Day: February 11, 2025
G76 Chamfer End of Thread
Category : Fanuc Turn New Stuff
G76 Chamfer, this is another myth exploding article about the G76 threading cycle.
It’s so easy to use cycles like G76 day in day out and never really fully understand how they work.
I certainly did and then one day I thought “Fuck this I need to know more”
That’s when I sorted out the number of passes thing. If you don’t know how to calculate the number of passes in a threading cycle then you should read the article above.
(G76 Chamfer) I want to talk about the P
G76 P011560 Q20 R.02
P01   One spring pass       15   Chamfer        60   Thread angle
Q       Minimum depth of cut
R       Finishing allowance
X         Core diameter of thread
Z         Thread end point
P         Depth of thread (as a radius no decimal point)
Q        Depth of first cut no decimal point.
F         Pitch of thread
Six Figure P Number Holy Shit
First two digits are easy, spring cuts. No it’s not the latest haircut for April.
G10
No G10… Is this you?
G10
G10
Make Sure Your in Absolute
