Leading Zeros Programme Numbers
Next time you call up a programme on your Fanuc or Haas control. Instead of typing O0001
Just type O1
I know it’s daft but just add up all the time you wasted (Three presses of your Zero key no wonder it’s worn out)
Training Courses
Fanuc Haas Training
More Heidenhain
Drawing Datum
On  a Fanuc control it’s a G code usually G54 although as standard you have six of these.
G54 G55 G56 G57 G58 G59
Zero Return
X 0.000
Y 0.000
Z 0.000
What about Z you say?
Mazak Work Offsets
CNC Training Mazak
Toshiba BMC 800 Work Offsets
Is Six Enough?
Right Let’s Wrap This Up
So now if we program
Because G54 is Modal.
Digital Readout
Toshiba Tosnuc CNC Training
G57 H901
G0 X0 Y0
So Where’s This All Going?
Now then think about this.
Don’t Just Plonk It Anywhere
Now when you program.
G0 G55 X0 Y0
By The Way
There’s More
Matsuura Training 500v
Lets Save Some Time
Mazak Training
Doesn’t matter either.
Work Offset G54 G55 G56
And…
Heidenhain
Bridgeport Interact 412
Heidenhain Training
This would call out offset 1.
Just zero the display.
How easy is that?
Heidenhain Training
Heidenhain Training
Heidenhain Training
So there you go from Heidenhain on a Bridgeport Machine to Matsuura MX520 with a Matsuura G-Tech 31i control. There are loads of different machines but the principle is always the same.
Call David 07834 858 407
Jump Around Using M99 Plus Block Skip
M99 Plus Block Skip, M99 on a Fanuc, Haas or Mazatrol ISO control can be used to jump sections of code.
Learn to use this in conjunction with the block skip command to switch it off and on.
Now I know you are all thinking “Dave you’re wrong it’s the end of a sub-program”. (Please in the name of holy shit do not call me Dave.)
Well you are right and you are wrong.
Yes it means continue and is used at the end of a sub program.
But it also has another nifty use.
Imagine you want to skip a complete section of program in the case below it’s the Spot Drill.
Let’s See Some Crap Ways Of Doing This
(If you want to do this on a Toshiba Tosnuc 888 or similar control go to the end of the article)
In this example it’s a spot drill we want to miss out.
M99 Plus Block Skip
Standard Code
You could delete it and make two programmes (sounds like hard work and loads of errors). Not to metion wear on your finger tips. Truth is it’s just a shit way to do it.
M99 CNC Code
Block Skip
The programme above  contains BLOCK SKIPS sometimes called BLOCK DELETES.
When you switch on your BLOCK DELETE/BLOCK SKIP switch, each time a forward slash (/) is seen that block will not be processed and the control will move on to the next block.
M99 Plus Block Skip
On most Fanuc controls it’s B.D.T not to be confused with CBT (Cock and balls torture) please do not google this in company time.
It works ok but it is very time consuming. If you want to skip a big section of code you will have to write in loads of block skips.
Call me a lazy bastard but I definitely couldn’t be arsed with that.
Some controls even have two three and four block skips so you can switch on any combination of these switches, mmmm complicated. Good luck with that one.
Do You Have Adequate Life Insurance?
M99 CNC Code (Now let’s use it)
The next example is the easiest way.
You probably normally see an M99 at the end of a sub programme.
In the case below it tells the control to jump to N100 (M99 P100).
The P part is the N number you want to jump to.
M99 P600 (Jump to N600)
M99 P6666 (Jumps to N6666)
M99 Plus Block Skip
If you put the BLOCK SKIP/BLOCK DELETE on it will not jump the spot drill.
You would have a choice. If you temporarily want to skip a section of code.
Be careful what N Numbers you choose so as not to mix them up.
Maybe you broke all the taps and you don’t have anymore so you want to skip the tapping. In this case I’d just jump with M99 and then take it out before saving the program.
However, see the next Example.
For this last example you might have to think a bit. Call me finicky but I like the BLOCK SKIP/BLOCK DELETE as a default to be off.
Most machines now don’t have a mechanical switch for BLOCK DELETE/BLOCK SKIP so when you turn on the machine block skip will always be off.
That means the default would be to jump the code.
My way of looking at it, is that you would want the default to be running the whole program as normal.
So We Are Agreed
The default should really be the way the programme was originally done.
In the example below if the block skip is off, which it will be when you start up your machine.
The first thing it will do is jump over the bit that tells it to jump the code.
Meaning it runs as normal not jumping any tools.
The Clever Shit (M99 Plus Block Skip)
M99 Plus Block Skip
What’s This?
Now I know this is a bit confusing and maybe I didn’t explain it too well. Trust me it works.
What’s the matter with you lot just take some time to fuckin read it.
Sorry I’m losing my temper a bit here, the dog’s just pissed on the TV remote again. Just read through it a few times and the penny will drop.
CNC Training Centre Classroom Training
Where the teacher is never angry.
DO NOT PASS GO DO NOT COLLECT £200
Yes you can do this with GOTO
This is my pet Cockroach his name is Boris
GOTO 100
Same as M99 P100
To do this you must have the Macro Option if you don’t then this is where M99 comes in handy.
Best way to see if you have macro is to try using it in MDI.
