Heidenhain Program Restart iTNC 530
Heidenhain Program Restart. Now you must have heard me banging on about program restart on certain machine controls.
On some it’s just non existent the best you can do is move to a tool change and start there. Oh and pray to any god you may believe in.
On a Fanuc control program restart it’s a rare option, and no fucker knows how to use it anyway, except me so click on this link.
Work Around
Without it, if you really know what you are doing you can restart programs.
This said you must have a real good knowledge of programming and modal G Codes.
What you can do is read the tool change line (M6 T06) then let the machine read the G43 line to take in the tool offset. Now you can then go on to read the canned cycle. From this point you can move on to any position and it will carry on (allegedly).
This is Fuckin dodgy. It’s a bit like having cataract surgery whilst driving a Sherman tank. You definitely need to be over 21 and not of a nervous disposition.
Chimpanzee baby
Anyway it does work, honestly, just be sure there is a full moon and you turn the control panel to face Mecca.
Joking aside make sure you understand the modal information on your control panel which you should do anyway.
What’s Modal Information?
Well it’s that screen you’ve been ignoring for years.
Please take your time and have rapid at minus 1000,000%. Be in single block and read this.
Remember if you crash this beast I will say I never met you and I definitely didn’t write this article, which will suddenly disappear into the ether at the slightest sniff of a lawsuit.
You know that screen you cant even be arsed to look at?
Well actually it contains some very useful shit so pay attention you naughty boy.
So this means you know and understand the following.
  • Is the machine in absolute or incremental?
  • What work offset is active?
  • Is the tool offset active and if so which one?
  • Is the machine still in compensation G41 G42?
  • Is the plane selection correct, usually XY G17?
  • Is the machine in feed per rev or feed per minute?
  • What speeds and feeds are active?
  • Is the machine in rapid or feed G0 or G1?
  • By the way if you come to me for some training I can impart all this knowledge on you.
Sinumerik Training Sub Programs
Sinumerik Training, with Siemens Sinumerik there are many ways to call a subprogram. Subprograms are a really convenient way to repeat a piece of program.
You could have an incremental program and call it in several places. You could profile the outside of a part with two different tools. One for roughing then one for finishing.
Siemens Training Click Here
The program below calls an external subprogram “THE_SHAPE” twice. The first time with a 20mm Endmill then the second time with a 10mm Endmill.
External means it’s another program somewhere in the directory.
Sinumerik Training
This is the subprogram.
Sinumerik Training
These subprograms need to end with an M17 (Fanuc uses M99). This tells the control to go back where it came from.
Providing the program is in the same folder as your main program then you just need to write in the name to call it.
Haas Super Mini Mill
I’ve wanted to get my hands on a new Haas machine for a while. Really wanted to see what the new control was like.
Haas Mini Mill
Stiltz provided the machine and the victims for the training.
If you have read any of my articles you will know I have always had an affection for Haas machines. The first one I ever worked on being about 1994. At that time they were nothing short of ground breaking innovation.
Things like a built in airline and coolant wash-hose were not only innovative but really useful.
Coolant Hose (What Will You Do With This)
A machine that worked straight out of the box. Easy peasy tool-change. Handwheel to scroll through the program, people still get impressed by this today.
Programmable coolant nozzles, fuckin hell that was a game changer. Just move nozzle to a position and press an F key and it’s stored with the offset.
Macro at no extra cost (wow) some people wanted two grand for this (cost of a good family car in 1995)
Program restart still the best in the world, don’t get me started.
The New Machine David How Was It?
To start with on this one I didn’t like the interface but it does grow on you. You need to get used to using the touch screen. Access to some menus is a bit convoluted too.
This Haas Mini Mill has a 10k spindle and 30 tools.
Something I suddenly remembered about this model. Well you know when you get a cup of coffee and it’s in a tall tapered glass mug? You are thinking “nice big cup of coffee”. You take four big swigs n it’s gone, shit what happened. What happened is an optical illusion because the cup is tapered it’s actual capacity is that of a thimble.
It happens all the time everything comes in a great big box with loads of packaging and the actual item is minute.
Anyway try moving this machine to the end of it’s stroke in X. Fuckin hell what a disappointment I recon you can only move around about half the table. I mean great you can put a pretty big part on here. That’s great so long as you don’t want to machine it!!!
It definitely is not what you expect from the company that’s known for pragmatism. Anyway that does piss me off.
The way this machine is being used is running programs from a memory stick. At first I thought it was a bit crazy as the programs weren’t particularly big.
Anyway surprise surprise it works well. Just plug in and press load and it runs. But what about editing you ask. No problem you just do it. Same as normal.
Program restart, no problem works exactly the same as when running from memory.
