Star Mechatronics Search Paths
Onsite Training Enquiry
On a sliding head machine you are running two simultaneous programs. It can be quite difficult to see where various wait codes synchronise.
First of all you need to be in the edit mode.
Cursor across until you see SYNC SCROLL
Now press it
The SINGLESCROLL button will take you back. Now as you cursor through both programs will scroll together. When you find a wait code it will turn blue. The opposite screen will keep scrolling till it finds the corresponding wait code.
Press the TOP button to return to top of program
BOTTOM will take you to the end
If you type in a wait code number for example 200
When you press M.NUM it will find it. Use the NEXSYN to jump to next wait code and use PRESYN to get to previous sync code.
Learn loads more Fanuc stuff on this website
Star SB-20R Parts Counter Screen Fanuc Oi TF
Operator Training beginners to Macro programming.
Star SB-20R Set Parts Counter
This machine is a sliding head CNC Lathe it runs two simultaneous programs. This article shows you how to set the parts counter screen to your required number of parts.
It also shows how to reset back to zero after your parts have been completed.
The machine is a Star SB-20R sliding head.
In your program an M20 tells the counter to add one part to its counter, there it is in yellow on the left hand screen.
Now press your CSTM GRPH key
This is the page you want to see.
You may need to press the green OPRT button below to find the screen.
Press COUNTE and you’ll get to this.
Press the ON/OFF key to switch counter on and off.
Edgecam Training
If you require Edgecam Programming services: 07834 858 407
Sub Contract Programming
Edgecam Classroom Training
This two day course teaches you to program from a basic part in Edgecam right through to machining on a real machine.
Learn to create a CNC program from lines or a solid model then post out the code you can then run it on a real CNC Lathe or Milling machine.
This course is designed to get you using Edgecam in the real manufacturing world.
The course is at our training centre in Barwell, Leicestershire, England
Apply Now Edgecam Turning
Apply Now Edgecam Milling
For more details or for on-site CNC Machine training
Call David  on :07834 858 407
Edgecam Onsite Training
Edgecam Articles
Layers in Edgecam
Edgecam Version Update Now
CNC Programming Using CAD/CAM
CNC Programming, When will it not be needed?
CNC Programming Services Call David: 07834 858 407
858 407
Are we fast approaching the day when we don’t need to know anything about programming in terms of G code etc.
CNC Programming
Tool Holder (Patent Pending)
Short answer is yes.
I was watching an interesting video on youtube the other day. This guy (seemed like a very clever guy) had bought an old CNC Lathe, a Mori Seiki.
I don’t think he had ever done any machining or general metal work type stuff.
His approach was untainted shall we say. He’d certainly never done any G code type CNC Programming.
CNC Programming
He immediately looked for software which would program this machine and said how in the past it would have been programmed with G code by hand.
Anyway he got something like One CNC or Fusion 360 and created a program. He went on to produce quite a few parts.
Really this proves that you don’t need to know G Code programming, or does it?
Because I am an old dinosaur and I make a living partly from teaching people G code type CNC Programming, I wonder if people like me are clinging on to these old skills and not moving forward.
It reminds of the times when CNC’s were first introduced all the old guys used to say they would never replace the capstans and autos. I remember my dad beating my first chess computer and saying it was just a gimmick.
CNC Programming
So what problems do you get when programming straight from software. Actually if you know what you are doing the answer is none. But do you know what you are doing?
The danger is when the person using the CAM system doesn’t really understand about work-holding and tooling.
I bet the aforementioned guy had some serious problems with his selection of cutting tools.
Sub Contract CNC programming UK – Edgecam Experts
Reliable, Expert Support for Your Machine Shop
At CNC Training Centre, we don’t just train CNC operators and programmers — we deliver high-quality sub-contract CNC programming services to machine shops, precision engineering companies, and manufacturers across the UK.
Whether you’re overloaded with work, facing a skills shortage, or need specialist multi-axis programmes written quickly and efficiently, we are here to keep your machines running and your production on schedule.
Why Outsource Your CNC Programming?
Modern CNC machining demands more than ever: tight tolerances, complex 5-axis components, exotic materials, and ever-shorter lead times. Many shops struggle to find (or retain) skilled programmers, especially for advanced work.
Outsourcing your programming to us gives you:
– Instant capacity without the cost of a full-time programmer
– Reduced downtime — get proven, optimised programmes delivered fast
– Access to specialist expertise in multi-axis milling, turning, turn-mill, and advanced CAM strategies
– Cost-effective flexibility — pay only for the programming you need
– Peace of mind from programmers who train others for a living
We understand the real-world pressures of sub-contract machining. Our programmes are written to run reliably on the shop floor, with efficient toolpaths, realistic cycle times, and clear documentation.
What CNC Programming Services We Offer
We provide comprehensive offline programming support for a wide range of controls and machines, with a particular specialisation in Edgecam (now part of Hexagon’s powerful CAM suite).
Our services include:
– 3-axis, 4-axis & 5-axis simultaneous milling (vertical and horizontal)
– CNC turning and multi-axis turn-mill (including sliding head / Swiss-type)
– Complex surfacing, 3D contouring, and high-speed machining strategies
– Edgecam Post-processor customisation and optimisation
– Toolpath verification, simulation, and collision avoidance
– Programme editing, optimisation, and troubleshooting for existing jobs
– Support for prototypes, small batches, and production runs
Because we specialise in Edgecam, we can take your solid models and quickly produce efficient, reliable CNC code — often faster and more consistently than generalist programmers. We also work confidently with other major CAM systems and popular machine controls such as Fanuc, Siemens, Heidenhain, Mazak, and more.
Who We Help
Our sub-contract programming clients typically include:
– Precision engineering and sub-contract machine shops
– Aerospace and motorsport manufacturers
– Medical device and implant producers
– Prototype and low-volume production companies
– Businesses experiencing peak demand or staff absences
Whether you need one urgent Edgecam programme or ongoing support during busy periods, we tailor our service to fit your requirements.
sub contract CNC programming UK
Competitive Rates & Flexible Delivery
We offer realistic, value-driven hourly or project-based rates for sub-contract programming in the UK. Remote/offline programming keeps costs down while delivering fast turnaround — typically within days, not weeks.
Many clients find our Edgecam-focused programming support more cost-effective than hiring temporary staff or struggling with in-house bottlenecks. We can also combine programming with on-site training if your team needs upskilling at the same time.
Why Choose CNC Training Centre for Programming?
– **Deep Edgecam expertise** — we specialise in Edgecam and train CNC professionals on it every week, so we stay at the forefront of its powerful features and best practices
– **Practical, shop-floor focused programmes** — written by people who understand machining realities, not just theory
– **Proven track record** in delivering reliable, efficient code that minimises setup time and maximises machine utilisation
– **UK-based service** with fast response times and clear communication
– **Training expertise as standard** — if your operators need guidance on running the new programmes, we can support that too
Get Your Machines Producing – Not Waiting
Don’t let programming bottlenecks hold back your business. Whether you have a complex 5-axis aerospace part, a tight-deadline prototype, or a sudden surge in orders, our Edgecam specialists can help you deliver on time and to the highest standard.
Sub contract CNC programming UK
Contact us today for a discussion about your programming needs — especially if you use (or want to get the most from) Edgecam.
Call us or email with details of your machines, controls, CAM software (Edgecam or otherwise), and the type of work you need programmed. We’ll provide a quick, competitive quote and realistic lead time.
**Ready to keep your CNC machines cutting?**
Get in touch with the CNC Training Centre team now.
Programming Call David: 07834 858 407
