Category Archives: Fanuc Mill
Canned Cycles Using G98 G99
This article is about CNC Canned Cycles Using G98 G99
(G Code CNC Programming)
It’s not a competition G99 vs G98. sometimes you need G98 sometimes you need G99.
CNC Canned Cycles Using G98 G99, a canned cycle is usually one line of code for example to drill a hole. This one line of code tells the machine all it needs to know about drilling my holes.
G98 G99
  •  Depth
  •  Feedrate.
  •  Point to rapid to before drilling
  •  Point to rapid back to after drilling
G Code Programming Haas Fanuc (ISO) Mazak
What happens then is each time we give the machine a new position it will drill one of these holes. Each hole will be identical unless we change one of the parameters. So if on one hole we put a different Z depth that hole and all subsequent holes will be to the new depth.
So all in all it’s a really easy way to drill holes. You tell it what you want and then each time you give a position you get a hole. Then when you get sick of drilling holes you type in G80.
Machine says OK he don’t want anymore holes so from now on when the machine moves to a position nothing happens.
Mitsubishi Carbide
There are loads of Canned Cycles I can’t be bothered to tell you about them all cos I’m going out tonight otherwise I would explain them. Anyway they all do different stuff like.
  • G84 Tapping
  • G73 High speed Peck Drilling
  • G83 Deep hole Drilling
  • G81 Drilling
They all work in the same way as each other but with variations.
Now the video at the bottom of the page is about CNC Canned Cycles Using G98 G99 and that’s in all the drilling and tapping type cycles.
Ok what does it do? You may well ask, G99 vs G98
I know for a fact that some of you, and I won’t mention names, put this on the line with the canned cycle but you ain’t got a clue what it does. Maybe you don’t even put it in. Maybe you don’t care.
Anyway it’s simple.
  1. You rapid to an initial point
  2. You rapid down close to the hole (this is the R point)
  3. You feed down to depth (Z Depth)
  4. Then you rapid out to either the initial point (1) or the R point (2)
Now if you program G99 it returns to the R point .
If you program G98 it returns to the initial point (that means the first one)
Ok why on earth would I want that?
Well……. if you made the first point say 50mm above the job (About 2 inches) and the rapid point was 1mm above the job (.040”).
You could drill all your holes in G99 and the drill would each time return to 1mm (.040″) above the part. You get to a clamp and you put G98 and it jumps to 50mm (2”) above the part and misses the clamp. Change back to G99 and it stays down returning to 1mm (0.040) above the part.
Take a look at the CNC Training Courses on offer at the CNC Training Centre
Please don’t let on if you don’t like it as I am easily offended.
co*****@***************re.com
CNC Programming Running Order
CNC Programming Running Order (CNC Basics)
CNC Programming Running Order, the order of your CNC code within one block does not matter (see below)
Or does it?
O0001(G81 DEMO)
G21 G90 G40
(G90 G40 G21) Works the same
(M06 T01) Works the same
G90 G0 G54 X12.64 Y88.0 S2546 M3
(S2546 M3 G90 G0 G54 X12.64 Y88.0) Works the same
So if you always put the speed and M3 (spindle start clockwise) at the end of the first position line try to always stick to that.
It Could Save You
If one day you miss out the speed for example. You will look at the code and it will look strange. You will immediately realise what is wrong.
It’s like the time my cooker got pinched, I looked in the kitchen and their was an old pince of cheese and a dirty floor where it used to be. Whilst I was thinking of a recipe to use the old cheese in I thought “something is wrong”.
Anyway
You will get used to the order of your programs and they will be easier to read, so the CNC Programming Running Order is important.
This helps not only you but your customer, the machine operator or setter.
Imagine you have not seen this program for a while. How long will it take you to realise how it works and what it does?
When you look at any code that I write, in any of my articles, I always use extra end of blocks to space out the code.
Compare CNC Programming Running Order to paragraphs in a book, that is how we visually can jump around the pages.
If for example you were looking at an old program,  you would quickly be able to scan the program and see what’s going on.
So although the order does not matter to the machine it matters to you, try to make your programs consistent and to a regular pattern.
Anyone using your programs, including you, will find them easy to read and to fault find.
Summary
  •  Try to keep XYZ in that order to save confusion.
  •  Make your first three or four lines of each tool always follow the same pattern.
  •  Turn on the coolant in the same place (if it’s not there you will notice).
  •  Start the spindle in the same place and the same when you switch them off.
  • Produce an SOP (Standard Operating Procedure) documenting program layout.
