Haas CNC Control – What’s Improved and What Still Works
Category : Haas New Stuff
Haas CNC Control – Still Some Clever Ideas After All These Years
I first started training people on the Haas CNC control back in 1995, and at the time it was an absolute game changer.
Not quite in the same way as when I first saw Mazatrol, the Mazak conversational software, which was stunning to say the least. Haas impressed me for different reasons.
What Haas effectively did was take the familiar Fanuc-style control and put it on steroids. A very clever move.
Editing was miles better. Copy and paste — wow! Programs were easy to copy, and program restart was, and in my opinion still is, one of the best systems around. Compare that with Fanuc, where restarting a program can still feel unnecessarily painful.
On a Haas, you could move the cursor to where you wanted in the program and hit Cycle Start. Simple.
And then there were the little things.
When an axis reached the end of its travel, it just stopped. No alarm-induced panic, no turning on the smoke alarms or sprinkler system. It just plain old stopped.
I’m also pretty sure Haas were one of the first to fit a coolant wash-down hose as standard. Ostensibly this was for cleaning down the machine, although its more important use was soaking your unsuspecting mate on the machine next door.
It even had a tray for your coffee cup and a clip for the airline. Someone had clearly spent time using the machine tools Gene Haas I think.
Tool changing was easy too. No M6 T1 followed by an end-of-block. Just input T1 and press ATC Forward.
Fanuc, meanwhile, can seemingly find a way of punishing you for forgetting an EOB.
Haas CNC control
Has the Haas CNC Control Lost Some of That Innovation?
All that said, I can’t help thinking that some of that original innovative approach became a little jaded over the years.
However, I recently worked on a very new VF-2 and noticed a few rather clever features that I really liked. I don’t know how long some of these have been available, but they certainly caught my attention.
Manual Lathe Warco GH 1439
Makes a pleasant change to go back to basic on a simple manual lathe with a DRO (Digital Readout).
I think simple is definitely the wrong word as the level of skill needed to operate this little beast is very high. We are talking years of practice and developed skill.
Now I’m definitely gonna get trolled for this but most of the skill is no longer needed, just buy a CNC.
It is much better when you have a readout DRO (Digital Readout).
Trolled? I don’t even know what it means I just know it’s a bad thing on the internet and it hurts. The only troll I know of is in a fairy tale I used to read to my children.
Great story about some geezer under a bridge terrifying kids, what could be better?
Yes so sometimes it’s hard to let go of some of these hand skills we don’t need. But what these machines definitely do well is get you used to cutting metal and the overall feel of it.
If it’s a hard material you fuckin know.
Switch It On This Manual Lathe with DRO (Digital Readout)
To turn on this machine is easy just flick the isolator round.Manual Lathe
Make sure both Estops are cleared there is one at each end, rotate to release.
The DRO (digital readout has its own switch at the back you may need to flick this over, and after a few seconds it will burst into life.
Safety First
The yellow pedal is your big mate on a Manual Lathe. Press him at anytime and the machine will stop dead. In any dodgy situation keep your foot over this ready.
G130 Doosan Lynx 300M – Set the G30 Position
Category : New Stuff
G130 on a Doosan Lynx 300M – Setting the G30 Position
Doosan Lynx 300M G130
On a Doosan Lynx 300M, G130 can be used to set the machine’s G30 second reference position.
The interesting part is that G130 is not doing the work itself.
Read on if you are scared of fucking with parameters.
On this machine:
G130
calls:
O9019
This is done using Fanuc parameter 6059.
If parameter 6059 contains:
130
then G130 calls macro O9019.
What Does O9019 Do?
The macro reads the position you added to G130 and writes it into Fanuc parameter 1241.
Parameter 1241 stores the second reference position, normally associated with:
G30 P2
So instead of manually entering the position into parameter 1241, you can enter it on the G130 line:
G130 X200. Z200.
Simple.
This is called a G Code Alias read about it here
How It Works
G130 X200. Z200.
Parameter 6059
O9019
Your X200. Z200. position
Parameter 1241
Setting the Position
  1. Reference the machine.
  2. Jog the turret to the required position.
  3. Check that the position is safe.
  4. Record the existing parameter 1241 values just as a safety precaution.
  5. You could even take a screen shot.
  6. Add you new position to G130 for example G130 X200. Z200.
  7. Check parameter 1241.
  8. Test the G30 move at a low rapid override.
  9. (G30 U0 W0)
Why Use G130?
It is quicker than manually typing coordinates into parameter 1241 and reduces the chance of entering the wrong value.
It also gives the setter a very simple command:
G130 X200. Z200. (set my G30 position here)
It’s Permanent
Yes it stays in forever unless you change it. Therefore you don’t have to keep writing G130 in a program if you always use the same position.
If you are scared of fucking with parameters then this is your answer. Change the G30 position and no one dies.
