G10
No G10… Is this you?
G10
G10
Make Sure Your in Absolute
What about the L2 you ask?
What’s that for?
L2 means you are writing to the work offsets (G54- G59)
But you can also write to the tool length offsets in which case it would be
G10 L10 P1 R200. (200 length into tool 1)
G10 L12 P1 R10.(10mm radius into tool 1)
WARNING THIS IS NOT THE SAME ON ALL FANUC CONTROLS
Look David, I Have Shit Loads of Offsets
Don’t need your stupid G10.
Now I know some of us do have more offsets than you can shake a cheap memory stick at, but……..
With G10 it’s fixed in program so if some daft bastard alters your precious work offset you don’t give a flying monkey’s shit. Your program just reloads it.
Conclusion
G10 means your datum positions are saved with your CNC program.
The vice or fixture needs to be in exactly the same place when you next set it up.
You can use special single point location fixturing or just make a sub plate.
It’s great for horizontal machines.
Haas G10
9 Comments
Vikas
October 24, 2019 at 7:09 pm
Dwar sir,
Can you explain all “L” Number and why use in program.
    November 1, 2019 at 6:59 pm
    L2 means repeat two times L3 means repeat three times
    November 1, 2019 at 7:00 pm
    Sorry I didnt realise it was in the G10 in G10 L1 is tool offsets L2 is work offsets
John
October 16, 2020 at 6:06 am
HI,
Would L2 P7 override G54.1?
If not, then what would?
I am currently nesting 30 parts (using G54.1, G54.2, .3, .4 etc) and this code would really help me out!
Regards, John.
    November 11, 2020 at 7:13 pm
    Yes you can write to G54.1 with a G10 command instead of L2 you use L20 to get to extended work offsets
Manish Singh
November 2, 2020 at 10:48 am
Sir G54.1 ye kaisa offset hai plz tell me answer
Solomon Kibebew
July 18, 2021 at 3:20 pm
Hi my name is Solomon I just need to ask you about G10,L,P what are they meant also G54.1 how do you use on G10 with L and P can you send me some program examples?
Pradeep kumar
November 27, 2021 at 5:04 am
H.m.c machine operator sector
V.m.c machine operator
Sunil kumar
December 16, 2021 at 11:44 am
If you want use work cordinate more then G59 then use P001 for G54.1 and P002 for G54.2…….. So on