  • Bunch code together in meaningful blocks.
Siemens Sinumerik Training
G81 Drilling Example (Canned Cycle)
The G81 is the most commonly used canned cycle it simply drills a hole and retracts.
All other canned cycles are similar to this but with a few extra bells and whistles.
G81 Drilling Example this simple part has four M12 holes drilled countersunk and tapped.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G81 Drilling Program Example
Here is the CNC code
G81 Program Example
The G81 Cycle instructs it to drill a hole 6mm deep (Z-6.) at a feed of 200mm per minute (F200.)
This is because of the G98.
Now watch the video to see it all in action (G81 Drilling Example)
Haas G81
See full explanation
G01 G00 Basic CNC Programming ( G01 not GO1 )
The letter O is only used for a programme number and a GOTO statement on a Fanuc Control. It’s important not to get it mixed up with the number Zero. So we should really say G zero one ( G01 not GO1 ).
G01 not GO1
When I first learnt to programme, before the First World War, I still remember how daunting the thick yellow Fanuc Manuals were. The Japanese were learning to speak English and we were learning to speak G Code.
Fanuc Manuals
In the Beginning
Okay enough of this bullshit and verbiage let’s talk about G codes.
I often begin my training courses by saying “you only need to know four G codes to programme a CNC, it really is that easy”
G0 G1 G2 G3
What that means is that you can get round any shape with straight lines G1 and circles G2 and G3. Oh and you need to quickly get to the part so use G0 rapid.
Lets Get On with It
G00 or G0 commands a rapid move. That means the axis will be flat out. Maximum foot to the floor, shit off a stick as we say in the Midlands.
Why do I need to know this?
Now lets see.
Move down in Z
G0 Z5.
G01 not GO1
G01 not GO1
G01 not GO1
It’s obvious really.
Just think for a moment:
Looks like this.
G01 not GO1
G01 not GO1
G00 X130. Z-30.
Could be:
G00 X130. ;
Z-30.;
G01 not GO1
Now G01 ( G01 not GO1  )
You do?
G01 X55. Y-200. ;
You would get an angle.
G01 X55. Y-200. ;
The Feed-rate
G01 X55. Y-200. F100. ;
CNC Turning
What About 3 Axis Rapid?
G0 X50. Y20. Z3.
I would definitely advise using it but, and there always is one, just be real careful nothing is in the way. Don’t blame me I’ll just say I never  met you.
Thank you for reading my article ( Basic CNC Programming G01 not GO1 )
Absolute or Incremental G91 G90
Absolute or Incremental that is the question?
Absolute or Incremental no it’s not a Shakespearean Quote from Hamlet.
Two distinct ways of programming.
Understanding Absolute and Incremental Positioning in G-Code
When diving into the world of G-code, mastering the difference between absolute and incremental positioning can be a game-changer. This knowledge not only enhances your programming skills but also provides strategic flexibility in crafting your creations. By utilising G90 (absolute) and G91 (incremental) commands, you gain control over your machine’s movements, allowing for precision and adaptability in your projects.
We all know Absolute (G90)
You are working from an absolute datum. This means that every position or movement is a measurement from the datum.
It is just like on a drawing where every measurement is from the same datum point.
So no matter what position you move to the movement distance is from the datum. This is called Absolute and you use G90. G90 is modal so the G code stays in until you tell the control otherwise.
But do you understand Incremental (G91)???
Incremental is a bit harder to get your head around.
So this time it’s like every position is measured from where you are. So if the movement is X10. then the machine moves 10mm from where you are in a plus direction.
Here is the same part as above but drawn in a different way.
So each position is measured from the last one. Well that’s how incremental positions work. You just move the incremental distance regardless of where you are.
Absolute or Incremental Why?
Come on you tell me…….
You’ll have to work it out or read right to the end of this article. Oh by the way it’s incredibly boring.
Absolute or Incremental There is More
Absolute is like saying “Go to my house”. My house is in just one place and I only have one. So that is an absolute position.
Now if you were at my house and I said “Go to my house”. Apart from thinking I am a bit daft you wouldn’t move. You’d say “David, I am already at your house, are you OK?”
Well that’s like being in G90 Absolute.
G90 G0 X50. Y50.
X50. Y50.
When the machine gets to the second line, in the above code, it wouldn’t move. It would quite happily accept this line of code. I’m sure somewhere deep in it’s CNC brain it would think you were a bit daft. But they are very polite these CNC guys.
