Rads and Chamfers Fanuc Parameters 8134 3453
Category : Fanuc Parameters
Bits n Bobs
Rads and Chamfers Fanuc Parameters. Today we are going to change the parameters that make ,R and ,C work this means you can program point to point and just stuff in some rads and chamfers as an afterthought.
Here’s an article on it if you want to use it
Fanuc have two ways of putting on chamfers and rads and that’s where the confusion lies.
Just do as you’re told (oh and read this article)
So in Parameter 3453 you can set bit #0 (CRD) to a 1 this allows what Fanuc call “Direct Drawing Inputs” to work.
Also in Parameter 8134 set bit #2 (CCR) to a o
Now don’t let the description put you off this turns on the crappy one that uses R and R- and K and K-. This only works on 90 degree corners and unless you won Mastermind I wouldn’t even try to understand how it works.
Trust me it’s shit
Anyway Rads and Chamfers Fanuc Parameters 8134 3453 all sorted!
Other Parameters Of Interest
If you aint got a camera then you must have a piece of paper.
2 Comments
Clive
February 26, 2022 at 12:35 pmHow to unlock G68 and G69? My fanuc 16i can’t read both G68 and G69 code, show alarm improper G code
February 26, 2022 at 3:29 pmIt looks as if you don’t have the macro option on your machine. In MDI key in #1=1. and press cycle start. If you get an alarm it means you don’t have macro. There is no way to turn this on, you have to buy the option from Fanuc
