This is a short video that covers Flatland Finishing and Intermediate Slices. You may have forgotten you can do this or maybe you didn’t know it existed. Please add comments and request any tutorial videos you may want.
If you liked this video, please don’t forget to subscribe to my YouTube channel by going to:CNC Training Centre
You can reset Fanuc Display (Relative Position) just like you would on a manual machine with a DRO. So use it for setting or even measurements. One thing to remember is it will not retain it’s position when you turn the machine off. The control in the video is a Fanuc 18i on a big vertical lathe but all other Fanuc controls are similar.
This is a video explaining cutter compensation in CNC programming.
Tool cutter comp.
CNC cutter comp.
G41 G42 cutter compensation.
Cutter diameter compensation.
Cutter radius compensation.
Heidenhain RL RR.
This means that when you input the data for your cutting tool in your offset table you can use the diameter or the radius of the tool. This depends on your settings.
(Cutter compensation G code)
G41 cutter compensation left
G42 cutter compensation right
G40 G code to cancel cutter compensation
This Video shows you :
How to program G41.
How to program G42.
CNC cutter compensation examples.
Cutter compensation Heidenhain style.
Heidenhain RL RR.
We always recommend that you climb mill so you will be using G41 most of the time.
What will you do when your cutter wears?
What if you want to use a different size cutter?
The cutter may not run true.
What if the cutter is not exactly size?
The Rules:
Shape must be continuous and consistent.
You can’t cut along a line and then go back along it.
It’s important to allow more than the tool radius when entering tool compensation. The same applies when you come out of tool compensation.
Internal corner radii and steps must be greater than the tool radius.
Don’t ask
You do not need leading or trailing zeros in a CNC program (see below):
O0001(G81 DEMO) G21 G90 G40 T01 M06 (20.0 MM DIA X 90 POINT SPOT DRILL) G90 G00 G54 X12.64 Y88.00 S2546 M03 G43 H01 Z15.00 M08 G0 Z100.00 Z1.00 G01 Z-0.1
Without leading Zero is exactly the same. (Trust me it won’t self destruct or start world war 3) O1(G81 DEMO) G21 G90 G40 T1 M6 (20.0 MM DIA X 90 POINT SPOT DRILL) G90 G0 G54 X12.64 Y88. S2546 M3 G43 H1 Z15. M8 G0 Z100. Z1. G1 Z-.1
Try to keep your code consistent. As I mentioned before try to make all programs look the same.
Leading Trailing Zeros, if you are short of memory (not as in forgetful) this can save loads of space, and you might be surprised how small the memory is on some CNC machines, some have the memory of a fish.
CNC Programming
The main thing is that you are happy with the layout of your program.
If you are not consistent with your approach it can cause a lot of problems.
Please remember that when you are typing code into the machine it will take you considerably longer to type G01 X0.200 Y0.200 F100.00 than G1 X.2 Y.2. It could wear out your fingers or give you multi RSI.
A Haas control will automatically add leading zeros but just try to ignore it. Maybe Mr Haas likes to see them.
