G76 Chamfer End of Thread
Category : Fanuc Turn New Stuff
G76 Chamfer, this is another myth exploding article about the G76 threading cycle.
It’s so easy to use cycles like G76 day in day out and never really fully understand how they work.
I certainly did and then one day I thought “Fuck this I need to know more”
That’s when I sorted out the number of passes thing. If you don’t know how to calculate the number of passes in a threading cycle then you should read the article above.
(G76 Chamfer) I want to talk about the P
G76 P011560 Q20 R.02
P01   One spring pass       15   Chamfer        60   Thread angle
Q       Minimum depth of cut
R       Finishing allowance
X         Core diameter of thread
Z         Thread end point
P         Depth of thread (as a radius no decimal point)
Q        Depth of first cut no decimal point.
F         Pitch of thread
Six Figure P Number Holy Shit
First two digits are easy, spring cuts. No it’s not the latest haircut for April.
Hitachi Seiki Made Some Brilliant Machines
Category : New Stuff
Hitachi Seiki made some amazing machines many of them are still around. Read about one that I recently trained on and the typos in the manual.
I have pondered for a while about writing this article because what triggered it was a miss print. Actually I don’t know what you call it. Maybe a translation error. If you read to the end you’ll see why.
This article is purely frivolous so if you are seeking CNC Programming knowledge there’s not much. (Except for the bit about the Hitachi Seiki machines)
Read one of my other articles which are crammed with useful programming tips and information.
CNC Programming
Are You a Self Taught at CNC Programming?
It is very common now a days to be self taught in CNC Programming. I don’t have a problem with this because really I fall into the same category.
The problem seems to be with some people is that once they get everything running enough to satisfy the boss they stop learning and look no further.
The thing with me is that while my contemporaries were reading the Daily Mail reinforcing their racist, sexist, homophobic, misogynistic views, I spent my time reading the boring shitty old manuals.
This in turn gave me knowledge that I could use in later life to charge people much inflated prices for CNC Training.
These manuals really were absolute dog shite in terms of the way they were written.
I mean they were full of mistakes and misspelt words and even the smallest thing took ages to understand. Fuck knows why I persevered and learnt, but I did.
Remember there was no YouTube no TicTok not even an Internet. Platform shoes were mandatory even the mullet hadn’t been invented yet.
I still do it to this day, read manuals that is.
G10
No G10… Is this you?
G10
G10
Make Sure Your in Absolute
Call David: 07834 858 407
A Canned Cycle What is It?
If you want to learn CNC programming  then you need to know what a canned cycle is.
In a Can…….Learn CNC
dog-163527
X60.
X70.
X80.
X90. Y60.
Want to know More?
Anyway Here are a few:
G98 G99
 G43 Z50.H1 M8
X60.
X70. G99
X80.
X85. G98
X90. Y60.
g98gif
Why you ask?
Easy you can jump over shit.
spiderman-1579249
It Gets Better.
X60.
X80.
X90. Y60.
Now let’s alter the feed
X60. F300. (Change feed)
X70.
X80.F200.(Change it back)
X90. Y60.
Do’s And Don’ts
Do Not………
X60.
X90. Y60. (ETC)
Do Not Repeat Axis Moves.
X60. Y50. (Don’t need Y50.)
X70.
X80.
X90. Y60.
D0…….
  • Always use a canned cycle if possible it saves loads of time. It is also really easy if you need to edit anything.
  • Make your CAD/CAM system output canned cycles, not long hand code. I saves loads of time if you need to edit.
  • Love engineering and be nice to your cat.
Learn CNC
Learn CNC
O0001(Drill and Tap M10)
T01 M06 (20mm Spot Drill)
G90 G0 G54 X0 Y0 S1500 M3
G43 Z3. H1 M8
G81 G98 Z-10. R1. F100 L0
G91 X-31.63 L9
G0 G53 Z0
ETC
  • The programme moves to the datum X0 Y0 which is the middle of the part at the right hand end.
  • The G81 has an L0 at the end. L0 is not a Lionel Richie song it just means don’t do one. So it moves to X0 Y0 and does nothing.
  • The next line, G91 means incremental move so it moves incrementally nine times (L9) X-31.63 and drills a hole each time.
Learn CNC
