G81 Drilling Example (Canned Cycle)
The G81 is the most commonly used canned cycle it simply drills a hole and retracts.
All other canned cycles are similar to this but with a few extra bells and whistles.
G81 Drilling Example this simple part has four M12 holes drilled countersunk and tapped.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G81 Drilling Program Example
Here is the CNC code
G81 Program Example
The G81 Cycle instructs it to drill a hole 6mm deep (Z-6.) at a feed of 200mm per minute (F200.)
This is because of the G98.
Now watch the video to see it all in action (G81 Drilling Example)
Haas G81
See full explanation
2 Comments
DANIEL RICHARD KASANDA
February 24, 2020 at 6:34 am
I am Daniel Richard Kassanda from Tanzania I have interested much on CNC programing. please can you Sponser me to study CNC programing there.
ALEXANDRA GAMMAD
January 17, 2023 at 6:35 am
As a Freshmen in ELECTRICAL ENGINEERING at the same time working in a factory CNC machines this website is very helpfullll! More lessons to upload i highly appreciate this website thankyou for helping me and other people to know about CNC machines…