In MDI Type in #1=6 if you have macro it will work if you don’t you’ll get an alarm and your machine will self destruct in 15 minutes.
Jumping Sections of Code on a Toshiba Tosnuc 888 or Similar
This is how you do it on a Toshiba (the blue bit).
Don’t forget it’s GO (that’s G and letter O) not G0 which is G and number zero (Rapid Command).
Don’t get your letter O’s and your number zeros mixed up.
/M99 P50                                   /[GO,50]               (JUMP TO N50)
M99 P100                                    [GO,100]            (JUMP TO N100)
N50                                              N50                      (ARRIVE HERE
THE CODE
THE CODE
THE CODE
ETC
ETC
ETC
ETC
N100                                            N100                      (ARRIVE HERE)
Without Fancy Shit  (Just jump some code)
THE CODE
THE CODE
THE CODE
ETC
ETC
ETC
ETC
If you have macro you can do a similar thing on Mazak, Haas or Fanuc.
Call 07834 858 407
G76 Threading Cycle
G76 Threading Cycle
Oh and It Gets Worse.
And not to mention all that boring maths that you will have to do. You remember that teacher with the beard that kept banging on about ratios and differentiation? Well, maybe you should have paid more attention.
Some of them are just boring and only used by clever fuckers, not normal people like you and me.
Really, you don’t need to know, it’s just me trying to impress. Most of the cycles on a CNC Lathe are wrongly call Canned Cycles. The correct name for a cycle like G76 Threading Cycle and G71 Roughing Cycle is a Multi Repetitive Cycle. No that’s not an illness it’s the correct name. So don’t start ringing the “no win no” fee lawyers.
That’s another piece of useeless information.
Haas and Some Fanucs
G76 X16.93 Z-25. K1.534 D.485 A60 Q0 P2 F2.5
X = Core diameter of thread
Z = Thread end point
D = Depth of first cut
F = Pitch of thread
You could write:
Fanuc
G76 P010060 Q20 R.02
P01   One spring pass       00   Chamfer        60   Thread angle
Q       Minimum depth of cut
R       Finishing allowance
X         Core diameter of thread
Z         Thread end point
P         Depth of thread (as a radius no decimal point)
Q        Depth of first cut no decimal point.
F         Pitch of thread
Third two are the tool angle.
G76 Threading Cycle
Fuck The Zeus Book
Lets Cut an M20 x 2.5  Thread Using The G76 Threading Cycle
Thread Depth =.614 x Pitch
.614 x 2.5 = 1.535
G76 Threading Cycle
Have You Been Doing it Wrong for Years?
There are some absolute pricks out there claiming to know all about CNC Programming who actually know Jack Shit.
G76 Threading Cycle
It is where the tool plunges into the thread and the cut gets wider and therefore is more prone to chatter as it deepens. It is going straight down the centre of the thread vee.
If you put in A60 then the cycle will flank cut.
Flank Cut?????
See below:
Don’t know what flank cutting is? Don’t worry it just means you are stupid. I won’t tell anyone, your secret is safe with me.
Help is At Hand
Ways to cut a thread
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
So Which One Is Best.
Why?
With method three you get a nice even cut with less chatter and less tool wear. It’s also kinder to your insert and better for the environment.
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
Is this you?
Come on now this is not good.
Wooppee It’s Easy
So on your calculator:
(1) Press keys for depth of the thread eg 1.534
G76 Threading Cycle
(2) Press divide key (÷)
then press the √ key
G76 Threading Cycle
G76 Threading Cycle
1.534 ÷ √10 = 0.4854
D.485
So your cycle reads
  1. Enter the depth of thread (K Value).
  2. Press ÷
  3. Enter depth of first cut (D value)
  4. Press =
  5. Press the squared key (²)
The answer is:
10.01689871 that’s 10 to you.
G76 Threading Cycle
So next time you cut a thread don’t guess the number of passes uses this formula it’s dead easy. You can also loose weight if you do this as part of a calorie controlled diet.
As in the example above.
(1.534 / .4854)²
1.534/.4854 = 3.1602
3.1602 x 3.1602 = 9.98737 (10 to you)
1.534 ÷√1   = 1.534      Cut = .000
1.534 ÷√2  = 1.084     Cut = .450
1.534 ÷√3  = 0.885     Cut = .199
1.534 ÷√4  = 0.767     Cut = .118
1.534 ÷√5  = 0.686     Cut = .081
1.534 ÷√6  = 0.626     Cut = .060
1.534 ÷√7  = 0.579      Cut = .047
1.534 ÷√8  = 0.542     Cut = .037
1.534 ÷√9  = 0.511      Cut = .031
1.534 ÷√10 = 0.485     Cut = .026
Some friendly Advice
Oh Yea Here Is Another Tip
When using G76 you can’t use feedhold. On some controls the tool will retract but please check the small print first or try it in fresh air.
A Few Rules
  1. Always use G97 speed in RPM you can’t use G96.
  2. Don’t move the Z start position unless it’s by a multiple of the pitch.
  3. Don’t change the speed.
  4. Machine has to accelerate into the thread so start at Z5. depending on the speed and pitch this may need to be more.
  5. Watch out for that Z end point. That’s the one that will make it hit the chuck if you get it wrong.
  6. Come and train with us.
Contact Us
Siemens Sinumerik Training
