Bridgeport using Heidenhain to Matsuura using G-Tech 31i control.
More Heidenhain
Drawing Datum
On a Fanuc control it’s a G code usually G54 although as standard you have six of these.
G54 G55 G56 G57 G58 G59
Zero Return
X 0.000
Y 0.000
Z 0.000
The “MACHINE” position tells us how far we are from the machine zero. We don’t use this at all once we have set our datums.
What about Z you say?
Mazak Work Offsets
Toshiba BMC 800 Work Offsets
Is Six Enough?
Right Let’s Wrap This Up
So now if we program
Digital Readout
This is one of my favorite controls. Call me a geek but I get really excited about this kind of stuff. Below is the 888 control. (The 666 is a bit of a devil to program)
G57 H901
G0 X0 Y0
So Where’s This All Going?
Now then think about this.
Don’t Just Plonk It Anywhere
Now when you program.
G0 G55 X0 Y0
The machine will use the new datum. Easy what.
By The Way
There’s More
The tool change chip to chip is going to be about 17 seconds. Machines like the new Matsuura MX 520 tool change in just over a second.
Lets Save Some Time
Doesn’t matter either.
Work Offset G54 G55 G56
And…
Heidenhain
Bridgeport Interact 412
This would call out offset 1.
Just zero the display.
How easy is that?
So there you go from Heidenhain on a Bridgeport Machine to Matsuura MX520 with a Matsuura G-Tech 31i control. There are loads of different machines but the principle is always the same.
Call David 07834 858 407
