Category Archives: Fanuc Mill
CNC Milling G Code List For Beginners
Download and print this nice large print CNC Milling G Code List
Download CNC Milling G Code List PDF
I always begin my training sessions by telling my students not to remember anything I say.
This sounds completely stupid and my excuse is it wasn’t my idea to say it.
About ten years ago I worked in France. After about a year and it seemed obvious that I would need to speak to people to order “Fish n Chips” and stuff like that.
Anyway I got these CD’s to teach me French and the bloke (can’t remember his name) started off by telling you not to remember anything he told you.
I think there is a bit of reverse psychology going on but the main idea is that you understand not remember. It didn’t work for me because I still managed to completely fuck up the language. Not realizing French Canadians speak differently to native Frenchmen (I was working for Bombardier) . Anyway I asked this bloke, in French, to “come with me”. I can’t remember what it is in French and after all the bloke on the CD had specifically told me not to remember.
Anyway turns out this had a sexual connotation and made me the complete laughing stock everywhere I went from then on. (I’ll let you do the maths on that one.)
“OK who bought all The fuckin toilet paper?”
When it comes to CNC Programming the idea of not remembering loads of G Codes is really important. Truth is you only need a few and it’s all about understanding what they do.
For Example I want to drill a hole.
You completed a training course at the CNC Training Centre. You understood it all and you practiced with you free simulation software that you get with the course.
You start writing a program to drill some holes.
From your training you know that there is a cycle that drills holes.
You understand how the cycle feeds the tool down to a depth and then it rapids out ready to do another.
Quick Fix G81 Video
You also know that if you keep adding more positions (X50. Y50.) it will keep drilling holes.
And… when you are sick of drilling holes there’s another G code to stops it.
What Are These G Codes?
So you just look em up on your CNC Milling G Code List.
G81 Drilling Canned Cycle
G80 Cancel Canned Cycle
Then you think “mmm I’m sure there’s one that pecks the material out and breaks it up”
“Let me see… Ah this looks like the one
G73                 Peck Drilling
Type up or print this list in nice big letters and stick it to the side of your machine
G00                 Move at Rapid speed
G01                 Feed in a Straight Line
G02                 Clockwise Arc
G03                 Counter Clockwise Arc
G04                 Time Dwell
G28                 Return Axis to Home
G41                 Cutter Compensation Left
G42                 Cutter Compensation Right
G40                 Cancel Cutter Compensation
G43                 Apply Tool Length Offset
G54 to G59     Work Offsets
G81                 Drilling Cycle
G73                 Peck Drilling
G83                 Deep Hole Drilling Cycle
G84                 Tapping Cycle
G80                 Cancel All Canned Cycles
G90                 Absolute Programming
G91                 Incremental Programming
CNC Programming Basics Letter O Number Zero
CNC Programming Basics, in my very early days of CNC I got to do quite a lot of work for Hitachi Seiki the Japanese machine tool maker that unfortunately no longer exist.
Many of their machines are still around and running. I was fortunate enough to be trained by a Japanese engineer who focused on the CNC programming basics.
The control was called Seicos which I think was based on the Fanuc control which Hitachi made themselves.
Anyway they had an equivalent of the Fanuc FAPT which was an automatic programming system.
It was the dogs bollocks of the day.
You could do maths on the fly with this control which I recon is a great idea.
Maths On The Fly
You could input say 8/25.4 then when you pressed enter, it would calculate the answer and input it for you. Lots of software like Fusion 360 do this today.
A couple of times I read a radius from a drawing say 15 for example and I would input 30 for the diameter. Every time he would stop me and say “no no wrong” (sorry I can’t do a Japanese accent).
He would insist that I input 15 x 2 and then press enter.
I didn’t think too much about it at the time. Over the years the penny has dropped as to the significance of this lesson.
CNC Training
When I am training people now I always say that you must input exactly what you see.
Roy Walker has a Catchphrase “Say What You See”  I just love this show. I suggest you watch it now because this article gets more and more boring as it goes on.
Anyway
So if you input exactly what you see you will make less errors.
“Say What You See”
“Say What You See”
For example if I had worked it out that 15 x 2=29 or I made a typing error then I would have been in trouble.
