Day: June 1, 2023
G28 G53 Zero Return
G28 G53 Zero Return
CNC Training (Call David: 07834 858 407)
G28 G91 Z0                   (Z axis moves up to tool-change)
G28 G91 X0 Y0 Z0        (All three axis move to their respective zero return positions)
If you programmed
G28 G90 Z0 or you forgot the G91 this means return to zero point via a reference point. The reference point is Z0 so the spindle would rapid to Z0 (Bang) and then move up to reference return point.
G28 G53 Zero Return
Using G53
G53 Z0
You need to write
G53 Z0
G53 X0 Y0
Note:
T01 M6
G53 Z0
T01 M6
Tosnuc 888
Tosnuc 888
If you have any questions about G28 G53 Zero Return or you are affected or have been affected by any of the issues in this post please contact me 07834 858 407