If you were in a canned cycle it would drill another hole in the same place because that is what a canned cycle does. (They repeat each time a position is given)
Ok Now are you ready? The Incremental Bit
So if I said to you “drive 5 miles north”.
Well it rather depends on where you are. You may well arrive at my house (and I would make you a cup of tea). Now if I repeated the command “drive 5 miles north” you wouldn’t stay for another cup of tea. You have another journey to make.
Well that’s like being in G91 Incremental.
G91 G0 X50. Y50.
X50. Y50.
After the second move in the above code you would be at X100. Y100. Each axis moves another 50mm.
The Wait Is Over Read On
Absolute or Incremental, why?
First of all let’s look at the two drawings again.
Absolute or IncrementalAbsolute or Incremental
Why not just read the figures off the drawing? Dead easy. First drawing would suit absolute. Second drawing would suit incremental. Or for some parts it would be a combination of Absolute or Incremental.
If you try to add up the figures on drawing number two you will more than likely make a mistake.
Reading The Program
When you read a CNC program you want the figures you see to be the same as the drawing. That way it’s easy to check and you won’t make so many mistakes.
Don’t forget it might be years later when you next read this program.
So Absolute or Incremental? Well it rather depends.
Here is another example where incremental programming would work well.
The pockets are all the same so you could program one pocket incrementally. Stick it all in a sub program and then just move to an absolute position and call it out.
It would be a bit like having a robot that could dig ten inch diameter holes two foot deep. You just send it anywhere in your garden, it will dig you a hole and you can plant a tree.
I can almost hear the comments on this article. “Oh I’d just use a different datum for each pocket”.
“Incremental no way bloody dangerous”
OK smart arse.
At the CNC Training Centre we like you to learn as much as possible about CNC Programming. Understand all the G codes all the M codes every principle. You end up with a toolbox full of CNC Programming Tools.
Absolute or Incremental Which Tool?
Absolute-or-Incremental Let’s Talk About Safety
When you use G91 Incremental as soon as possible add a G90 to bring the machine back to G90 Absolute.
So for example if you had a sub-program you could try and remember to put G90 in your main program. That is something I would definitely forget to do.
So put it at the end of your sub program. That way every time you come out of your sub program you are back in G90 Absolute.
O500(Drilling Sub-Program)
G91(Incremental)
X50.
X60.
X80.
X10.
X5.
X5.
G90(Absolute)
It’s all about tidying up.
If you leave things lying around anything can happen.
You definitely can have a collision using G91 (Incremental) if you are not careful.
Don’t Be Put Off There’s More
Incremental has some brilliant uses. When drilling holes the same distance apart it can save you a lot of programming time. Oh and it really simplifies things.
When using a canned cycle like G81 you can make repeat moves.
G81 G98 Z-5. R1. F100.
X52.554 L20
This will drill 20 holes 52.554mm apart. Think about adding all these figures up, very prone to mistakes.
But do be careful, if you get a figure wrong you can get a cumulative error. “Cumulative error” Sorry I promised not to fuckin swear.
Come on you G91 deniers it does exist and it can work.
Advantages
  1. You can program exactly what is on the drawing.
  2. No need to add up figures.
  3. Repeat holes are dead easy.
  4. Features that repeat can be placed in a sub program and used at any absolute position.
  5. Less errors because you don’t need to add up the figures.
  6. When you later read your program the figures look like the ones on the drawing.
  7. Great for using sub-programs.
  8. It can help you lose weight as part of a calorie controlled diet.
Understanding these concepts is like adding a powerful weapon to your G-code arsenal, enhancing both precision and efficiency.
Whether you’re executing complex designs or simply looking to streamline your process, this foundational knowledge ensures your commands translate perfectly from paper to product.
Disadvantages
  1. If you make a mistake then the errors will add up.
  2. Can cause collisions if used incorrectly.
  3. People don’t like it and are frightened of it.
How does understanding absolute and incremental positioning affect flexibility in G-code programming?
By mastering the use of G90 and G91 commands, you gain the ability to switch between absolute and incremental positioning, thereby increasing your programming flexibility.
2. Why is understanding the difference between absolute and incremental positioning important?
Grasping these concepts is crucial because it equips you with a significant advantage in G-code programming, enhancing your ability to execute precise and efficient commands.
Absolute-or-Incremental Remember This
  • Change back to Absolute G90 straight after use.
  • Make sure the figures you input are accurate.
  • Standardise your code (Read This).
  • After each tool change make sure you have a G90.
  • When you are proving out look at position display to check how figures add up.
