Day: December 3, 2025
CNC Programming Safely Using Decimal Point
CNC Programming Safely (Decimal Points)
CNC Programming Safely is very important. This post explains about the role of the decimal point.
Decimal points who needs em eh?
On Fanuc controls and Haas controls depending on the setting of a parameter if you input something like X20 it can be taken in two ways.
(1) X20 is taken as a movement in X of 20mm this is like a calculator and some controls will convert this to 20.000 for you.
(2) X20 is taken as 20 microns which would be .020
The difference between 20mm and .02mm is massive would you agree?
This also works on feed rates so you could be waiting a long time. Or the other way around you end up with a pile of broken tools.
The most dangerous one is with offsets this will definitely cause a collision.
I remember those things in comic books where you have to find the difference between two pictures. The difference with a CNC Machine is it can cost you your job if you don’t spot the missing decimal point.
Even at five years old I couldn’t really be arsed. I remember swearing for the first time and thinking “fuck this, pass the water pistol”
Sorry this is not true, obviously I was swearing long before my fifth birthday.
Please contact me with the answers to the quiz above (that way I’ll know never to offer you a job)
Decimal Points
Now you could go diving for your manuals and check your parameters and settings. I don’t actually recommend that right now.
Think of people like me and all those applications engineers who work here there and everywhere.
It maybe that in your company you have machines set in different ways and that’s gonna be real confusing.
It is obviously a good idea to have all your machines working in a similar manner if possible.
So in order to do your CNC Programming Safely I recommend that you make a rule when you are inputting code.
Always include a decimal point regardless of the control settings.
That way whatever your machine setup you will still get the right movements and offset adjustments.
Never Use a Decimal Point (CNC Programming Safely)
M codes
S Codes
G codes although there are exceptions such as G54.1
H numbers
T codes
L
N numbers
O (Programme numbers)
P  address
And if you do you will get an alarm. There are exceptions to these rules but you would need to check your programming manual.
B   address
C   address
D  address
E   address
F   code
I   address
J   address
K  address
Q  address
R  address
U  address
V  address
W address
X  address
Y  address
Z  address
I have trained people who insist on programming X0.0 and that is ok if it helps you to remember the decimal point. Even though on X0 it would make no difference but rules are rules.
Just remember that if you change companies it will be very hard to break the habit if you are not inputting decimal points.
It’s a bit like keep putting your hands down your trousers. When your at home it’s a minor bollocking from the wife.
Try it in public and you’ll end up on the sex offenders register.
Those using CAD/CAM systems it is quite easy to change your post processor to always output decimal points too.
Here is the Fanuc parameter that you can alter.
Click Me
Mazak Spindle Warm Up Macro
Warm up Programme
This Mazak Spindle Warm Up Macro is something I created recently for the Macro training course that we offer at the CNC Training Centre. The course covers Macro Programming suitable for Haas, Mazak and Fanuc.
I must admit I often think that with Macro programming a little knowledge is a dangerous thing. On visiting companies I just think it’s more about a programmer’s ego than really getting good CNC code.
See this article, it gives a brief description of macro programming.
If you just want the Mazak Spindle Warm Up Macro then just jump to the end and copy it. I won’t be offended by the fact that you are just too selfish and greedy and can’t even spare the time to read my articles that I slave for hours to produce!
Gratuitous use of macro programming (that’s bullshit to the normal folk), can be dangerous and really confusing to the operator using it.
  • A macro can automate a regular task.
  • Families of parts can be grouped together and simplified in one programme.
  • Macros should be fool proofed with alarms to prevent erroneous input.
  • The details of the macro ideally should be protected (ie lock the 9000 programmes).
  • Where possible alias the macro to a G or M code.
  • The machine operator is your customer so treat him or her well.
  • If you don’t like re-inventing the wheel every day then macros are for you.
  • Don’t forget to check if you have the macro option on your machine it can be quite expensive to add. Oh and it will really piss you off if you read this whole article and find you ain’t got it!
Some Explanation.
This macro (Mazak Spindle Warm Up Macro) is for the warming up of the spindle, it’s a much smoother warm up because it does not take big leaps in speed. It is a much more gradual approach.
You tell it your maximum rpm you want to warm up to and the time you want the warm up to last. You can tell it what RPM increase you want as a step. You also tell it the initial speed you want your spindle to start at from cold.
It goes on to calculate the difference between your start speed and your maximum speed. It divides this speed by the speed increment that you give it. This will tell it how many times to go around the loop.
