Category Archives: Haas Mill
Cutter Compensation
Cutter compensation explained.
This is a video explaining cutter compensation in CNC programming.
  •  Tool cutter comp.
  •  CNC cutter comp.
  •  G41 G42 cutter compensation.
  •  Cutter diameter compensation.
  •  Cutter radius compensation.
  •  Heidenhain RL RR.
Cutter Compensation
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool.  This depends on your settings.
Cutter Compensation
(Cutter compensation G code)
  •  G41 cutter compensation left
  •  G42 cutter compensation right
  •  G40 G code to cancel cutter compensation
This Video shows you :
  • How to program G41.
  • How to program G42.
  • CNC cutter compensation examples.
  • Cutter compensation Heidenhain style.
  • Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
Cutter Compensation
Cutter Compensation
Cutter Compensation
Cutter Compensation
Rules are the same as the tool nose radius compensation on a CNC Lathe.
If you programme a shape and you do not use cutter compensation you will have to work out the size of the shape with your tool radius added.
  • What will you do when your cutter wears?
  • What if you want to use a different size cutter?
  • The cutter may not run true.
  • What if the cutter is not exactly size?
Cutter Compensation
The Rules:
  • Shape must be continuous and consistent.
  • You can’t cut along a line and then go back along it.
  • It’s important to allow more than the tool radius when entering tool compensation. The same applies when you come out of tool compensation.
  • Internal corner radii and steps must be greater than the tool radius.
Don’t ask
Cutter Compensation
Cutter Compensation
Call 07834 858 407
Haas Super Mini Mill
I’ve wanted to get my hands on a new Haas machine for a while. Really wanted to see what the new control was like.
Haas Mini Mill
Stiltz provided the machine and the victims for the training.
If you have read any of my articles you will know I have always had an affection for Haas machines. The first one I ever worked on being about 1994. At that time they were nothing short of ground breaking innovation.
Things like a built in airline and coolant wash-hose were not only innovative but really useful.
Coolant Hose (What Will You Do With This)
A machine that worked straight out of the box. Easy peasy tool-change. Handwheel to scroll through the program, people still get impressed by this today.
Programmable coolant nozzles, fuckin hell that was a game changer. Just move nozzle to a position and press an F key and it’s stored with the offset.
Macro at no extra cost (wow) some people wanted two grand for this (cost of a good family car in 1995)
Program restart still the best in the world, don’t get me started.
The New Machine David How Was It?
To start with on this one I didn’t like the interface but it does grow on you. You need to get used to using the touch screen. Access to some menus is a bit convoluted too.
This Haas Mini Mill has a 10k spindle and 30 tools.
Something I suddenly remembered about this model. Well you know when you get a cup of coffee and it’s in a tall tapered glass mug? You are thinking “nice big cup of coffee”. You take four big swigs n it’s gone, shit what happened. What happened is an optical illusion because the cup is tapered it’s actual capacity is that of a thimble.
It happens all the time everything comes in a great big box with loads of packaging and the actual item is minute.
Anyway try moving this machine to the end of it’s stroke in X. Fuckin hell what a disappointment I recon you can only move around about half the table. I mean great you can put a pretty big part on here. That’s great so long as you don’t want to machine it!!!
It definitely is not what you expect from the company that’s known for pragmatism. Anyway that does piss me off.
The way this machine is being used is running programs from a memory stick. At first I thought it was a bit crazy as the programs weren’t particularly big.
Anyway surprise surprise it works well. Just plug in and press load and it runs. But what about editing you ask. No problem you just do it. Same as normal.
Program restart, no problem works exactly the same as when running from memory.
Haas VF3
This week I got to train two people on a Haas VF3, and what a delight it was. This machine was old I mean 1996 but still a great functional machine tool.
I like to see myself in a similar way, really old but still functioning, well at least as I write.
Haas VF3
It took me back to when I first set up my business of training people on CNC machines. My first two victims were at Armitage Shanks in good old Wolverhampton.
