Category Archives: Fanuc Turn
Basic Turning
Basic Turning
G96 Hamsters Large wheel Small wheel
G97 Speed In RPM
G97 S1500 M3
When drilling  a hole you are on the centreline of the machine so you just want plain old simple RPM.
G96
G96 S200 M3
Basic Turning
If the tool was positioned  at a 100mm diameter it would be as if the tool were able to run around this diameter at  a speed 200 meters a minute.
Basic Turning
Neeeeeoooooooowwww
G96 G97 hamster on a Wheel
Anyway I did and his name was Harold Wilson (British Prime Minister at the time).
Basic Turning
G96 G97 all about hamsters
Harold Had G96
Harold Was a Clever Bastard
200 / .6864 = 291
Manual Lathe
cnc turning basics
G50 Warning
Watch the video
Basic Turning
G96 and G97
G96 Whoopee It’s amazing
So use G96 for everything.
Except for:
  • Drilling.
  • Tapping
  • Threading (Screw cutting)
  • Cutting the Lawn
Modal and non modal G codes
Let Me explain
We all know that programming can be complicated. So let me explain to you how it all works. This article explains the real meaning of Modal and non modal G codes.
Modal means that once a command is issued it stays in the control.
How Can you Actually Use This?
If you issue a G0 or G00 command the machine is in rapid and you do not need to re-state it.
Rapid means all motors are flat out, like a teenager in a Ferrari.
Every move from then on will be a rapid move unless you tell it otherwise. The G code that changes it must be in the same group. For example G0 G1 G2 and G3 are all in the same group a bit like The Beatles used to be.
The other day I was talking to  a “young person” who hadn’t even heard of the Beatles. I mean fuckin hell, am I really really old or are they doomed to be forgotten?
Fanuc Display – Relative Position
Fanuc Display
You can reset Fanuc Display (Relative Position) just like you would on a manual machine with a DRO. So use it for setting or even measurements. One thing to remember is it will not retain it’s position when you turn the machine off. The control in the video is a Fanuc 18i on a big vertical lathe but all other Fanuc controls are similar.
Subscribe to my YouTube channel (I beg you)
Webster & Bennett with Fanuc 10T
I Just Love Old Machines
I recently got to train someone on one of these, a Webster & Bennett with Fanuc 10t Control.
Webster & Bennett
It’s what I crudely call a big bastard. But bastard it is not, it can definitely machine some big shit
Webster & Bennett
Like this monster.
Don’t ask me what it is or I would have to kill you. Joking aside I think it’s a water valve. Beware these jacuzzis use a lot of water,
The machine is a Webster & Bennett vertical borer and I think the Fanuc 10t control was possibly a retro fit.
When these start whizzing around even a few RPM it can scare the living shit out of even the most seasoned engineer. And me, well I,m more seasoned than a piece of Nando’s chicken.
G50 on a Webster & Bennett Your Best Friend
Anyway joking aside your best buddy now is definitely G50 get this wrong and it’s fuckin world war three.
Imagine the scenario, you program G96 S180 M3. Spin at 180m/min. Not too fast but…. what if the tool is sat in the middle of the part.
Machine says “come on lads happy days foot to the floor flat out joy riding” and it fucks off like two teenage boys in a stolen Lamborghini.
So without a G50, or the wrong speed, this beast will accelerate to it’s maximum rpm.
Oh and did I Mention it’s harder to stop than a P & O Criuise Ship with 4000 obese pensioners on board?
Ten Things You Might Not Know About The Fanuc Sub Program
Sub Program Fanuc
Here are ten things you might not know about Fanuc sub programs,
Fanuc CNC controls are the most common controls in the world so it might be useful to have a good understanding of how sub programs are called and used.
(1) You Can Call a Sub Program By Name.
Yes you heard it here the program can be called by it’s name or it’s number. When calling by name don’t use the P.
Just put the name of the program in these things <> with an M98 and your away.
M98<ALBERT>
The only problem with this is that the syntax needs to be spot on so if you have got complicated names for your your sub routines then you might be in the shit.
I always call mine names like ALBERT that are easy to remember.
(2) You can use internal sub routines on a Fanuc Control.
Some people call these local sub programs. It just means it’s tagged on the end of your program which makes them nice n easy to look after. A bit like a pet Goldfish or a pet fly.
I bought mine from the local pet store. I asked the assistant if he sold pet flies and he said no. I said “well there are loads in the window”.
Anyway he sold me one (£15) his name is Paul
This is not him this is Steve.
Internal Sub-Routines
By typing M98 Q500 your control will look for N500 within your current program. This is great because you can add the sub programs to the end of your main program. Don’t forget to leave big gaps so you can clearly see where and what they are. Oh and mind your P’s and Q’s.
M98 P500 (Call O500 externally)
M98Q500 (Call N500 in main program.
Oh and read this too.
Sub Program
Just one other thing. Watch your n numbers it’s easy to get them mixed up. Try and use a convention.
