficult Ones.
Your tool change M06 is probably aliased to a macro. This means that a programme is running in the background that you can’t see. Single block may well be inhibited. This means one press of the CYCLE START button will do the tool change. Sometimes however single block works. In this case it will take loads of presses to get through the tool change. Just be patient.
This is the sort of thing that’s running in the background.
CNC beginners guide
I won’t go too much into this, after all it is a CNC beginners guide.
Canned cycles depend on parameter settings. It will normally be one press to rapid to the tool down. Then one press to drill the hole. It may or may not need another press to bring the drill out of the hole.
The exception is G84 Tapping Cycle. You definitely wouldn’t want single block to work on this. Imagine the tap gets to the bottom of the hole and sits there waiting for a push of the button.
Sometimes feedhold is inhibited too in a canned cycle.
Hope you enjoyed this CNC beginners guide
Edgecam training
Category : Fanuc Turn
What to do Next?
Correct
IncorrectG76 threading start point
Don’t say I didn’t warn you.
G0 X21. Z3.
G97 S1200 M3
G76 P010060 Q20 R.02
This thread has a core diameter of 16.96 (X16.93) the thread depth is 1.535 (P1535).
Wrong as Below
G0 X19.95 Z3.
Well now’s the time.
G0 X21. Z3.
G97 S1200 M3
2.5 x 1200 = 3000
Strange Behaviour
Maybe you had a pitch error.
G0 X21. Z3.
G97 S2400 M3
2.5 x 2400 = 6000
Eat more fish.
You know that old book that you use to prop  the door open.
I Love Guide i
Category : New Stuff News
Now I know in the past I have been inclined to say some pretty rude things about Fanuc Manual guide.
Well today I’m here to make amends please Mr Fanuke, as the Americans call him, forgive me it was pure ignorance.
Right now that’s out the way. I could write a massive blog about all the shit things but no there are some great things.
I think the more you learn about something the more you seem to like it. Like all these people who slag off electric cars, funny how they have never actually bought one. I have one and I love it.
Let me make a amends today so it;s official “I Love Guide i”
Manual Guide i is great for editing, fixed forms are awesome and graphics are less crap than all the others.
I Love Guide i, Some things you might not know
You can click on a tool like in this picture T1260 then press INPUT
I Love Guide i
And it will jump to the tool file.
I Love Guide i
Now try clicking on an M code and press INPUT.
I Love Guide i
Wow an M code list comes up. I recon that’s impressive and very useful to boot.
I Love Guide i
I you have it and you don’t use it then you bloody well should. another reason is that when you click on a G code or M code down the bottom left it tell you what it is. Don’t you just love it. Oh and one more thing if you can be arsed to put all your tool descriptions in it will tell you what they are too.I Love Guide i
Stick around to learn more