1996 was the year I started out on my own CNC Training and these were the first machines I trained on. I did so many I got pissed off with the sound of my own voice (which I rarely do).
Because all the machines were the same I was saying the same things and quoting the same tired old anecdotes day after day.
Fortunately, I went on to train on all the well-known CNC machines like Mazak, Mori Seiki, Matsuura, Bridgeport to name a few. Quite a lot of the not so well-known ones like Maho, seen below.
Haas VF3
The machine above has a Phillips control and they were the absolute dogs’ bollocks. It even had rigid tapping. You could hit feed-hold while it was tapping and you got the option to reverse the tap out! Training people on these was an absolute delight.
Don’t forget we’re talking mid 80s here.
Shut up David this sounds like a big plug for the CNC Training Centre, or maybe it is.
CNC Training Centre (Home of the CNC Program)
There is pub by us and on the sign, it says “The Home of the Roast”.
You have to queue up to get your food and a young lad carves the meat in front of you. If he don’t like the look of you, which obviously with me he didn’t, you get two or three slices of turkey, so wafer thin, you can see the pattern on the fuckin plate underneath.
Now I don’t want to knock the people of Nuneaton, being as most of my family live there, but honestly there are some greedy bastards about.
After you get your meat and a few accoutrements you follow a long line of people adding cabbage and peas and all sorts of vegetables and potatoes to their plates. This bloke in front of me was scooping so much on to his plate it was flowing over. It was like a fuckin bowler hat as my late father would say, sans expletive.
In those days you didn’t swear in front of ladies, unless of course it was their turn.
I was just thinking “did you like not eat for a fuckin week?” You can imagine his kids at school saying to the teacher “oh, we’re not eating at our house this week miss”. The teacher then asks if this is some precursor to a religious festival or some such thing.
“Oh no miss, we’re booked in at the carvery for Sunday lunch” she gives them a knowing nod.
Anyway, I looked at this blokes plate with utter middle class disgust and vowed never to go there again.
My mate was about three people in front of this bloke and to my amazement my mate’s plate was so full of food, it made his look like he’d paid for the children’s menu.
G10
No G10… Is this you?
G10
G10
Make Sure Your in Absolute
Call David: 07834 858 407
A Canned Cycle What is It?
If you want to learn CNC programming  then you need to know what a canned cycle is.
In a Can…….Learn CNC
dog-163527
X60.
X70.
X80.
X90. Y60.
Want to know More?
Anyway Here are a few:
G98 G99
 G43 Z50.H1 M8
X60.
X70. G99
X80.
X85. G98
X90. Y60.
g98gif
Why you ask?
Easy you can jump over shit.
spiderman-1579249
It Gets Better.
X60.
X80.
X90. Y60.
Now let’s alter the feed
X60. F300. (Change feed)
X70.
X80.F200.(Change it back)
X90. Y60.
Do’s And Don’ts
Do Not………
X60.
X90. Y60. (ETC)
Do Not Repeat Axis Moves.
X60. Y50. (Don’t need Y50.)
X70.
X80.
X90. Y60.
D0…….
  • Always use a canned cycle if possible it saves loads of time. It is also really easy if you need to edit anything.
  • Make your CAD/CAM system output canned cycles, not long hand code. I saves loads of time if you need to edit.
  • Love engineering and be nice to your cat.
Learn CNC
Learn CNC
O0001(Drill and Tap M10)
T01 M06 (20mm Spot Drill)
G90 G0 G54 X0 Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-10. R1. F100 L0
G91 X-31.63 L9
G0 G53 Z0
ETC
  • The programme moves to the datum X0 Y0 which is the middle of the part at the right hand end.
  • The G81 has an L0 at the end. L0 is not a Lionel Richie song it just means don’t do one. So it moves to X0 Y0 and does nothing.
  • The next line, G91 means incremental move so it moves incrementally nine times (L9) X-31.63 and drills a hole each time.
Learn CNC
