How to Make a Program Active Fanuc 0i-TF
Category : New Stuff
35 five star ratings on Google (just saying)
Why do You Make a Program Active Fanuc 0i-TF?
In order to run or edit a program on a Fanuc control you first need to make it active. On a Fanuc control you are editing in real time so you don’t need to save your work. Unfortunately any edits you make are permanent.
This step-by-step guide shows how to Make a Program Active Fanuc 0i-TF control, specifically on a **Star SB-20R Type G** sliding head lathe, which uses a dual-path (two-channel) setup.
First of all you need to be in the EDIT mode.
Press PROG to view your program.
Now press FOLDER to see a list of programs.
Use your cursor to move down to your program.
Press the OPRT for more options
Now press MAIN to make your program active
The @ or “at” symbol means this is the active program. Program O0007 is now your active program.
Another way is to type in the number of the program you want to make active O3 or O0003 for program 3