Important
G130 is a custom G-code alias on this machine. Do not assume it performs the same function on every Fanuc-controlled machine it will not.
This is a Doosan specific command. Now you know how you could add it to any machine, see end of article for full code.
Also, back up your parameters and macros before changing anything.
Onsite Doosan CNC Training UK – Hands-On Courses
Onsite Doosan CNC Training UK – Expert Hands-On Courses at Your Facility
In the competitive UK manufacturing sector, your Doosan CNC machines are key assets for delivering precision turning, milling, and multi-axis work. But to get the absolute best performance from models like the Puma series lathes, Lynx compact turning centres, or DNM vertical machining centres, your operators and programmers need targeted, practical skills.
32 Five Star Reviews
That’s where CNC Training Centre excels: we provide onsite Doosan CNC training right on your shop floor – no travel, no lost production time, just real results tailored to your exact machines and workflows.
Why Onsite Doosan CNC Training Delivers Superior Value
Doosan machines (now known as DN Solutions) have earned a stellar reputation in the UK for their durability, high-speed capabilities, FANUC controls, and versatility across industries like aerospace, automotive, medical devices, and precision engineering.
Yet the biggest untapped gains often lie in operator expertise.
  • Zero production disruption – Training happens where your team already works, using your specific Doosan lathes, mills, or multi-tasking centres.
  • Hands-on with your reality – Practice on your actual fixtures, tooling, programs, and materials – far more effective than offsite or generic simulators.
  • Fully customised sessions – From foundational operator safety and setup to advanced Doosan programming training onsite, live tooling, Y-axis, sub-spindle ops, probing, and cycle time reductions.
  • Quick, measurable ROI – Teams apply new skills immediately, slashing scrap rates, shortening setups, minimising errors, and increasing output.
Investing in premium Doosan machine training onsite empowers your workforce to fully exploit the reliability and innovation built into every Puma, Lynx, or DNM model – helping you stay ahead in a skills-short UK market.
What Our Onsite Doosan CNC Training Includes
Every course is built around your Doosan lineup and production goals. Core topics typically cover:
  • Safe operation, daily checks, and preventive maintenance
  • Rapid, accurate setup and workholding strategies
  • G-code mastery plus conversational and Manual Guide i programming techniques
  • Toolpath optimisation for turning and milling efficiency
  • Advanced capabilities: live tooling integration, multi-axis machining, in-cycle probing
  • Common troubleshooting on Puma CNC training onsite, Lynx Doosan training, DNM machining centre training, and similar models
Delivered by seasoned instructor with extensive Doosan experience, our sessions provide industry-proven insights you can trust.
Ready to Maximise Your Doosan Investment?
Don’t let under-skilled operators hold back your high-performance Doosan CNC machines. With Doosan CNC training from CNC Training Centre, you’ll see faster setups, better part quality, reduced downtime, and a more capable team – all without anyone leaving your premises.
Your Doosan machines are built for greatness. Let’s ensure your team is too.
Expert onsite Doosan CNC training – practical, effective, delivered where it matters most.
CNC Programming Training
Learn to Program CNC Machines with Confidence
Onsite Training Enquiry
CNC (Computer Numerical Control) programming is an essential skill for machinists, engineers, and manufacturers looking to improve precision, efficiency, and automation in machining. Whether you’re new to CNC or looking to advance your skills, these CNC programming training courses provide hands-on learning with real machines and industry-standard software.
Why Choose CNC Programming Training?
CNC machines are the backbone of modern manufacturing, used in industries such as aerospace, automotive, medical, and precision engineering. Learning CNC programming enables you to:
•Enhance Your Career – Skilled CNC programmers are in high demand across multiple industries.
•Improve Efficiency – Mastering programming techniques reduces setup time and increases productivity.
•Ensure Precision – Good programming minimises errors and improves part quality.
•Stay Competitive – Advanced CNC skills give you an edge in the job market and in manufacturing sector.
What You’ll Learn in Our CNC Programming Training
These training courses cover essential topics to help you become a proficient CNC programmer, including:
1. Introduction to CNC Programming
•Understanding G-code and M-code
•CNC machine setup and operation
•Basic programming structure
2. Advanced CNC Programming
•Tool path optimisation
•3-axis, 4-axis, and 5-axis programming
•Advanced cycles and macros
3. Mill-Turn and Multi-Axis CNC Training
•Programming for complex mill-turn machines
•Synchronising milling and turning operations
•Live tooling and sub-spindle programming
4. Hands-On Training with Real Machines
•Practical exercises on CNC mills and lathes
•Simulated programming and real-world applications
•Debugging and troubleshooting programs
Who Should Enrol?
This CNC programming training is ideal for:
•Beginners looking to start a career in CNC machining
•Machinists and engineers wanting to enhance their skills
•Companies training staff to improve production efficiency
•Anyone interested in mastering CNC programming
