Day: May 30, 2022
Surface Finish CNC Turning
Category : Beginners
CNC Turning Surface Finish
Ever wondered what feed rate is best to give you a particular CNC Turning surface finish? Or do you just guess?
Well look no further. From now on you’ll be able to work out what feed-rate will give you the surface finish you require when CNC Turning.
Oh and there’s a formula where you can work out what surface finish you’re going to achieve without a fortune teller.
We are going to use um Ra.
The um stands for microns.
The Ra stands for roughness average.
Here is a full explanation if you really want to know.
CNC Turning
You can buy a flat block like the one above which you can use as a comparison to see what surface finish you’re getting.
The section above is for CNC Turning surface finishes.
So you can already see that 12.5 is like a plowed field and .4 is like a babies arse (as my father used to say) .
So if you’re fixing a fence post then 12.5 might be OK.
Surface Finish The Dreaded Formula
surface finish
First of all what feed rate would you need to obtain a certain CNC Turning surface finish.
CNC Turning
Now what if you’re already machining the part. That means you know the feed rate. What surface finish will you get?
CNC Turning
So………….
Our tip radius is .8mm
CNC Turning
We want to achieve a 3.2 um Ra  CNC Turning surface finish
CNC Turning
So here’s the formula.
CNC Turning
Let’s do this bit first.
https://www.youtube.com/watch?v=vWQgBtlUUMM&ab_channel=MotoMadness
8 x .8 x 3.2 = 20.48
Now let’s divide it by 1000
20.48 / 1000 = .02048
Now lets square root the answer.
Square root of .02048 = .143
So the feed-rate you need is F.143
CNC Turning
OK… You Came Back. You Ready to Carry On?
Anyway let’s see how you do it backwards.
surface finish
So imagine you had been turning these imaginary bits with a .8mm radius insert at a feed-rate of .143 (F.143)
First of all square the feed rate .143 x .143 = .020449
CNC Turning
Now do the bottom bit 8 x .8 = 6.4
surface finish
Now divide the top by the bottom.
surface finish
.020449 / 6.4 = 0.00319515625
Then simply multiply this by 1000
0.00319515625 x 1000 =3.19515625 (3.2)
That’s 3.2 to you
surface finish
A surface finish comparator
It worked backwards!!! Phew what a relief.
Surface Finish, Now Let’s Think About This
So to get a 3.2 finish with a .8 tip radius you would need a feed rate of .14
Now let’s do the same calculation with a .4 radius tip.
surface finish
Calculate surface finish
So did you work it out?
Here’s one I prepared earlier.
The answer is .101
And if you can be bothered to work it out with a 1.2 radius tip.
The answer is .175
.4    =  .101
.8    =  .143
1.2  =  .175
Interesting
So as the tip radius gets bigger you get to increase the feed rate!
Oh yea we do CNC Training too not to mention Classroom Training.
