Day: October 27, 2025
Hurco Tool Changer How To Change and Load Tools
Hurco Tool Changer
The Hurco tool changer is a strange old beast but trust me you will get to love and respect it as time goes on.
Hurco Training
First of all you can call the tool anything you like, well sort of as long as it’s a number.
Anyway I’m confusing myself here, you give it a number from 1 to 999
You then decide if it is AUTO or MANUAL. The control will then decide what to do with it.
To define a tool go to Tool Setup Screen type in a new number for your new tool.
Hurco Tool Changer
As you go to each dropdown menu the option will appear on the right as well.
Now pick your tool, fill in diameter of the tool. Select which coolant type you want PRIMARY is usually the main nozzle supply and SECONDARY is through spindle.
Hurco Tool Changer
Hurco Tool Changer
This is where your Hurco starts to get smart, it can calculate your speed based on the SURFACE SPEED you give it. I will also calculate the feed rate based on the number of teeth you have and FEED/REV you give it.
Don’t worry it still works if you wear dentures.
Hurco Import Tools How To Guide
Category : Hurco News
Hurco Import Tools, in a previous article I did say how much I love Hurco Machines  I then added a small caveat and a rant.
Anyway here is another.
Hurco Import Tools
Now if you know a better way of doing this please tell me “we are all in this together” as our government once said as they were about to simultaneously fuck us over and rinse our bank accounts.
I need to re-home this beetle as we are moving house.
Hurco Import Tools
The problem is that when you start a new program it does not have any tools. It’s easy to get your Calvin Klein thong completely twisted on this one.
Sorry but writing these articles just doesn’t pay the bills
What can happen is you can get completely mixed up over what tools are in your machine and what tools your program needs.
Hurco Import Tools to the rescue, I have found the simplest way to sort this out is to have a template program with every tool you ever use or need. You can then import the tools from this program into the one you just started.
