Day: December 31, 2024
Fanuc Useful Variables
Category : Macro News
Call David: 07834 858 407  (On or off-site Training)
If you use macro programming quite a lot these Fanuc Useful Variables will definitely speed things up for you.
#0 Null Mmmm
#0 this is null, use this to make something have no value, that’s not zero by the way.
You can use this to see if your macro user has not entered a value for some letter you have used.
This means you can then apply a default value if there is none stated.
#1 to #33 are classed as local variables. These values are not retained depending on settings.
These variables will be assigned to corresponding letters in your macro call line.
For example using letter A will represent #1 in the body of your macro.
We have loads more articles on macro if you are interested.
System Variables
These are amazing you can interrogate the sytem, ask it questions like.
What tool is in the spindle?
What time is it?
What speed are you running at?
Almost anything, well you know not anything as in, will I go bald or what horse should I bet in the Grand National?
Fanuc Useful Variables Work Offsets
Or these
Setting a Macro As an Alias Using M Code
Setting a Macro As an Alias Using G Code
Fanuc Useful System Variables Modal Information
Don’t Be alarmed
#3000 is a system variable it puts the machine into an alarm state. You can assign a value of 0-200 and a message in brackets such as.
(THE TOOL IS BROKEN YOU TWAT)
#3000=100 (SORRY FOR SWEARING AT YOU)
Single block
#3003=1 will disable single block
#3003=0 will enable single block.
Thanks for reading my article, if you need to look for more information there’s loads more on this website or go here for Fanuc manuals.
It’s a bit spammy but you can get the manuals you need.