In the loop it uses the machine timer. It zeros the timer then runs it for the calculated time for each step.
It has to then get this time in milliseconds because that’s what the geeks use in these machine timers.
Ideally it should be aliased to an M code.
Alias WTF? No it’s not like changing your name from Reginald Kenneth Dwight to Elton John it is a bit more sophisticated.
What it means.
Well it means you can access a programme using your own G code or M code.
So for example if you put 200 into parameter 92 when you programme a G200 it will jump to programme 9011. Just as if you had put M98 P9011 or G65 P9011. With a G code you can pass arguments to the programme a bit like G81. In G81 you tell it the depth and rapid point these are the Z and the R values. Now you can do the same with your G code.
Also for parameter 82 if you put 33 into parameter 81 when you programme M33 the control will jump into programme 9001. You cannot pass arguments when you use an M code. Best not to argue then eh.
So for my Mazak Spindle Warm Up Macro we will use M33 and alias it to programme 9000. So having done all this you can lock out programme 9000 so no one can even see it. (Our little secret). They will not be able to edit it either.
All they need to know is that M33 will run the Mazak Spindle Warm Up Macro.
M33 is aliased to O9000
Now then a word about testing.
Actually it’s more than one word but here we go.
When you test your macro you need to stop your control from looking ahead, put the blinkers on as it were.
(Sorry that’s totally wrong blinkers actually make a horse look ahead and not to the side).  Anyway CNC controls have to look ahead and here is why.
Cutter Compensation.
Below is a typical tool path where the tool is compensated to the left. In order to machine the part without cutting into it the control needs to read in front.
As it moves up the left hand side it needs to know where its going in advance, moving round the outside in single block it would stop here.
If it were about to cancel the compensation it would end the move here.
If it were about to go to the left on the inside it would need to stop here.
They would all be the same Y position but in single block it stops ready for the next move (three different places).
So this explains why the control looks ahead. Each move relies on the next for correct positioning.
When we write a macro programme and we are testing it this look ahead is a real nightmare. The system often will know the answer before you think it has seen the question.
Complicated?  mm read on:
Right joking aside, what we do is to use a G code to stop the system from looking ahead. What we can then do is single block through the macro and check the calculations as we go.
When you are happy with the code you can let the system look ahead again by turning look ahead back on.
Although what you are doing may be very simple, a very small mistake can really bugger things up. (Sorry for saying bugger, I meant knacker).
Have a System.
Now my advise here is to be very systematic in your approach and test each line of your macro as you go. Be happy that each line works ok before you move on to the next.
You can try it this with the Mazak Spindle Warm Up Macro below. Turn off the block look ahead and the single block restriction and check each variable as it is changed. It will help you to understand how the Mazak Spindle Warm Up Macro works.
Oh one other thing plan your macro before you start don’t get to excited and rush on. Also keep a record of what variables you have used so that you don’t accidentally use a variable twice. Things can get very scary if you do this.
Comment, comment, comments and more comments to say what the comments are for. Honestly you can’t have too many comments in a macro. The best approach is to imagine that you were abducted by aliens (I sincerely hope you never are) but if you are the will anyone understand your code?
If the answer is no then you are not explaining your code well enough. Also if you are like me and you have a poor memory then you will need them for yourself. So when you look back at this macro in 200 years you will know what it meant.
Check this article on how to lay out your CNC code and add comments.
“The code give us the bloody code?”
OK.
So here is the Mazak Spindle Warm Up Macro.
I hope it works for you.
PLEASE DO NOT USE THIS MACRO IF YOU ARE UNDER 18 OR ARE OF A NERVOUS DISPOSITION
Oh by the way if you get bored easily then I definitely wouldn’t read all this. Just put the code in your machine and enjoy it with my compliments (thicko).
O09000 (Mazak Spindle Warm Up Macro)
#100= 20. (TIME)
#102= 500. (RPM FROM COLD)
#103= 7000. (MAX RPM)
#105= 1. (RPM STEP)
#106= #104 / #105 (LOOP)
#107= #101 / #106 (DWELL)
WHILE [ #3001 LT #107 ] DO2
END2
END1
#3004= 0 (OVERRIDE BACK ON)
Boring, boring so what does it all mean?
Explanation of  Mazak Spindle Warm Up Macro
#100= 20. (TIME)
#105= 1. (RPM STEP)
END2
END1
(Override works again.)
