Day: October 23, 2023
For On-site CNC Training Contact David: 0783 858 407
G84 is a tapping canned cycle.
G84 taps holes.
This simple part has four M12 holes, drilled, countersunk and tapped. The datum is the centre of the part so the holes positions are.
X55. Y55.
X-55. Y55.
X-55. Y-55.
X55. Y-55.
Here is the CNC code
The G95 selects feed per revolution which means we only need to program the tap pitch for the feed-rate.
See full rigid tap G84 Rigid Tapping Program Example
The M29 engages the rigid tapping mode and the S800 is the speed. (It does not start the spindle)
The G84 Cycle instructs it to tap a hole 17.mm deep (Z-17.) at a feed of 1.75mm per revolution (F1.75)
So it feeds at 1.75mm per revolution with the spindle turning clockwise to depth.
At the bottom of the hole it reverses the spindle and feeds back to the initial point.
This initial point was in the line.
This is because of the G98.
Once the cycle is active each time it sees a position it repeats the tapping process.
When the G80 is programmed it no longer taps holes.
Single block and feedhold do not work in a tapping cycle.
Why? You ask.
IT BUSTS THE TAP
Now watch the video to see it all in action (not breaking the tap).
