Fanuc Subprogram (Local Subroutine)
Category : Fanuc
If you have ever used local subroutines on Heidenhain or Yasnac. Then you will know how convenient it is to save all your programs in one go. No need to remember to save all those shitty little external sub programs.
What’s He On About?
If you are now saying “what the fuck is he on about”. Here is an explanation.
A local subroutine or subprogram is where you stuff all your subprograms at the end of your main program.
So on a Fanuc control if you were making this part below.
Drill spot drill then tap.
Programme would look like this.
Thing is the code is just repeated three times. I have nice round numbers in here like X40. and Y20. so it’s easy to notice mistakes. But if it was X40.392 for example you wouldn’t spot a slight mistake.
So if you call a subprogram it looks like this.
And then your Subprogram is like this.
Fanuc Subprogram
The M98 P500 calls the external Fanuc Subprogram. Read this if you don’t know about sub programmes.
Saves you having to repeatedly write shit loads of code.
So that’s why we use a Fanuc Subprogram. But……
You have to look after these bloody things and they seem to be able to just get lost on their own.
You find them at the back of the fridge sometimes along with a piece of mouldy old cheese. At least you can make a meal of the cheese.
Fanuc Subprogram No More Lost Programs
So this is how it looks with a Local Subroutine.
All you need to do is replace P with Q. So mind your P’s and Q’s as they say.
The Q corresponds to any N number. So you could have loads of these stacked up at the end of your programme and you only need to save it once. All this shit will go with it and you don’t need to worry about it ever again.
Haas To The Rescue
Of course Mr Haas sorted this out years ago with M97, this calls a local sub. M98 calls an external program. It’s on all Haas machines and you definitely do need to fuck with any parameters.
Just A word Of Caution.
There are PARAMETERSÂ involved. Arrrrrrrrrrrh……..the dreaded PARAMETERS
To call a subroutine on your Fanuc control. You first need to make sure that Bit 0 of parameter 06005 is set to 1
It’s only on the newer controls by the way.
Sub programs on a Siemens control.
Thanks For Reading My Articles We Love you all .
