We all know that programming can be complicated. So let me explain to you how it all works. This article explains the real meaning of Modal and non modal G codes.
Modal means that once a command is issued it stays in the control.
How Can you Actually Use This?
If you issue a G0 or G00 command the machine is in rapid and you do not need to re-state it.
Rapid means all motors are flat out, like a teenager in a Ferrari.
Every move from then on will be a rapid move unless you tell it otherwise. The G code that changes it must be in the same group. For example G0 G1 G2 and G3 are all in the same group a bit like The Beatles used to be.
The other day I was talking to a “young person” who hadn’t even heard of the Beatles. I mean fuckin hell, am I really really old or are they doomed to be forgotten?
I noticed a common search in google is G80 G-code Fanuc.
CNC Machines use what we call canned cycles in a nutshell G80 cancels a canned cycle.
What is a canned Cycle?
To be honest I think it is a funny choice of words “Canned Cycle”.
My guess would be that all the information to drill a hole would be kept together in a “Tin Can” to use whenever you want.
I made this…….
First of all we program the cycle this is a G81:
G81 G98 Z-10. R1.5 F200. X55. Y55. F250.
The machine will move to the position X55. Y55. then it will rapid to 1.5mm above the part (this is the R1.5). It will then feed down to Z-10. at a feed-rate of 250 mm per minute F250.
Finally it will use rapid to come out of the hole.
Well Commented Programs
M11 (OPEN CHUCK)
M10 (OPEN CHUCK)
etc etc
I had a boss once who actually learnt sines and cosines of angles.
Cosines of Angles
Holy shit I mean it’s impressive and I must add in 1975 it was actually worth doing because we didn’t even have calculators.
Hope you enjoyed reading my article on CNC Milling M Codes.
You can reset Fanuc Display (Relative Position) just like you would on a manual machine with a DRO. So use it for setting or even measurements. One thing to remember is it will not retain it’s position when you turn the machine off. The control in the video is a Fanuc 18i on a big vertical lathe but all other Fanuc controls are similar.
This is a video explaining cutter compensation in CNC programming.
Tool cutter comp.
CNC cutter comp.
G41 G42 cutter compensation.
Cutter diameter compensation.
Cutter radius compensation.
Heidenhain RL RR.
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool. This depends on your settings.
(Cutter compensation G code)
G41 cutter compensation left
G42 cutter compensation right
G40 G code to cancel cutter compensation
This Video shows you :
How to program G41.
How to program G42.
CNC cutter compensation examples.
Cutter compensation Heidenhain style.
Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
What will you do when your cutter wears?
What if you want to use a different size cutter?
The cutter may not run true.
What if the cutter is not exactly size?
The Rules:
Shape must be continuous and consistent.
You can’t cut along a line and then go back along it.
It’s important to allow more than the tool radius when entering tool compensation. The same applies when you come out of tool compensation.
Internal corner radii and steps must be greater than the tool radius.
Don’t ask
