Day: October 29, 2025
Polar Programming G16 Fanuc
Polar programming is cool.
No use??? Think about it. Polar Programming G16.
Read on….
Oh No Polar Programming G16 is an Option
Polar Programming G16First thing you need to do is program a G16 to say you want to use polar programming.
G16 on its own means your datum is the centre of the pole (X0 Y0)
Once G16 is active then X becomes your radius and Y becomes your angle.
What’s The Time Mr Wolf?
Now see it running.
Note that the distance to the sharp corner is 46.188 The line N1 uses this.
Incremental
Polar Programming G16 Action
Action
What do you think?
G16…..
Leading Trailing Zeros CNC Programming Basics
You do not need leading or trailing zeros in a CNC program (see below):
O0001(G81 DEMO)
G21 G90 G40
G90 G00 G54 X12.64 Y88.00 S2546 M03
G43 H01 Z15.00 M08
G0 Z100.00
Z1.00
G01 Z-0.1
Without leading Zero is exactly the same. (Trust me it won’t self destruct or start world war 3)
O1(G81 DEMO)
G21 G90 G40
T1 M6 (20.0 MM DIA X 90 POINT SPOT DRILL)
G90 G0 G54 X12.64 Y88. S2546 M3
G43 H1 Z15. M8
G0 Z100.
Z1.
G1 Z-.1
Try to keep your code consistent. As I mentioned before try to make all programs look the same.
Create an SOP (Standard Operating Procedure) which will cover all programming layout options. Haas controls will insert their own leading and trailing zeros so you won’t have a choice there.
Leading Trailing Zeros and Memory
Leading Trailing Zeros, if you are short of memory (not as in forgetful) this can save loads of space, and you might be surprised how small the memory is on some CNC machines, some have the memory of a fish.
CNC Programming
The main thing is that you are happy with the layout of your program.
If you are not consistent with your approach it can cause a lot of problems.
Please remember that when you are typing code into the machine it will take you considerably longer to type G01 X0.200 Y0.200 F100.00 than G1 X.2 Y.2. It could wear out your fingers or give you multi RSI.
A Haas control will automatically add leading zeros but just try to ignore it. Maybe Mr Haas likes to see them.
Main thing is you don’t need to type them in.
Take a look at this article.
Another way to save space on a Mazak control is to delete all the spaces (ISO G code programs only)
Contact David :07834 858 407
CNC Programming Course
Training on all controls and machines.
CNC Programming Examples Turn and Mill
Category : Fanuc
Click CNC Programming Examples
These are the different CNC programming examples we have both turning and milling.
CNC Programming Examples Turning
G94 Facing
Milling
G81 Drilling Cycle
G73 Peck Drilling Cycle
G83 Deep Hole Peck Drilling Cycle
G82 Drill With Dwell Cycle
G84 Rigid Tapping
Examples from Haas
Webster & Bennett with Fanuc 10T
I Just Love Old Machines
I recently got to train someone on one of these, a Webster & Bennett with Fanuc 10t Control.
Webster & Bennett
It’s what I crudely call a big bastard. But bastard it is not, it can definitely machine some big shit
Webster & Bennett
Like this monster.
Don’t ask me what it is or I would have to kill you. Joking aside I think it’s a water valve. Beware these jacuzzis use a lot of water,
The machine is a Webster & Bennett vertical borer and I think the Fanuc 10t control was possibly a retro fit.
When these start whizzing around even a few RPM it can scare the living shit out of even the most seasoned engineer. And me, well I,m more seasoned than a piece of Nando’s chicken.
G50 on a Webster & Bennett Your Best Friend
Anyway joking aside your best buddy now is definitely G50 get this wrong and it’s fuckin world war three.
Imagine the scenario, you program G96 S180 M3. Spin at 180m/min. Not too fast but…. what if the tool is sat in the middle of the part.
Machine says “come on lads happy days foot to the floor flat out joy riding” and it fucks off like two teenage boys in a stolen Lamborghini.
So without a G50, or the wrong speed, this beast will accelerate to it’s maximum rpm.
Oh and did I Mention it’s harder to stop than a P & O Criuise Ship with 4000 obese pensioners on board?
Fanuc Subprogram (Local Subroutine)
If you have ever used local subroutines on Heidenhain or Yasnac. Then you will know how convenient it is to save all your programs in one go. No need to remember to save all those shitty little external sub programs.
What’s He On About?
If you are now saying “what the fuck is he on about”. Here is an explanation.
A local subroutine or subprogram is where you stuff all your subprograms at the end of your main program.
So on a Fanuc control if you were making this part below.
Drill spot drill then tap.
Fanuc Subprogram
Programme would look like this.
Fanuc Subprogram
Thing is the code is just repeated three times. I have nice round numbers in here like X40. and Y20. so it’s easy to notice mistakes. But if it was X40.392 for example you wouldn’t spot a slight mistake.
So if you call a subprogram it looks like this.
Fanuc Subprogram
And then your Subprogram is like this.
Fanuc Subprogram
Fanuc Subprogram
The M98 P500 calls the external Fanuc Subprogram. Read this if you don’t know about sub programmes.
Saves you having to repeatedly write shit loads of code.
So that’s why we use a Fanuc Subprogram. But……
You have to look after these bloody things and they seem to be able to just get lost on their own.
You find them at the back of the fridge sometimes along with a piece of mouldy old cheese. At least you can make a meal of the cheese.
Fanuc Subprogram No More Lost Programs
So this is how it looks with a Local Subroutine.
All you need to do is replace P with Q. So mind your P’s and Q’s as they say.
The Q corresponds to any N number. So you could have loads of these stacked up at the end of your programme and you only need to save it once. All this shit will go with it and you don’t need to worry about it ever again.
Haas To The Rescue
Of course Mr Haas sorted this out years ago with M97, this calls a local sub. M98 calls an external program. It’s on all Haas machines and you definitely do need to fuck with any parameters.
Just A word Of Caution.
There are PARAMETERS involved. Arrrrrrrrrrrh……..the dreaded PARAMETERS
To call a subroutine on your Fanuc control. You first need to make sure that Bit 0 of parameter 06005 is set to 1
Fanuc Subprogram
It’s only on the newer controls by the way.
Sub programs on a Siemens control.
Thanks For Reading My Articles We Love you all .
