Category Archives: Fanuc Turn
How to use G50 on a CNC lathe
CNC Turning Basics G50 Speed Clamp
How to use G50 on a CNC lathe.
G50 in a turning program is a speed clamp. The machine accelerates up to the speed you set (G50 S2000) and will not go any faster.
Now before I get arrested by the “Correct Word and Grammar Police” I know it’s not actually a clamp. The truth is it’s just what everybody calls it, so get off my fuckin case.
Black dog his name is Boris
Anyway if I start to call it something else all my CNC mates (and I do have some) will be confused.
Just check me out on LinkedIn. Anyway as I was saying my mates wouldn’t know what the fuck I was on about.
You must program a G50 before each tool and at the beginning of the program for safety reasons which I will explain later.
It’s Modal
G50 is a modal G code (it stays active). If you have a program where you do not want to clamp the speed you must still put the G50 at the beginning of the program (set the clamp to the machines maximum RPM).
Otherwise it may pick up the G50 from the last program and you may not get the RPM you want. It can have the effect of slowing down production because the speed is being restricted and you didn’t realize.
Don’t use someone else’s G50 get your own.
You wouldn’t wear someone else’s dirty pants. (Americans call underpants underwear I think)
These are mine (sorry I din’t get time to wash them).
Modal G code explanation here.
Now Here Is Something You May Not Know
Historically G50 was used to set the machine datum. This still works so do not put any X or Z figures on this line. You will get some weird shit happening if you do. Oh and you will probably trash your 100 grand machine.
Anyway how to use G50 on a CNC lathe
G50 S2000 (SPEED CLAMP 2000 RPM)
Some G code systems, or depending on parameters, may use G92 instead of G50. This is not very common but it works exactly the same way.
On a Fanuc control they are called A type and B type G codes and depends on machine tool builder. Most of the G codes remain the same but proceed with caution.
It is particularly useful when you are facing a part using G96 (constant surface speed). When the tool reaches the centre of the part the machine will be running at maximum RPM. This could be very dangerous on large or out of balance components. When you set a G50 speed clamp, once the machine reaches the clamped speed it will go no further.
Here is a tutorial video about G96 and G97
RULES
  1. Use a G50 at every tool-change
  2. Use a G50 at the beginning of a program (even if you think it’s not needed)
  3. G50 S2000 (Only G50 and speed on one line, nothing else)
  4. There is no rule 4
  5. Never eat yellow snow.
Toshiba VTL CNC
This is a Toshiba VTL (Vertical Turning Lathe).
If you want to buy one or fix one go to Leader CNC
Now imagine this revolving too fast you would soon need their services oh and a good trauma team.
More CNC Turning Help (G70 and G71)
Jumping Sections of Programme Using M99 and Block Skip
Click for M99
Contact: 07834 858 407
CNC Turning Using T00 to Cancel Offset
CNC Turning Using T0000 to Cancel Offset
This article is about CNC turning programs and the use of T00 or T0000 to cancel the tool offset.
My daughter is autistic, and one of the things that she has taken great delight in doing during the Covid lock down, was picking up on the stupid nonsensical phrases and expressions that neurotypicals have created in their non-binary brains.
In case you don’t already know neurotypical is an expression used by autistic people to describe non-autistic people. I still haven’t worked out if it is a term of endearment or mildly offensive but I don’t really care anyway.
Anyway, whilst I was writing an article about using multiple offsets, yet to be completed, I suddenly realised why it is a good idea to cancel the tool offset on a CNC Lathe (more about that later).
We were sat drinking tea in our summer house, me my wife and my daughter.
I know it sounds grand but really, it’s not exactly a summer-house it’s more of an old shed. It’s one I converted to compete with my neighbours when they had a fancy new summer house built.
Just a few finishing touches needed
I was talking about this article in rather abstract terms as my wife and daughter are none engineers but always pretend to be interested in my rantings.
Anyway, with reference to tool offset cancellation I said “you learn something new every day”.
My daughter immediately retorted “oh so what did you learn yesterday?”. Fortunately, I could think of something I remembered learning that there are 206 bones in the human body, so I used it.
I need to add a this point that my daughter is not an autistic savant and we still need google and takeaway menus. She’s not like that bloke in “Rain Man” who can remember every number in a fuckin’ phonebook.
