Category Archives: Haas Turn
Basic Turning
Basic Turning
G96 Hamsters Large wheel Small wheel
G97 Speed In RPM
G97 S1500 M3
When drilling  a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
Basic Turning
If the tool was positioned  at a 100mm diameter it would be as if the tool were able to run around this diameter at  a speed 200 meters a minute.
Basic Turning
Neeeeeoooooooowwww
G96 G97 hamster on a Wheel
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Basic Turning
G96 G97 all about hamsters
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Manual Lathe
cnc turning basics
G50 Warning
Watch the video
Basic Turning
G96 and G97
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
  • Drilling.
  • Tapping
  • Threading (Screw cutting)
  • Cutting the Lawn
Modal and non modal G codes
Let Me explain
We all know that programming can be complicated. So let me explain to you how it all works. This article explains the real meaning of Modal and non modal G codes.
Modal means that once a command is issued it stays in the control.
How Can you Actually Use This?
If you issue a G0 or G00 command the machine is in rapid and you do not need to re-state it.
Rapid means all motors are flat out, like a teenager in a Ferrari.
Every move from then on will be a rapid move unless you tell it otherwise. The G code that changes it must be in the same group. For example G0 G1 G2 and G3 are all in the same group a bit like The Beatles used to be.
The other day I was talking to  a “young person” who hadn’t even heard of the Beatles. I mean fuckin hell, am I really really old or are they doomed to be forgotten?
G92 Threading Single Line Method
G92 threading Cycle is something that concerns me. It’s sadly neglected. Now I know you’re probably saying “no one uses that old shit anymore”
Well you could be wrong.
G92 Threading works exactly the same as G76 except you need to programme every pass. This would be a pain in the arse but hear me out.
The Haas G76 cycle does not have any facility for a spring pass. This is where you add extra cuts at the end of a threading cycle to take out any metal left from the tool pushing off.
On a Fanuc control you can put these extra spring passes in as part of the G76 cycle.
Read this if you need to know more.
If you want this on your Haas control or an old Fanuc control then you can do this.
G76 X16.93 Z-25. K1.534 D.485 F2.5
G92 X16.93 Z-25.
X16.93
X16.93
Just add the G92 after your G76 cycle and whatever X figure you want to go to.
The G92 is modal so you will need a G0 move to cancel it. The code above would give you three spring passes.
Here is a load more interesting stuff.
Haas SL15 CNC Lathe
Classroom Training Click Here
Today I got to train someone on a Haas SL15 Lathe, it had live tooling and a sub spindle.
Haas SL15
It also had a bar-feed.
Not worked on one of these for a while. Tell me why on earth don’t other companies look at the pragmatic approach that Haas take to CNC Machining and copy it?
Say what you like about Haas machines but they have an incredible knack of shattering the bullshit and making stuff easy.
Here are two massive ones.
G112
G112 tricks the Haas SL15 CNC Lathe into thinking it’s a machining centre and that it can mill.
It’s like gender identity for CNC Machines. But, and this is the “for fuck sake bit”, on most machines you have to program it like a machining centre but then when your done you need to double X and switch all the Y’s for C’s.
Sounds simple but in practice it’s a shit storm, specially when programming G2 and G3.
Here is an article about it.
When Mr Haas invented the Haas SL15 CNC Lathe he must have looked at this and laughed. Here is a really clever idea. We’ll trick the machine into thinking it’s a machining centre and here is the clever bit. We’ll keep up the facade.
So you make a milling program (XY) and then……. you leave it that way. How incredibly clever is that?? Mmmmmm