Single Block
You can suppress single block in a macro. You can suppress single block in this macro (Mazak Spindle Warm Up Macro) because it is really annoying if you expect your spindle to warm up in 30 minutes. You come back having made tea, toast and croissants (as us engineers do).
“Shit” you say “the machines been on single block and stopped at 500 rpm for 30 minutes”
Just add these.
#3003= 1 (SINGLE BLOCK OFF)
#3003= 0 (SINGLE BLOCK ON)
I have suppressed spindle override because you need the correct speed in a spindle warm up programme.
If you read the explanations above you will see how it works.
CautionSwitchSingleBlock
Oh and by the way here is a similar article for a Haas or Fanuc type machine.
Haas Reset Program Pointer Setting 31
Another setting to look at: Haas Reset Program Pointer. This setting means that when you press that dirty old RESET button.
If it’s set to on your program will return to the start. If it’s set to off then your program pointer will remain in the same place.
And this is what Haas have to say
We really love you but honestly we don’t really care if you break your machine. However if you do, make sure you youtube it. Then you could make a shit load of money from the video.
Oh yea we do CNC Training too, not to mention Classroom Training.
Siemens Sinumerik 840D 828D training
Parameter 3109 Display W and G
People who know me know just how boring I am. Today I’m going to confirm this by getting very excited about this parameter.
Parameter 3109 bit 1 (#1) DWT will make the display of wear offsets loose that confusing W and G.
Stay here I’ll explain more.
Parameter 3109, to change this parameters first you need to go to the setting screen in MDI.
Today we are going to change the parameter that stops the offset page displaying G and W.
Bit 1 (#1) DWT make this a 1 to stop this being displayed.
So when you change this parameter you won’t see a W beside the offset number in the wear screen. You also won’t see the G beside the tool number in the geometry screen.
I know for a fact when training people that this really confuses them. Especially the the G on the geometry screen.
This is it before with the W
Parameter 3109
This is it with the parameter change good old fashioned numbers.
Parameter 3109
As in the book
Parameter 3109
Bits n Bobs
Other Parameters Of Interest
1300 Stops over travel alarm
3101 Clear Screen
3102 Unlock Programs
3203 Clear MDI Screen
Do yourself a favour take a picture of the screen before you change a parameter. If you ain’t got a camera then you must have a piece of paper.
Brother CNC Training On-Site: SPEEDIO Operator Courses
How to Operate a Brother CNC Machine: Master It in Days with Our On-Site Training
Looking for a straightforward guide on how to operate a Brother CNC machine — or better yet, someone to come to your shop and teach your entire team hands-on?
Brother SPEEDIO machines (S1000X1, S700X2, R650X2, M140X2, etc.) are some of the fastest, most reliable compact machining centres on the market — but only if your operators truly know how to run them safely and efficiently.
Instead of piecing together YouTube videos and manuals, bring in the experts.
We Bring Brother CNC Training Directly to Your Shop – 100% On-Site
No travel expenses for your team. No production downtime sending people off-site. We come to you, train on your exact machines, using your fixtures and your parts.
On-Site Brother CNC Training
Control Panel
Our On-Site Brother CNC Training Programs:
3-Day Operator Essentials
  • Full machine familiarisation & safety
  • Power-on sequence, homing, manual movements
  • Work offsets, tool length setting, and tool data management
  • Loading programs, dry runs, graphic simulation
  • Running proven parts with your tooling
  • Troubleshooting common alarms Your operators will be confidently running production parts by the end of day 2.
3-Day Advanced Programming & Optimisation
  • Everything in the above course +
  • High-efficiency toolpaths for 4+1 axis SPEEDIOs
  • Custom macro programming and variables
  • Pallet changer
  • Cycle-time reduction techniques that Brother owners love
Custom Training Packages Tell us your biggest pain points (setup time, scrap, crashing tools, etc.) and we’ll build a program around your specific needs and machine models.
Why Machine Shops Choose Our On-Site Brother CNC Training
  • Zero travel cost or lost time for your team
  • Years of onsite training expertise
  • Training happens on your actual machines and parts
  • Immediate ROI — most shops cut setup times massively after training
  • Flexible scheduling around your production needs.
  • Groups up to 4 cheaper than sending offsite.
Stop guessing how to get the most from your Brother investment.
Brother Speedio
Get Brother CNC training brought directly to your facility.
Master how to operate a Brother CNC machine — the right way, in your shop, on your schedule.
Onsite Brother CNC Training