The expression is “if you know one autistic person, you know one autistic person”
Anyway with her autistic brain I should have known this wouldn’t suffice. “The world tilts at 23.5 degrees on its axis” I quickly added.
“You already knew that” she said.
(Please ignore this if you think the world is flat as I know a lot of my readers do)
She insisted that I should go back at least three weeks in order to prove the validity of the statement.
I decided to give in and the conversation ended by me admitting that all neurotypical people are stupid.
In our household that’s a result and a common strategy we use to resolve this kind of conflict.
Such idioms as “washing your dirty laundry in public” are just banned unless you think you have a simple way of explaining it.
A friend once exclaimed that “there is more than one way to skin a cat!” and as a result required a police escort to get home (joke).
My daughter has a cat and her whole existence revolves around it. I’ll let you imagine her reaction.
Using T00 to Cancel tool Offsets
Anyway, this was going to be an article about using multiple offsets in a CNC Turning program.
They are a bit like multiple orgasms but not nearly as much fun. Anyway I had this eureka moment with regards to T00 and ditched the whole thing.
On a CNC Lathe we use a four-digit number when we do a tool change.
T0101 for example.
The first two digits make the turret index T0101 (index to tool 1)
The second two T0101 will call an offset. You will note I said an offset because it can be any.
By the way some controls like Haas omit the first zero on a tool change.
CNC Turning
Geometry offset page on a Fanuc CNC Lathe
In the above case it’s offset 1 but it could be T0112 this would index to tool 1 and use offset 12.
CNC Turning
Anyway thinking about these four digit numbers made me think about when you use zeros.
On older machines you used to have to cancel the offset by stating T0100 or much safer T0000. Otherwise the machine would add the new offset to the old one and a shitstorm would ensue.
I had consigned, this now inert procedure, to the CNC Turning equivalent of room 101 or at least the annals of CNC History. Anyhow, it seems there is life in the old T000 dog yet.
I love this puppy I’m going to use it in every post from now on
Now this is where that eureka moment happened in my summer house / luxury shed and I wrongly claimed to learn something new every day.
The Theory
When you write a CNC Turning program you can either return the tool back to the machine reference or return it to a tool change position.
Now the first option (reference) is OK if it is a small a machine. In other words it’s not gonna take it a week to get there.
On a big machine you would have to navigate around all sorts of shit like the tailstock or a steady or the boss’s Bentley. And it would almost definitely be a waste of time.
Soooo normally we would use a tool change position. This would be making use of G53
CNC Turning
Using G53 for tool change position
CNC Turning G53
Because the G53 uses the machine coordinate system it will be the same place for each tool.
CNC Turning
You could then put this position in a sub program. That way it would be the same for every tool. If you needed to change the position you would only need to change it once in the sub-program.
I will forgive beginners for thinking you could just rapid each tool to the same position away from the work piece.
For example G0 X100. Z100. for every tool.
CNC Turning
Sending a drill to a position
CNC Turning
Sending a turning tool to a position
Just look at the turret position in the pictures above. Although the X Z position of both tools is the same there is a huge difference in the turret position.
This could work but when you pick the program up again maybe months later. The tools could be different lengths the tool-change position would have to be altered.
Your drills may not be the same length and the machine may even over-travel when you try to move it to your old tool change position..
Using a G53 you can always allow for the longest tool and know your index position is safe.
Remember G53 does not consider the tool offset or the work offset. To be honest G53 is the selfish bastard of the G codes it just does not give a flying shit what offset is active.
Eureka
Anyway, thinking about cancelling tool offsets it gave me an idea.
If at the end of each CNC Turning tool you cancel its offset. you could send it to a known position.
Because no tool offset is active this would always be the same place.
Some of you probably already do this but honestly, I never thought of it.
I intend to program this way from now on.
CNC Turning
Using T00 for your tool change position
You should be able to use T00 or T000 to cancel your tool offset.
Don’t Do This (I really shouldn’t be telling you)
You can use the tool number plus the zeros so to cancel T0101 you could put T0100. I strongly recommend that you do not do this because it introduces an index move and therefore another potential collision.
You would need to remember to change this on all tools if for some reason you moved the tools around in the turret.
Oh yea about the multiple offsets. I will be writing and article on it when I can be arsed but in the meantime here is a video.
Thanks for reading my articles (no flies were killed in the writing of this article) except for the little bastard that’s flying around my office.
