Category Archives: Haas Turn
Haas Control Zeros Not Required
Category : Haas Mill Haas Turn
Haas Control
On or Offsite CNC Training
Tel: David 07834 858 407
For Example In MDI on a Haas Control
When you type code into your Haas control there is no need to input the zeros. This applies in programme edit and in MDI.
For example in MDI
Try typing in: G90 G X Y Z
Then press ENTER
You will get: G90 G00 X0 Y0 Z0
 HOW EASY IS THAT!
Mmm…….
G0 Cancels Canned Cycles
G0 Cancels Canned Cycles, this is not a news flash it’s always been the case.
O0001(G28 Example)
(PROGRAMMED BY ANDY MURRAY)
G21 G90 G40
T01 M06(20MM ENDMILL)
G90 G0 G54 X200. Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-5. R1. F100.
X100.
X50.
G0 X25. (No hole drilled here cycle would be cancelled)
G80 (This also cancels the cycle)
G28 G53 Zero Return
G28 G53 Zero Return
CNC Training (Call David: 07834 858 407)
G28 G91 Z0                   (Z axis moves up to tool-change)
G28 G91 X0 Y0 Z0        (All three axis move to their respective zero return positions)
If you programmed
G28 G90 Z0 or you forgot the G91 this means return to zero point via a reference point. The reference point is Z0 so the spindle would rapid to Z0 (Bang) and then move up to reference return point.
G28 G53 Zero Return
Using G53
G53 Z0
You need to write
G53 Z0
G53 X0 Y0
Note:
T01 M6
G53 Z0
T01 M6
Tosnuc 888
Tosnuc 888
If you have any questions about G28 G53 Zero Return or you are affected or have been affected by any of the issues in this post please contact me 07834 858 407
Just an address will do…
For CNC Training Call David: 07834 858 407
Just an address will do.
When you work on a machine day after day or you work on the same CAD system. I believe that every now and then you need to look at what you are doing and take stock. You know like when you can’t quite get something to work correctly and you find a way to frig it.
Well done you got yourself out of a mess. But hang on a minute that was two years ago. So when you gonna take the time to find out what was the correct way?
It’s time to get off your fat arse and do something about it.
Sometimes when I am training people I feel like I am being really fussy when I pick them up on minor annoying things they do when operating a machine. By the way I don’t mean things like scratching your bollocks.
For example leading zeros (don’t get me going on that).
Right, your on a Fanuc or Haas control and you want to call program one and you type in O0001 and press search or lower cursor.
No no no!
Just type in O1 that’s all you need. Honestly it drives me bloody bonkers.
Here is an idea just spend one day sorting all these little things out. I tell you now the saving over a year, once you force yourself to do everything the quick way, is massive and it’s there forever.
There is a slow convoluted way and there’s a right way.
Check out the shortcut keys on your favorite bit of software and use em. It’s amazing once you get a grip on it.
How do you copy and paste? You can let me know on that one.
Anyway Enough Ranting This is The Post
Just an address will do when you are typing code into a Haas control. You don’t need to type the zero. How cool is that?
Impress your mates with this one, or better still the boss (you may get a raise…….  not)
Type in G X Y and press input. (This could be in MDI or EDIT mode)
Yes that’s all you need.
It will go in as G00 X0 Y0
These clever Americans can just guess what you are trying to do.
So much easier, one day all controls will be this good.
There you go just an address will do.
  • Vasectomy
  • Lawns mowed
Contact David: 07834 858 407
How to use G50 on a CNC lathe
CNC Turning Basics G50 Speed Clamp
How to use G50 on a CNC lathe.
G50 in a turning program is a speed clamp. The machine accelerates up to the speed you set (G50 S2000) and will not go any faster.
Now before I get arrested by the “Correct Word and Grammar Police” I know it’s not actually a clamp. The truth is it’s just what everybody calls it, so get off my fuckin case.
Black dog his name is Boris
Anyway if I start to call it something else all my CNC mates (and I do have some) will be confused.
Just check me out on LinkedIn. Anyway as I was saying my mates wouldn’t know what the fuck I was on about.
You must program a G50 before each tool and at the beginning of the program for safety reasons which I will explain later.
It’s Modal
G50 is a modal G code (it stays active). If you have a program where you do not want to clamp the speed you must still put the G50 at the beginning of the program (set the clamp to the machines maximum RPM).
Otherwise it may pick up the G50 from the last program and you may not get the RPM you want. It can have the effect of slowing down production because the speed is being restricted and you didn’t realize.
Don’t use someone else’s G50 get your own.
You wouldn’t wear someone else’s dirty pants. (Americans call underpants underwear I think)
These are mine (sorry I din’t get time to wash them).
Modal G code explanation here.
Now Here Is Something You May Not Know
Historically G50 was used to set the machine datum. This still works so do not put any X or Z figures on this line. You will get some weird shit happening if you do. Oh and you will probably trash your 100 grand machine.
Anyway how to use G50 on a CNC lathe
G50 S2000 (SPEED CLAMP 2000 RPM)
Some G code systems, or depending on parameters, may use G92 instead of G50. This is not very common but it works exactly the same way.
On a Fanuc control they are called A type and B type G codes and depends on machine tool builder. Most of the G codes remain the same but proceed with caution.
It is particularly useful when you are facing a part using G96 (constant surface speed). When the tool reaches the centre of the part the machine will be running at maximum RPM. This could be very dangerous on large or out of balance components. When you set a G50 speed clamp, once the machine reaches the clamped speed it will go no further.
Here is a tutorial video about G96 and G97
RULES
  1. Use a G50 at every tool-change
  2. Use a G50 at the beginning of a program (even if you think it’s not needed)
  3. G50 S2000 (Only G50 and speed on one line, nothing else)
  4. There is no rule 4
  5. Never eat yellow snow.
Toshiba VTL CNC
This is a Toshiba VTL (Vertical Turning Lathe).
If you want to buy one or fix one go to Leader CNC
Now imagine this revolving too fast you would soon need their services oh and a good trauma team.
More CNC Turning Help (G70 and G71)