So at what point do you decide that you will use a calculator?
What he was teaching me was, wherever possible make the machine do the work.
Taking this to its logical conclusion the way you programme from a drawing is really important and it is all part of CNC Programming Basics.
  • Make the datum wherever possible the same as the drawing.
  • If the drawing has several datum’s you could also have several datum’s.
  • If holes are dimensioned 15.865 apart and you have 4 holes don’t add it up programme it as incremental.
  • If you have polar programming (G16) on your machine and the drawing is dimensioned that way, with angles and rads, then use polar.
  • Here is a post on how to use G16
It’s Right there in Front of You
What this means is that when you look at the programme and you look at the drawing it is really easy to understand what you are doing. Remember what I have said in many posts before.
If you are the programmer the setter is your customer.
If you are the setter then the operator is your customer.
When someone else picks up your work they should easily be able to see what you are up to.
Unless your one of those assholes that really doesn’t want them to understand.
  • Read the drawing and you can see the same figures as the programme.
  • Check out the datum and it’s the same as the drawing.
We always emphasise this when we are training programmers.
The Point
Let me now get to the real point of this article this Japanese guy would never allow me to say G O as in letter O. He would insist on me saying G zero. If you think about the translation here, the only reason that we get the two mixed up is because they look the same. I would imagine to him it seemed totally wrong.
The thing is it is totally wrong.
If you place a letter O accidentally in your code instead of a number zero when you read it into your machine it will start a new programme as soon as it sees the letter O.
So you will end up where you and your poor machine are both very confused.
The letter O has only one use in a CNC programme it precedes the programme number to begin a programme (see below). The comments in brackets are totally ignored by the control and therefore you can put what you like while you are protected by the brackets.
By the way if you want to use foul language or childish rude comments them please make sure they are parenthesised. I often do this myself.
O0001 (G81 DEMO)
G21 G90 G40
G90 G0 G54 X12.64 Y88.0 S2546
G43 H01 Z15.0 M8
G0 Z100.
Where Else Can you Use The Letter O?
Sorry I lied to you. There are other uses for the letter O.
I only lied to protect you as a beginner.
What are they? Let me know
CNC and Training on all controls and machines.
Using Rads and Chamfers Fanuc Control
Category : Fanuc Mill
Rads and Chamfers Fanuc, yes you heard it there is a quick way of doing it just like on Heidenhain.
On a Fanuc control they offer two ways of adding rads and chamfers, one is pants and the other one is great.
It really is a pain in the arse to get some of these features working but it’s definitely worth the effort to sort it out. Read this article and get to work. Your life will never be the same.
The first way uses R and R- or K and K- depending on which way your going. Now I won’t be explaining how this works because really I haven’t got a fuckin clue
It’s way too complicated. If I did know I wouldn’t waste wearing out my keyboard or damaging my manicured nails to write an article.
Anyway it will only do orthogonal lines (if you don’t know what orthogonal means don’t worry it just means your a bit thick).
This by no means implies that I think all goats are stupid (technically known as goatism).
Orthogonal means relating to 90 degree lines
Now lets do it my way and you get to do shit like this.
Parameters…. Shit!!!!!
First of all you got to alter some parameters.
Well maybe you just need to check them (they might already be ok).
Anyway just read this article it tells you how to do it.
Right having done that here is a simple turned part.
Here is the code if you want to program it……Rads and Chamfers Fanuc
Now if you want to add corner rads and chamfers it looks like this.
Oh and if you got the time and the patience to write the code here is what it should look like……
The Code
(Maybe some of my smart arse readers would like to check it, don’t tell me if it’s wrong because I don’t handle failure well.)
So with a few commas an shit it’s real easy, you should try it some time.
And that’s it job done. Just remember to check those parameters,
By the way if you wreck your machine altering parameters please don’t contact me I’ll just deny all knowledge.
G82 Drilling Program Example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
This is because of the G98.
Haas G82 example
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
G73 Peck Drilling Program Example
The G73 Cycle instructs it to drill a hole 17.5mm deep (Z-17.5) at a feed of 200mm per minute (F200.)
G73 Drilling Example
Haas G73 example