I will ask it politely to leave or else.
CNC Turning G Code List For Beginners
Download and print this nice large print CNC Turning G Code List
Download CNC turning G Code List PDF
I always begin my training sessions by telling my students not to remember anything I say.
This sounds completely stupid and my excuse is it wasn’t my idea to say it.
About ten years ago I worked in France. After about a year it seemed obvious that I would need to speak to people to order “Fish n Chips” and stuff like that.
Anyway I got these CD’s to teach me French and the bloke (can’t remember his name) started off by telling you not to remember anything he told you.
Reverse Psychology
I think there is a bit of reverse psychology going on but the main idea is that you understand not remember. It didn’t work for me because I still managed to completely fuck up the language.
Not realising French Canadians speak differently to native Frenchmen (I was working for Bombardier) . Anyway I asked this bloke, in French, to “will you come with me”. I can’t remember what it is in French and after all the bloke on the CD had specifically told me not to remember.
Anyway turns out this had a sexual connotation and made me the complete laughing stock everywhere I went from then on. (I’ll let you do the maths on that one.)
“OK which one of you bastards bought all the fuckin toilet paper in lock-down?”
Now I know what you are thinking, “that is the gnats cock of CNC Turning G Code Lists”. Honestly size isn’t everything.
Learn these first and just by seeing them every day they will just sink into your brain.
When it comes to CNC Programming it is important to enjoy your self and not get bogged down trying to remember loads of G Codes.
The truth is you only need to remember a few and it’s all about understanding what they do.
For Example This is in your Programme.
You watch in amazement as it cuts your part.
So you look up what G71 means on your list of G Codes printed in large letters on the side of your machine.
“Oh yea it’s that’s roughing shit” you say.
As You Watch it Run It All Makes Sense
From your Classroom Training you know that there is a multi repetitive cycle that can rough out a part.
You understand how the cycle works already.
G71 Rough Turning Cycle
So as it runs, it all makes sense.
Keep it Simple
Type up or print this list in nice big letters and stick it to the side of your machine
G00                 Move at Rapid speed
G01                 Feed in a Straight Line
G02                 Clockwise Arc
G03                 Counter Clockwise Arc
G04                 Time Dwell
G28                 Return Axis to Home
G41                 Cutter Compensation Left
G42                 Cutter Compensation Right
G40                 Cancel Cutter Compensation
G50                 Maximum Spindle Speed
G54                Work Offsets
G71                 Stock Removal Cycle
G70                 Finishing Cycle for Above
G76                 Threading Cycle
G83                 Peck Drilling Cycle
G96                 Constant Surface Speed
G97                 Speed in RPM
This article is about using G10 on a CNC Lathe to set the work shift or work zero offset as it is known on a Haas control.
If you have ever used Mazak machines you will know that when you call a program the work offset is kept with it.
Obvious really……
I mean if you were teaching your dog or your cat to program a CNC Lathe and you told him that he had to reset the workshift every time he called a new program what would he say.
I mean nothing really but he’d probably give you a strange look.
But you can do it on a Fanuc control or on a Haas control.
You just put this………………….
G10 P0 X0 Z-98.1
Using G10
So you would put that at the head of your program and it would change the work shift screen as above.
Advantages
No need to set workshift everytime.
Automatically sets X figures so there’s no chance you could alter it by accident.
Well there is a slight catch.
It’s obvious really but from now on you can only change the workshift from the program.
If you altered it on the workshift screen it would just change back when you run the program.
Now I know your not stupid enough to do that but I bet the bloke on nights is.
The Big One
When you restart a program you must remember to read this line.
Imagine if you tried to re-run the threading tool after altering the G10 you would just jump to that tool and run it. (Your new offset wouldn’t work)
Therefore you must remember to make the control read it in before running any tools.
Now the clever bastards will have a solution to this.
(This songs hilarious by the way)
What you could do is use a subprogram, if you had one for tool change position you could dump the G10 there.
That way each tool would read it.
Oh yea and it’s probably a bit more tricky to alter as you can’t use input plusUsing G10
So you have to revert to mental arithmetic.
Ok So Why Do I Need All This Crap
Do you use the same chuck day in day out?
Do you keep the jaws for each job?
Well if the answer to these questions is yes, your workshift value is the same every time you set up this part.
Do you really want to reinvent the wheel?
