Haas TL2 Thread Repair
Call David: 07834 858 407
Haas TL2 Thread Repair, this is a really useful function on a Haas tool room Lathe. The XYZ machine does this too.
Isn’t it rather funny that all the people that tell me how shit electric cars are never seem to have had one.
CNC Training Centre Company Car
I got mine at a bargain price when my mate gave up his milk round in 1976
Well I must admit I thought the Haas toolroom lathe was shit. But in honesty I didn’t really give it a close look.
Well now I have, I can honestly say it’s actually not bad. I certainly had fun with this one.
As a semi automatic machine it ticks the boxes.
Thread Repair Let’s Get Started
First of all line your tool up with the thread on your Haas tool room Lathe.
Take some time to get this right. You now need to tell the control exactly where the thread is. That is you tell it how many thread you are from the end of the thread.
Go to REFERENCE box and press enter
This will now come up as set.
Tell it the length of your thread, note this is a positive value.
Also you need:
  • Pitch
  • Height
  • Left or right hand
  • Spindle speed
  • Depth of cut
You can now run this or send it to MDI
Mmmm how the fuck does it do that. You might be a bit nervous when it comes to running this. Rightly so I know I was. Might be good idea to try it on a dummy part or a test piece on your Haas tool room Lathe.
Honestly it does work. Be absolutely sure the information is correct.
How Does It Work
Well it’s just magic
Let me explain.
Here’s the code
First of all it sets offset G154 P99 to zero (hopefully you are not using this work offset. This means that all you positions are absolute machine positions from zero. Just like you used G53
That’s the G10 L20 P99 X0 Z0
It will then rapid away from this by the clearance you gave it. G00 X-218.004
It then rapids to the start of the thread G00 Z-1020.661
Starts the spindle as requested G97 S1000 M03
So it has recorded your current position and moved away from it.
The G76 will use the recorded position to work out where the end of the thread is and use the position you were at in X to set the X root diameter.
Now the Q is the angle that the spindle is at, that is how it knows where to start from a rotary point of view. Without this it’s a shitstorm.
It’s all a bit crude but then so am I, and me and this Haas both work.
Push away hit CYCLE START (just don’t say it was my idea)
G76 Threading Cycle
G76 Threading Cycle
Oh and It Gets Worse.
And not to mention all that boring maths that you will have to do. You remember that teacher with the beard that kept banging on about ratios and differentiation? Well, maybe you should have paid more attention.
Some of them are just boring and only used by clever fuckers, not normal people like you and me.
Really, you don’t need to know, it’s just me trying to impress. Most of the cycles on a CNC Lathe are wrongly call Canned Cycles. The correct name for a cycle like G76 Threading Cycle and G71 Roughing Cycle is a Multi Repetitive Cycle. No that’s not an illness it’s the correct name. So don’t start ringing the “no win no” fee lawyers.
That’s another piece of useeless information.
Haas and Some Fanucs
G76 X16.93 Z-25. K1.534 D.485 A60 Q0 P2 F2.5
X = Core diameter of thread
Z = Thread end point
D = Depth of first cut
F = Pitch of thread
You could write:
Fanuc
G76 P010060 Q20 R.02
P01   One spring pass       00   Chamfer        60   Thread angle
Q       Minimum depth of cut
R       Finishing allowance
X         Core diameter of thread
Z         Thread end point
P         Depth of thread (as a radius no decimal point)
Q        Depth of first cut no decimal point.
F         Pitch of thread
Third two are the tool angle.
G76 Threading Cycle
Fuck The Zeus Book
Lets Cut an M20 x 2.5  Thread Using The G76 Threading Cycle
Thread Depth =.614 x Pitch
.614 x 2.5 = 1.535
G76 Threading Cycle
Have You Been Doing it Wrong for Years?
There are some absolute pricks out there claiming to know all about CNC Programming who actually know Jack Shit.
G76 Threading Cycle
It is where the tool plunges into the thread and the cut gets wider and therefore is more prone to chatter as it deepens. It is going straight down the centre of the thread vee.
If you put in A60 then the cycle will flank cut.
Flank Cut?????
See below:
Don’t know what flank cutting is? Don’t worry it just means you are stupid. I won’t tell anyone, your secret is safe with me.
Help is At Hand
Ways to cut a thread
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
So Which One Is Best.
Why?
With method three you get a nice even cut with less chatter and less tool wear. It’s also kinder to your insert and better for the environment.
G76 Threading Cycle
G76 Threading Cycle
G76 Threading Cycle
Is this you?
Come on now this is not good.
Wooppee It’s Easy
So on your calculator:
(1) Press keys for depth of the thread eg 1.534
G76 Threading Cycle
(2) Press divide key (÷)
then press the √ key
G76 Threading Cycle
G76 Threading Cycle
1.534 ÷ √10 = 0.4854
D.485
So your cycle reads
  1. Enter the depth of thread (K Value).
  2. Press ÷
  3. Enter depth of first cut (D value)
  4. Press =
  5. Press the squared key (²)
The answer is:
10.01689871 that’s 10 to you.
G76 Threading Cycle
So next time you cut a thread don’t guess the number of passes uses this formula it’s dead easy. You can also loose weight if you do this as part of a calorie controlled diet.
As in the example above.
(1.534 / .4854)²
1.534/.4854 = 3.1602
3.1602 x 3.1602 = 9.98737 (10 to you)
1.534 ÷√1   = 1.534      Cut = .000
1.534 ÷√2  = 1.084     Cut = .450
1.534 ÷√3  = 0.885     Cut = .199
1.534 ÷√4  = 0.767     Cut = .118
1.534 ÷√5  = 0.686     Cut = .081
1.534 ÷√6  = 0.626     Cut = .060
1.534 ÷√7  = 0.579      Cut = .047
1.534 ÷√8  = 0.542     Cut = .037
1.534 ÷√9  = 0.511      Cut = .031
1.534 ÷√10 = 0.485     Cut = .026
Some friendly Advice
Oh Yea Here Is Another Tip
When using G76 you can’t use feedhold. On some controls the tool will retract but please check the small print first or try it in fresh air.
A Few Rules
  1. Always use G97 speed in RPM you can’t use G96.
  2. Don’t move the Z start position unless it’s by a multiple of the pitch.
  3. Don’t change the speed.
  4. Machine has to accelerate into the thread so start at Z5. depending on the speed and pitch this may need to be more.
  5. Watch out for that Z end point. That’s the one that will make it hit the chuck if you get it wrong.
  6. Come and train with us.
Contact Us
Siemens Sinumerik Training
