Category Archives: Fanuc Turn
Tool Nose Radius Compensation CNC Lathe
On or Offsite CNC Training
Tel: David 07834 858 407
CNC lathe tool nose radius compensation, I think that sometimes in life we get off to a bad start with things. I know when I was at school I was convinced that I was useless at French, Physics and all sports.
I just got off to a bad start.
Getting stabbed with a javelin in the foot did not enthuse me with regards to sporting activities.
Tool Nose Radius Compenasation
Oh and two of my close friends wanted to see if passing a high voltage though my body would give me special strengths a bit like Frankenstein. Needless to say it didn’t work and to this day I can’t watch those films.
So when you have a bad experience with something it just puts you off.
Maybe when you first tried to use G41 and G42 you got loads of ALARMS. Not to mention that nasty rash that you needed a three month course of antibiotics to clear.
We often find ways around our lack of knowledge or whatever.
I know when I was in France my mate always spoke English in a kind of French accent thinking they would know what he was on about. He would put an “a” at the end of each word.
He would say “doa youa knowa thea timea” and they would say “Va te faire foutre”
Here is the video (DON’T YOU DARE WATCH IT YET)
Sorry about the long intro but I have a record to sell as well.
Anyway, Tool Nose Radius Compensation.
People find ways of programming without tool nose radius compensation.
It surprises me when people don’t use it and it is usually because they don’t understand the very simple rules.
Rules CNC Lathe tool nose radius Compensation
The daftest one being, don’t ask it to do the impossible.
So if you are machining a diameter of say 40mm and you move to a bigger diameter 40.5
If your tip radius is 0.8 the machine would alarms out.
You swear at the machine but unfortunately it’s you that’s being a prick. You can’t fit a .8 radius in that gap.
TNRComp
The same thing applies if you machine around a radius that is smaller than the tip radius.
The other common fault is knowing when and where to apply it. (A bit like lip gloss.)
Your shape needs to be one continuous path that does not go back on itself.
No reverse gear.
I always say “use it and get rid of it”.
You can’t just move on to another shape.
You need to cancel and then re apply.
If you don’t use compensation your parts are not really correct because you are frigging the figures. You naughty naughty boy.
The other big problem is if you need to change the tip radius and you didn’t use tool nose radius compensation you would have to change the program.
Your program and part will simply be wrong without tool nose radius compensation that is unless you are only machining orthogonal lines. (Some of my readers will need to goggle that)
If your CAD system is not outputting tool nose radius compensation or cutter compensation in milling then you need to look at your post processor.
If you can’t do it get your software provider to help. Believe me they can all output this if they are set up correctly.
CNC Sub Program
CNC Sub Program, all CNC machines will have some form of sub programs.
 This article deals with G code (ISO) type programming but most of the features talked about will be available in some form on any CNC control.
A CNC sub program is a branch from your main program into another program.
After completing this, your control will return to the main program and continue where it left off.
It’s like the branches of a tree.
Sub Program
Probably the most common use of a CNC Sub Program would be for a tool change position. You could have a sub program which took the machine to a position for tool change. Your machine probably does this anyway but it’s hidden.
The advantage of this is that you could use it for any program and you don’t have to keep writing it. It is going to be very reliable because you know you never touched it. (Honest governor).
You could use a sub-program for a set of hole positions, call it out once to spot drill and again to drill and again to tap. Just use it as many times as you want.Got to be good for the environment too.
CNC Sub Programme
Some controls have internal sub programs Haas and Yasnac as well as Heidenhain and Siemens have this facility.
You can do it on a certain Fanuc controls but it is an option.
It means you can stuff these at the end of your program and jump into them the same way as you would an external one.
CNC Sub ProgrammeCNC Sub ProgrammeCNC Sub Programme
Why would I want to do that you say?
Easier to manage is the quick answer.
You know when you save your main program there are no pesky sub programs lurking that you forgot to save. They are all built into your main program.
Normally you would call your sub-program once only and you don’t need to tell it “oh I want this once” it says “come on mate I know that I’m not stupid.
But you can call it several times and if you get into incremental programming, and I hope you do, you will definitely find a need for this.
Sometimes with sub-programs it’s what you don’t put in that matters. What I mean is if your milling and you put the feed in the sub-program you are stuck with it. If it’s not there then you can state the feed externally and use a different one every time.
Tosnuc 888
It uses G72 followed by the dollar sign, oh and for the repeat command it uses L but don’t forget the comma.
G72 $MYPROGRAM , L2
Yes Tosnuc uses anything for a program name up to eight characters. So that it doesn’t get confused by the L you have to put in a comma.
Tosnuc 888
By the way on this control (Tosnuc 888) you don’t use M99 at the end of your sub program you just use M30 and it works correctly.
Don’t try this on your Fanuc or Haas control as M30 means stop and rewind and that’s what it will do. Then it will just sit laughing at you.
Ok now you can watch the video.
CNC Milling sub programming examples.
  • Fanuc programming training.
For On-site CNC Training Contact David: 0783 858 407
G84 is a tapping canned cycle.
G84 taps holes.
This simple part has four M12 holes, drilled, countersunk and tapped. The datum is the centre of the part so the holes positions are.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
The G95 selects feed per revolution which means we only need to program the tap pitch for the feed-rate.
See full rigid tap G84 Rigid Tapping Program Example
The M29 engages the rigid tapping mode and the S800 is the speed. (It does not start the spindle)
The G84 Cycle instructs it to tap a hole 17.mm deep (Z-17.) at a feed of 1.75mm per revolution (F1.75)
So it feeds at 1.75mm per revolution with the spindle turning clockwise to depth.
At the bottom of the hole it reverses the spindle and feeds back to the initial point.
This initial point was in the line.
This is because of the G98.
Once the cycle is active each time it sees a position it repeats the tapping process.
When the G80 is programmed it no longer taps holes.
Single block and feedhold do not work in a tapping cycle.
Why? You ask.
IT BUSTS THE TAP
Now watch the video to see it all in action (not breaking the tap).
G0 Cancels Canned Cycles
G0 Cancels Canned Cycles, this is not a news flash it’s always been the case.
O0001(G28 Example)
(PROGRAMMED BY ANDY MURRAY)
G21 G90 G40
T01 M06(20MM ENDMILL)
G90 G0 G54 X200. Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-5. R1. F100.
X100.
X50.
G0 X25. (No hole drilled here cycle would be cancelled)
G80 (This also cancels the cycle)
G28 G53 Zero Return
G28 G53 Zero Return
CNC Training (Call David: 07834 858 407)
G28 G91 Z0                   (Z axis moves up to tool-change)
G28 G91 X0 Y0 Z0        (All three axis move to their respective zero return positions)
If you programmed
G28 G90 Z0 or you forgot the G91 this means return to zero point via a reference point. The reference point is Z0 so the spindle would rapid to Z0 (Bang) and then move up to reference return point.
G28 G53 Zero Return
Using G53
G53 Z0
You need to write
G53 Z0
G53 X0 Y0
Note:
T01 M6
G53 Z0
T01 M6
Tosnuc 888
Tosnuc 888
If you have any questions about G28 G53 Zero Return or you are affected or have been affected by any of the issues in this post please contact me 07834 858 407
