Category Archives: Fanuc Mill
Polar Programming G16 Fanuc
Polar programming is cool.
No use??? Think about it. Polar Programming G16.
Read on….
Oh No Polar Programming G16 is an Option
Polar Programming G16First thing you need to do is program a G16 to say you want to use polar programming.
G16 on its own means your datum is the centre of the pole (X0 Y0)
Once G16 is active then X becomes your radius and Y becomes your angle.
What’s The Time Mr Wolf?
Now see it running.
Note that the distance to the sharp corner is 46.188 The line N1 uses this.
Incremental
Polar Programming G16 Action
Action
What do you think?
G16…..
Ten Things You Might Not Know About The Fanuc Sub Program
Sub Program Fanuc
Here are ten things you might not know about Fanuc sub programs,
Fanuc CNC controls are the most common controls in the world so it might be useful to have a good understanding of how sub programs are called and used.
(1) You Can Call a Sub Program By Name.
Yes you heard it here the program can be called by it’s name or it’s number. When calling by name don’t use the P.
Just put the name of the program in these things <> with an M98 and your away.
M98<ALBERT>
The only problem with this is that the syntax needs to be spot on so if you have got complicated names for your your sub routines then you might be in the shit.
I always call mine names like ALBERT that are easy to remember.
(2) You can use internal sub routines on a Fanuc Control.
Some people call these local sub programs. It just means it’s tagged on the end of your program which makes them nice n easy to look after. A bit like a pet Goldfish or a pet fly.
I bought mine from the local pet store. I asked the assistant if he sold pet flies and he said no. I said “well there are loads in the window”.
Anyway he sold me one (£15) his name is Paul
This is not him this is Steve.
Internal Sub-Routines
By typing M98 Q500 your control will look for N500 within your current program. This is great because you can add the sub programs to the end of your main program. Don’t forget to leave big gaps so you can clearly see where and what they are. Oh and mind your P’s and Q’s.
M98 P500 (Call O500 externally)
M98Q500 (Call N500 in main program.
Oh and read this too.
Sub Program
Just one other thing. Watch your n numbers it’s easy to get them mixed up. Try and use a convention.
How To Format a Data Card on a Fanuc Control
Format a Data Card on a Fanuc Control yes that’s what were going to do. Now first of all I have a confession to make.
People often say to me how nice it is of me to write all these articles helping people with the shit they can’t do. Well sorry it’s not true actually I’m just a selfish bastard just like all the rest of you.
My only reason is that I have and always have had the memory of a goldfish. If you have ever had a goldfish and tried to train it (which I once did). I read books on it like “How to Train Your Goldfish in 3 Easy Steps”, for which I got a refund.
Anyway I digress. The reason you can’t train them is, not least of all because you can’t keep them out of the water too long, but they don’t remember a word you say. Fuck all, Jack shit.
So the minute they learn a nice trick they immediately forget it. It doesn’t bother them because they just forget that it bothered them.
Sorry no more about Goldfish.
Anyway its really easy to Format a Data Card on a Fanuc Control. You just hold in these two babies while switching it on.
Oh and make sure you have data card selected in your parameters.
This is me doing it. Yes that’s my gnarled up old hand.
G10
No G10… Is this you?
G10
G10
Make Sure Your in Absolute
Call David: 07834 858 407
A Canned Cycle What is It?
If you want to learn CNC programming  then you need to know what a canned cycle is.
In a Can…….Learn CNC
dog-163527
X60.
X70.
X80.
X90. Y60.
Want to know More?
Anyway Here are a few:
G98 G99
 G43 Z50.H1 M8
X60.
X70. G99
X80.
X85. G98
X90. Y60.
g98gif
Why you ask?
Easy you can jump over shit.
spiderman-1579249
It Gets Better.
X60.
X80.
X90. Y60.
Now let’s alter the feed
X60. F300. (Change feed)
X70.
X80.F200.(Change it back)
X90. Y60.
Do’s And Don’ts
Do Not………
X60.
X90. Y60. (ETC)
Do Not Repeat Axis Moves.
X60. Y50. (Don’t need Y50.)
X70.
X80.
X90. Y60.
D0…….
  • Always use a canned cycle if possible it saves loads of time. It is also really easy if you need to edit anything.
  • Make your CAD/CAM system output canned cycles, not long hand code. I saves loads of time if you need to edit.
  • Love engineering and be nice to your cat.
Learn CNC
Learn CNC
O0001(Drill and Tap M10)
T01 M06 (20mm Spot Drill)
G90 G0 G54 X0 Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-10. R1. F100 L0
G91 X-31.63 L9
G0 G53 Z0
ETC
  • The programme moves to the datum X0 Y0 which is the middle of the part at the right hand end.
  • The G81 has an L0 at the end. L0 is not a Lionel Richie song it just means don’t do one. So it moves to X0 Y0 and does nothing.
  • The next line, G91 means incremental move so it moves incrementally nine times (L9) X-31.63 and drills a hole each time.
Learn CNC
